Officially they don’t have radar because of the designation. The do get composite feeds.
Sure, they get an anonymous 1200 code. But they get the 1200 code at some minimum altitude and require a pilot contact to identify, as far as I know. I know the transponder is not required outside of class c. The ADS-B isn't required either. I don't know if he is required to turn it on if it is installed.I bet Valdosta gets a radar feed from Moody AFB which is nearby.
If ADS-B Out is installed, running it is required.Sure, they get an anonymous 1200 code. But they get the 1200 code at some minimum altitude and require a pilot contact to identify, as far as I know. I know the transponder is not required outside of class c. The ADS-B isn't required either. I don't know if he is required to turn it on if it is installed.
You are required to run both if installed. The transponder rules are unchanged from before ADS-B.Then I think his ADS-B is calibrated and it must use GPS altitude. Or, the ADS-B may be connected to the mode c altimeter. In that case maybe he is required to run the transponder because he has ADS-B installed.
It must be installed and running for the plane to show up on flightradar.If ADS-B Out is installed, running it is required.
There are good reasons you don't "flap" canard configurations.Per the latest video flaps may be added for production.
I’d like to see the canard elevator setup you would need for flaps on the main.
He said converting the ailerons to flaperons. That would be limited flap.Per the latest video flaps may be added for production.
Same issue. Plus these designs tend to be a little lacking in aileron authority at low speeds already without asking them to do double duty.He said converting the ailerons to flaperons. That would be limited flap.
Testing flaperons with a trial and error method on a high speed canard will be dangerous beyond belief. I’m struggling to wrap my head around how this will be designed and accomplished.I'm confused why he's talking about flaps on the main wing when he still has absolutely no idea what speed the canard stalls at. For all he knows, he could be landing at 60kts. I know that's extremely unlikely but my point is that it's a huge unknown.
