A new aircraft in the category FAR-103 - Junior
meglin1
Nov 12, 2015
329
Ukraine
A new aircraft in the category FAR-103 - Junior.
Geometric characteristics:
- aircraft length - 4.2 m
- wing span - 8.7 m
- area - 8.1 m2
Airplane weight:
- maximum take-off - 220 kg
- empty - 105 kg
- fuel weight - 10 kg
Flight characteristics:
- stall speed - 55 km / h
- safe speed of a separation - 65 km / h
- approach speed - 75 km / h
- landing speed - 60 km / h
- maximum speed
horizontal flight - 130 km / h
- maximum allowable speed - 140 km / h
- recommended flight speeds - 90-110 km / h
- permissible overload +4, -1.8
Airframe design:
The frame of the aircraft is made of duralumin.
The cabin, wing and tail paneling fiberglass laminate STEF 0.5-1 mm.
Chassis:
Three-post, with controlled front wheel. The main spring fiberglass.
Avionics:
Complex device IST-912 MA
Displays:
- speed;
- height relative to sea level;
- height relative to the airfield;
- rate of climb;
- records parameters (black box).
when installing an additional controller and sensors shows:
- fuel level;
- engine speed;
- engine hours;
- temperature of two cylinder heads;
- The temperature of the exhaust gases in the two cylinders;
- air temperature in the cockpit.
10,333
NOT Part 103 legal. 103 is limited to 24 kts (44kph) stall speed and 55 kts (102kph) max speed.
8,859
No, it's not quite Part 103 legal, but it certainly could be with a little more wing area and the right prop. As it is, it looks like a great European microlight or single-seat LSA using what appears to be an off-the-shelf paramotor engine. Bravo!
meglin1
Nov 12, 2015
329
Ukraine
[QUOTE = Dana; 452666] НЕ ЧАСТЬ 103 законная. 103 ограничивается скоростью сваливания 24 кт (44 км / ч) и максимальной скоростью 55 кт (102 км / ч). [/ QUOTE]
We will do better!
RJW
Feb 9, 2011
714
Wisconsin and Kansas
That is a very cool airplane. Ultralights can be made very light with a proper spar. How much does the finished wing covering weigh? .016 aluminum weighs about 4oz per square foot. Is the finished fiberglass significantly lighter? Sorry about the Imperial/US units. Feel free to answer in metric and I’ll translate.
Thanks,
Rob
meglin1
Nov 12, 2015
329
Ukraine
Power plant:
engine Airmax 220 (Spain) power 29 HP at 8000 rpm,
2-stroke, 210 cm3 with forced cooling of the cylinders.
Fuel consumption (gasoline B-95 with oil) 6 l/h.
The air screw with a diameter of 1350 mm.
billyvray
Aug 17, 2005
899
Newnan, GA
"The cabin, wing and tail paneling fiberglass laminate STEF 0.5-1 mm"
I'm curious about the sheet material being used for covering. Is it basically a straight layup of fiberglass and resin and handled as a sheet, or used in molds before assembly to shape the parts?
Very interesting.
poormansairforce
Mar 28, 2017
1,204
Just an Ohioan
Power plant:
That's neat!
Climb rate?
Redrive ratio?
Static thrust?
Prop pitch?
pwood66889
Feb 10, 2007
1,952
Sopchoppy, Florida, USA
I apologize for the metric system...
And I appologize that this keyboard does not do Cyrlic!
So many times in my literate education, I would hit the French, the German, et al. But no "Russian in the raw." Whatta rip!
Took that language in high school as a "career move." Right after Sputnick went up, either we (Americans) were gonna take them over, or they were going to take us over!
Percy in NW FL, USA
8,812
SI is my first language. I go both ways when doing hands on stuff. I only speak Elvish for engineering when I absolutely have to. I will generally translate Elvish to the Black Speech, calculate, then translate back if it's at all complex.
meglin1
Nov 12, 2015
329
Ukraine
Very interesting.
This is a finished industrial material, sold in the store.
meglin1
Nov 12, 2015
329
Ukraine
Was also tested version with a pulling propeller. Interesting data are obtained. But this option was more sensitive to the side airflow of the propeller and therefore more difficult for Amateur pilots.
8,859
