I would replace all Gaskets & Seals, Carb Boots, Fuel Line, Fuel Pump, Fuel Filter.
2si 690
From Wikipedia, the free encyclopedia
Jump to navigationJump to search
2si 690
Type Two-stroke aircraft engine
National origin United States
Manufacturer 2si
The
2si 690 is a family of in-line three cylinder, liquid-cooled,
two-stroke, dual ignition,
aircraft engines that were designed for
ultralight aircraft.
[1]
The basic engine was originally designed and produced by
JLO-Motorenwerke of
Germany and was later acquired by the
AMW Cuyuna Engine Company of
Beaufort, South Carolina and marketed under the
Cuyuna brand name. Later the engine was marketed by Cuyuna under the
Two Stroke International (2si) brand. Cuyuna no longer markets engines for aircraft use although the 690 is still in production as an industrial and marine engine.
[1][2][3][4]
Contents
Development[edit]
The 690 is a conventional three-cylinder engine that weighs 89 lb (40 kg) in its L70 aircraft and marine versions. The aircraft engine features dual
capacitor discharge ignition (single in the marine and industrial versions), reed valve porting, tuned exhaust system, three slide venturi-type
carburetors, liquid cooling, fuel pumps, a cast iron cylinder liner, ball, needle and roller bearings throughout. The aircraft version was offered with an optional gearbox reduction dive system and a centrifugal clutch. The current industrial and marine version has an available gearbox with ratios of 2.04, 2.65 or 3.06:1. Starting is electric start only.
[1][3]
Variants[edit]
690-L70 aircraft engine
Gasoline aircraft engine with triple carburetors, 70 hp (52 kW) at 6250 rpm, weight 89 lb (40 kg), out of production.
[1]
690L-70 industrial and marine engine
Gasoline industrial and marine engine, triple carburetors, 70 hp (52 kW) at 6250 rpm, weight 89 lb (40 kg), electric starter mounted on the accessory cover end. Still in production.
[3][4]
690AL-70 industrial and marine engine
Gasoline industrial and marine engine, triple carburetors, 70 hp (52 kW) at 6250 rpm, weight 89 lb (40 kg), electric starter mounted on the power take-off end. Still in production.
[3][4]
Applications[edit]
Aircraft
Specifications (690-L70 aircraft engine)[edit]
Data from Cliche
[1] & 2si
[3]
General characteristics
- Type: Three-cylinder, two-stroke aircraft engine
- Bore: 69.5 mm (2.74 in)
- Stroke: 60 mm (2.36 in)
- Displacement: 684 cc (41.7 cu in)
- Length: 21.6 in (549 mm)
- Width: 19.05 in (484 mm)
- Height: 13.9 in (353 mm)
- Dry weight: 89 lb (40 kg)
Components
- Valvetrain: reed valve porting
- Fuel type: Minimum 92 octane
- Oil system: premixed oil and fuel at 50:1
- Cooling system: liquid cooled
- Reduction gear: optional gearbox
Performance
- Power output: 70 hp (52 kW) at 6250 rpm
- Fuel consumption: 5.1 US gal/h (19.3 l/h) at 75% power
