99 Questions
Hi,
I built a Simplex Cloudster, it's nice. Sort of a motorcycle with wings. Removable fuel tank, hand-propped single-cylinder two-stroke with a multi-groove belt re-drive, three gauges (rpm, cht, egt). Perfect except for the single seat and the fact that Wisconsin winters are a bit nippy whether your bike has wings or not.
How close can I come to "simple perfection in E-AB. I sent for the EAA guide and it's a combination useless advertisement and monotonous repetition of a single rule from 20-27.
Maybe someone here could help me out.
What items do I legally need onboard an E-AB?
(Q: 3/99)
Is a replica (built from Roger Mann Ragg-A-Bon plans) of a Vagabon grandfathered like the real thing? 20-27 says it is with registration, just registration? Anywhere else?
(Q: 4/99)
Are there restrictions on the avionics I use?
(Q: 5/99)
It seems like I can use any powerplant and prop combo I choose (the plans call for a 72" x 39" Culver wood prop driven by a 50 hp Rotax that is out of production)?
(Q: 6/99)
Can I use a belt re-drive?
(repeat of Q: 2/99)
The pans call for the no longer produced Rotax 503, Power Sports suggests the Hirth 3202 as a direct replacement. I chose the Hirth 33 largely from watching the way they performed mostly from Be-Lite's videos (sadly they are gone). Be-Lite also seemed to have success with the Hirth 23. Does anyone have experience with this engine they would care to share.
(restatement of Q: 1/99)
Basically what I would like to do is build a replica of a 1946 airplane. Hand-propped, no electrics, minimal instruments, I'm fine with using the whisky compass as a wing leveler, a pressure ball air pressure (speed) indicator, non-sensitive altimiter, tach, egt, and cht.
Jack (Sheboygan WI)
(Q: 3/99)
(Q: 4/99)
(Q: 5/99)
(Q: 6/99)
(repeat of Q: 2/99)
Jack (Sheboygan WI)
