4130 Sheet Metal Neutral Axis Calculations
FokkerDVII
Feb 19, 2014
50
USA
Does anyone have a formula for locating the Neutral Axis for 4130 sheet metal when making 90 degree bends? Something in a MS Excel file would be great.
Thanks Chris
Jay Kempf
Curmudgeon in Training (CIT)
Apr 13, 2009
4,088
Warren, VT USA
For flat layout calculations? Each shop has their own sort of standards. It can vary with cold rolled vs. hot rolled, rolling direction, bend radius, the design, and the actually tooling and procedures used. Generally anywhere from 35 to 50% of the material thickness from the inside of the bend is used.
4,704
Basic Diemaking Eugene Ostergaard R<2T C=.33T, R=2T-4T C=.4T, R=>4T C=.5T R=Inside Bend Radius, T=Thickness of material, C=Location of neutral axis. I/We always used .33T at R less than 2T and .5T at R=2T or greater. I used to calculate the bend allowance but now I just draw it in cad and measure the length of the neutral axis.
FokkerDVII
Feb 19, 2014
50
USA
Very easy to measure in CAD if you have the neutral axis location. An internet search gave me much conflicting info. Yours is the practical guideline I was looking for. Thanks.
4,704
If you draw in the tangents and center of the bend on the flat pattern, you will know where to set/offset your clamp on a pan break, or where to locate the V-die on a vertical bending press. Again a Cad drawing of the bend and tool will help in understanding.
