Tuneturkey
Anyone,
Need some advice!
Engine is new for all practical purposes, 2:40 time on the ground, plane not yet flown.
Dual Bing 54 carbs, manually sync'd; Std complement of jets, needle jets, etc, per ROTAX; Jet needle at #2 position; Auto gas, 1:50 oil, Ultra-prop(three blade) with 12 deg. pitch plugs;
Engine inverted, Rotax diaphram fuel pump.
Mounted on a Hi-Max.
Location: Baton Rouge, LA. Currently Daytime temps 85-90 degF., elev. 39'
Concern: Engine runs cool, CHT 280-300 deg., EGT 800 +/-, idles at 2,050 - 2100rpm, full throttle max rpm 6120 - 6180, after 10 minutes.
Question: Are these temps and rpm's acceptable in a static situation? Will the rpm go up in flight to closer to or at 6500? Should an attempt be made to lean the engine to increase temps and rpm.
Thanks!
Need some advice!
Thanks!
