flywheel1935
See Mike Patey, he's tested his BRS on "Scrappy"
But then he can afford too.
Calling Muller's deeply flawed aircraft a "research version" is a bit silly. That implies there has been a disciplined and documented effort to establish flight capability baselines, investigation into aerodynamic and propulsion characteristics, and methodical exploration of system improvements in an effort to optimize the aircraft and meet the performance goals claimed at its introduction to the public. What has taken place up to now is the complete opposite of these basic tenets of research.Right. He can do whatever is needed for this research version. He may only want to get a bit more cooling to get to the cooler altitudes. Nobody knows what the testing goals are. It may be limited to winter flights only.
The builder still needs to apply due diligence and an understanding of the load paths and balance of the aircraft. I don't want to brake forum rules, but we're still talking about PM, right? There has been a notable accident with a WT-9 in Germany, where the chute has pulled the airframe apart and the pilot has fallen without chute with one half of the airframe, and the flight instructor came down with the rest of the aircraft. Investigation showed that the chute had almost just rescued the engine and propeller, but not the rest of the airframe: https://www.bfu-web.de/DE/Publikationen/Untersuchungsberichte/2002/Bericht_02_3X046-0.pdf?__blob=publicationFile[...]
The builder in question didn't design or sew it himself, so you treat it like a seat belt. Buy one good enough, install per directions, strictly, carefully, and hope you never need it.
You don't need to test the whole aircraft, but you should at least test the structure that needs to be penetrated. There have been accidents where the chute has been damaged by sharp edges of carbon structures and those where the rocket could not penetrate the structure, rendering the chute useless. These test can be made with a mockup of the structure, though.Testing a whole airframe chute is highly likely to destroy the craft, even if everything works perfectly. The odds of personal injury are very high. So that's pretty much the Final flight test of a prototype, after everything else is fixed.
Well, yeah. Many of us would choose a big turbocharged Lycoming as is already applied in pressurized birds for this application.Additional cooling adds weight. What's the solution?
I say air cooling.
He said he doesn't want big cooling changes with this one. His test program and business goals remains a mystery, but he did say he might redo it with flaps. So it might stay in research for a long time.The point of my previous post is that while PM is scheming out little changes in cooling, the Raptor really must have BIG changes so that it can be test flown at anything resembling its capabilities
Re: whole airframe parachute testing.
You go on faith it works and preflight with the manual in hand.
There's a reason in pre-critter-safety days they used animals in ejection seat development. The film I really want to see is how they strapped a Bear into a seat. Did they strap it in, then install the seat w/Bear? Or hoisted the Bear up into the plane and strapped him in? What tranquilizers? Custom jock straps for ground crew?![]()
Fixed that for you.He’s conserving a prototype at the expense of any useful data for a new type in my opinion.
Mike Patey is an engineer, fabricator, businessman and millionaire. He is on another level than the raptor program.See Mike Patey, he's tested his BRS on "Scrappy"
Care if I take some liberties with your words?He is on another planet than the raptor program.
The turbos are a minor issue at low altitude and low power settings currently being used. There is simply a fundamental lack of oil and coolant heat dissipation happening with the current kludged setup and as Bill pointed out, it's nowhere near being able to climb to 25,000 feet on a hot summer day at full gross, at climb power.So, from earlier discussions in the old Raptor thread, I was under the impression that "cooling" could be achieved if the engine was set up properly, in particular the turbos. No?
No, two separate issues, though they were for a time inter-related: Initially, the hot air from the intercooler was being blown onto the coolant radiator. He has since added a diverter so that the heated air from the intercooler is diverted away from the coolant rad, which helped some. But so has flying in the cool evening air.I was under the impression that "cooling" could be achieved if the engine was set up properly, in particular the turbos. No?
Yep, all this time and he's still clueless about compound turbos. I'm far from an expert, but learned a ton about the basics from the prior discussions.In the latest video, he claims that the turbo sizing does not matter because he does not need to eliminate turbo lag, and that whatever they are, they will compound. See prior discussion on this topic if you are unsure about that.
Next flight after this video was only 16 minutes. Over 5 days ago and it hasn't flown since. Can't wait to see what these substantial changes are he's talking about in the narration, but has not yet flown with.Apparently, substantial changes have been made since this flight, presumably to the cooling system.
