2A042
8,141
In my post #2 in this thread, is Kevin's engine a 2A042 ? I don't know much about them but I thought is was. His engine does a good job on the Mini-Max. The day of the video he just got back to his home field from flying in an airshow with another Mini-Max doing a formation flying demo in another state.
I think his prop is a 54"x18" that he made.
billyvray
Aug 17, 2005
759
Newnan, GA
what does Kevin weigh, I wonder...? I think a big ol 200 pounder like me would have a big effect compared to a 150lb man.
13,386
Just to add some semi objective information to this debate, I've attached the Mil Spec guide to installing a 2A042. From a quick look, it seems that there are guidelines for the moment of inertia of anything you're going to bolt on it directly. Plus there is some history with airboats, and there's been at least one ultralight. So I think it might not be quite as problematic as some potential installations. The specs say "Maximum horsepower at 3600 rpm" is 16.7, so things may not be quite as bad as they seem. They also say "maximum elevation for rated power" of 5,000 feet. And a maximum operating temperature of 120 F. So I'm thinking that means you can get at least the 10 hp under the implied hot and high condition. It's a questionable assumption, but if we assume that denser air means a corresponding increase in power, then that gets us up to 13 horsepower on a standard day at sea level. If we're fortunate, and that also applies to the 16.7 hp, we're up to 21.8 hp! Rumor has it that there's a restrictor plate in there, too. Recommended rpm goes up to 4,000, so perhaps when that restrictor plate is removed...View attachment 74726 I wonder how much that cooling fan uses up?
What I haven't been able to find anyplace is what a 2A042 weighs when you strip off all that junk it doesn't need in order to fly. Apparently it weighs 150 lbs with all the junk. Seems to me that's the most critical factor. And I'm a bit pessimistic.
I don’t know about the 042, but in post #6, Aerowerx says the 084 weighs in at 120 lbs ready to fly.
lr27
Nov 3, 2007
3,822
Out of curiousity, I checked out the 2A042 Yahoo group and found a couple of posts indicating someplace between 70 and 80 lbs stripped, depending on how far you take it. Not sure how much, if any of that was flywheel. Oil pan is supposed to be heavy.
