Wanted 75 hp Continental parts I need.
airbike
Aug 24, 2008
194
Oil sump
Crankshaft ....not accept prop strike
2 Magnetos
Please send me your cost and pics of your 75 hp Continental parts.
8,141
Contact Bob Barrows at Fincastle, VA, R & B Aircraft. Designer of the Bearhawk aircraft. He was selling aluminum oil sumps for the Cont-0-200 engine and down.
Very nice.
A good Crankshaft for the 75 is hard to find. Most for sale are a worn out .010 under size. If turned to .020 under there is just one place that sells the bearings and they are very expensive.
Kyle Boatright
Nov 11, 2012
930
Marietta, GA
What crank does the 75 use? Stock 65 crank, or the 85 crank? I have a flanged 65 crank.
Derswede
It uses a -65 crank. All you're doing with an A-75 is spinning an A-65 faster using different pistons, a mod to the piston pins, and (IIRC) an oil hole drilled in the rods.
Derswede
Jan 6, 2016
941
Central North Carolina
AAh, yes, Harry Fenton. That man I believe knows more about Continentals than.....Continental!
So I do have a crank, will post it in the For Sale area.
Derswede
crusty old aviator
Feb 17, 2014
238
Grantham, NH
Drilled rods are for only the A80’s 5 ring pistons, the A75 has 4 ring pistons, the A65 has 3 ring pistons, and those are the only differences, other than redline.
airbike
Aug 24, 2008
194
Derswede
I do accept a flanged 65 crank. Tell me if you can send me pics and your best offer.
Richard
Derswede
Jan 6, 2016
941
PM me, I have photos and can mike the bearings to show current diameter. There is also a set of bearing shells with the crank, they were taped onto the crank with grease below to prevent any corrosion. Worked well, journals are bright and shiny.
Derswede
