I dunno. The engine is adapted from a motorcycle where it is claimed to make 8hp at 4500 RPM. I don't think that engine is turning that direct drive prop on that airplane at anything close to 4500 RPM. Plus, if we correct for prop efficiency (maybe 70% at this low airspeed?) it wouldn't be incorrect to say the plane is flying on 3hp even if the engine is making over 4 1/4 HP at whatever rpm it is turning that prop.I looked up the wiki. It has an 8hp engine instead of 3hp posted on the youtube video. The interesting thing is. It has a cantilever wing and meets part 103 requirement.
General characteristics
Performance
- Crew: 1
- Length: 24 ft 3 in (7.39 m)
- Wingspan: 37 ft 0 in (11.28 m)
- Height: 4 ft 9 in (1.45 m)
- Wing area: 145 sq ft (13.5 m2)
- Empty weight: 232 lb (105 kg)
- Max takeoff weight: 420 lb (191 kg)
- Powerplant: 1 × ABC 8 hp 2-cylinder air-cooled horizontally-opposed piston engine, 8 hp (6.0 kW)
- Propellers: 2-bladed fixed-pitch propeller
- Maximum speed: 50 mph (80 km/h, 43 kn)
- Endurance: 1 hour 30 minutes
- Rate of climb: 180 ft/min (0.91 m/s)
I really like the EE Wren but surely that’s taxable horsepower, an old weird British calculation.
Definitely needs to be a replica of the Wren offered as a homebuilt kit, for one of the 18-24HP paramotor engines. Laser cut wood, aluminum tube 'n' gusset, bicycle style carbon tube and wrap, whatever.
For a full-scale aircraft to fly with just 3hp is pretty impressive.
That Avro could be lovely in a little more modern wood construction (glue and gussets rather than a billion fiddly metal brackets) and a Kohler V-twin or something. Do we know anyone with experience designing small wood biplanes with 1920s flair?
