Most Merlin engined planes don't whistle. Some of them have a bit of supercharger whine, if coming straight at you.
My PSRU has a loud, high pitched whine. It is very similar to the whine of a super-charger.Most Merlin engined planes don't whistle. Some of them have a bit of supercharger whine, if coming straight at you.
I have a supercharged BMW Mini with a roots type blower. It sounds uncannily like an Austin-Morris Mini with noisy gearsMy PSRU has a loud, high pitched whine. It is very similar to the whine of a super-charger.
It's my understanding that they taped the barrels so the ground crew would know if the guns had been fired, after returning to base.
Yes, in the case of our Mustang and a few other Mustang owned by friends.
Our Mustang with no gun ports is used guide often by the owner to do an airshow routine. We started noticing that in hight "G" maneuvers the plane was starting to whistle just like in the video. We traced it to the gear doors sagging under "G" load. Re-rigging the gear fixed the problem.
This is my own opinion based off my experience.
Brandon
Hard for me to grasp this, as my hydraulic system will keep the inner gear doors closed flush at all times, even during high G maneuvers. The pump will run any time it senses the doors are open when commanded to be closed, or if a slight drop in pressure is detected.Thanks for the clarification sir. Makes perfect sense. I have noticed the method of attachment on the gear doors on Mustang. There is the primary hinge located at the top (when gear is extended) and there is a ring or U-bolt type fastener around the strut that holds it in place.
I can definitely see how they would sag in high G maneuvers.
Thanks again for the clarification. You are a gentleman sir!
They actually have mechanical unlocks that need to be checked every 50 hours to make sure they're holding tight.Hard for me to grasp this, as my hydraulic system will keep the inner gear doors closed flush at all times, even during high G maneuvers. The pump will run any time it senses the doors are open when commanded to be closed, or if a slight drop in pressure is detected.
Did North American not design the P-51 gear doors like this?
