4A-084 teledyne engines for sale
singledadinmo2000
Feb 25, 2020
31
Mailing address is 50 Argyle Street.
Sopchoppy, FL 32358. Advise price and address for check.
Thanks!
Sorry it took so long but I did send them parts today I will send you a price and address later I’m out working right nowI sent some valves and valve springs and some other stuff with it I don’t need it anymore so you might as well have them
pwood66889
Feb 10, 2007
1,630
Sopchoppy, Florida, USA
Got `em, and thank you so much! I'm reading your address as:
Chris Bops
2115 N. Taylor
Springfield, Mo 65803
Please confirm! Don't you just love it when a deal comes together over the Internet and Jeff Bezos doesn't get a cut??? :)
Armilite
Sep 5, 2011
3,281
AMES, IA USA
A Good Example of 084 setup for Airplane use. Reliable 45hp is all your going to get if you want it to live very long. Can it make more hp, Yes, one was upgraded and Dynoed 60hp, but it didn't last long. They lasted about 1000 hrs if minor upgrades were done and treated right. They had weak Rod Bolts, one of the minor upgrades. Here is one in Direct Drive and one with a Belt Reduction. Originally Rated 20hp at 10,000 ft for Military 10kw Generators so it would work in 98% of the World.
addicted2climbing
Jan 27, 2012
1,054
Glendale, CA
here are some photos from when I had one on a skylite
I reached out to you many years ago regarding your Skylite with the O84 engine in it. Ed told me that anything heavier than then 80lbs was too heavy for a Skylite. Curious how it worked out for you. Also it looks like you changed the rudder as well. I am the fairly new owner of the Skylite planset and sell them here. www.cloudbaseaviation.com
If the Skylite could take the heavier engine I would put in a Pegasus DP1 as I have one I will get in the next run of engines but now that is slated for the Lil Bitts. I may build a slightly larger Skylite to be able to use the DP1 at some point.
I would love to hear your thoughts of how the skylite did with the O84. Also any more pics you can share? one of your pics is too small to see. I am currently working on offer subkits as I develope them and buil done for myself.
singledadinmo2000
Feb 25, 2020
31
Chris Bops
2115 N. Taylor
Chris borg the Rest is right
singledadinmo2000
Feb 25, 2020
31
I will have to look for more pictures as long as you keep the engine close to the firewall as you can the weight and balance was fine I had to add 15 pounds to the tail to get it right but it flew like a dream that motor was made for that plane And yes you want to build a bigger tail the original is too small you will not have good ground control I found the plans for that tail that I had on the Internet
singledadinmo2000
Feb 25, 2020
31
You are so right 40 to 45 horses all you want to push that motor anymore and you will have problems but if you leave it at 40 to 45 it will run forever
