Foundationer
Apparently here in the UK we finally have truly deregulated flying but it's a lot stricter than Part 103 over there in the States. What - if anything - can you do with 70kg?
Sub 70Kg Microlights. Strictly speaking these aircraft are termed Self-Propelled Hang Gliders (SPHG)! In April 2017 the CAA issued an exemption allowing Self-Propelled Hang Gliders to be fitted with wheels. Prior to this point all take-offs had to be by foot, hence footlaunched aircraft. These wheeled SPHG aircraft are defined as follows:
· an aircraft comprising of an aerofoil wing and a mechanical propulsion device which a) has a stall speed or minimum steady flight speed in the landing configuration not exceeding 20 knots calibrated airspeed; and b) has a maximum unladen mass, including full fuel, of 70 kg, or 75 kg if the aircraft is equipped with an emergency parachute recovery system.
· The specified condition is that the aircraft must not fly with more than one person on board.
These aircraft are exempt from registration and also the pilot does not require a pilot’s licence to fly them.
