Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Thread: High Temp Resin Recommendations
  1. #1
    Registered User Toobuilder's Avatar
    Join Date
    Jan 2010
    Mojave, Ca
    Posts
    4,156
    Likes (Given)
    416
    Likes (Received)
    2891
    Question High Temp Resin Recommendations
    I'm considering fabrication of an exhaust augmented duct for the cowl on the Rocket. It will be a single, flattened oval approximately 4hx8wx18l. This duct will handle all of the cooling exit air so it will see substantial volume of "warm" air, but will be augmented by raw exhaust flow (like a jet pump). I intend to line the inside with stainless foil tape, but I'm thinking a resin better suited to elevated temps than my typical West Systems would be a good idea.
    Anyone have a line on a good high temp "hobbyist" product?
  2. Likes BoKu liked this post
  3. #2
    Registered User wsimpso1's Avatar
    Join Date
    Oct 2003
    Saline Michigan
    Posts
    5,266
    Likes (Given)
    1931
    Likes (Received)
    2597
    Re: High Temp Resin Recommendations
    Vinylester resin has a Tg of about 300F. Get it from Aircraft Spruce and Specialty. Lots of homework is appropriate. While I have not used it yet, I do plan to shortly for my header tank and heat/defog stuff. Fiberglast and Aircraft Spruce & Specialty are among the sources.
    Billski's opinions expressed here are available free and may be worth the money you paid for them. Understand that they are based upon a successful combination of education and a lifetime of experience using that education, but I can not know everything about your circumstances. Your choices are yours alone, and you must be the final judge on what you do. No whining...
  4. Likes Vigilant1 liked this post
  5. #3
    Registered User
    Join Date
    Dec 2015
    Tehachapi, CA
    Posts
    346
    Likes (Given)
    54
    Likes (Received)
    456
    Quote Originally Posted by Toobuilder View Post
    While a high temp epoxy (or the Vinylester that Bill suggests) would work fine, the canard community has long built substantial parts of baffles and very close fitting cowls from the standard set of room temp. cure laminating epoxies with good results. Particularly if you're going to have flowing air between the exhaust pipes and the duct, and given that the duct is not structural, I'd have no hesitation about using room temp. laminating epoxies for this part (especially if you're going to line the inside with fiberfrax and either SS or AL tape).
    Either way should work just fine.
  6. Likes wsimpso1, Vigilant1 liked this post
  7. #4
    Registered User Victor Bravo's Avatar
    Join Date
    Jul 2014
    KWHP, Los Angeles CA, USA
    Posts
    5,404
    Likes (Given)
    1095
    Likes (Received)
    4401
    I'm pretty sure that some of the guys at Scaled will be able to let you have a cup of something that they use for higher temps. Or at least tell you where to get it.
    If you have some reason for not taking advantage of resources that may be nearby, I'd call E. V. Roberts in Los Angeles, they were one of the larger supply houses for resins which would sell to the public. I used to go pick up resin there for sailplane repair when I was hanging around the repair shops in Tehachapi. One of the technical people there might be able to offer a recommendation.
    "Everything in this book may be wrong."
    Richard Bach, Illusions
    "Common sense is so rare today, it should be reclassified as a superpower!"
    Derswede
  8. Likes BoKu liked this post
  9. #5
    Registered User BJC's Avatar
    Join Date
    Oct 2013
    97FL, Florida, USA
    Posts
    8,303
    Likes (Given)
    4625
    Likes (Received)
    5307
    Quote Originally Posted by Marc Zeitlin View Post
    Glasair Aviation used a high temperature vinyl ester resin for FWF for many years, but now uses the same resin FWF as for FWA with no adverse result.
    IIRC, most epoxy resins will adhere to VE, but VE does not reliably adhere to epoxy.
    BJC
  10. #6
    Registered User pictsidhe's Avatar
    Join Date
    Jul 2014
    North Carolina
    Posts
    5,142
    Likes (Given)
    1249
    Likes (Received)
    1266
    Cotronics makes a thin high temperature epoxy.
  11. #7
    Join Date
    Oct 2003
    Saline Michigan
    Posts
    5,266
    Likes (Given)
    1931
    Likes (Received)
    2597
    ... the canard community has long built substantial parts of baffles and very close fitting cowls from the standard set of room temp. cure laminating epoxies with good results ...
    I will not argue with success, but I wondered for a while how that could be reliable... CHT's at the temp probe will spend a lot of time near and above 400F, while the Tg for most standard epoxies is only 160-180F. I understand that the Tg will rise some when the part is exposed to higher temps, and that the head is somewhat cooler out at rocker covers, but that still seems to explain only part of it. Somewhere between rocker cover temp and core temp of the heads we must hit the limits for RT cure epoxy and require a change to higher temp resins and/or put in heat shields and/or put in insulation.
    Does anyone have any rules on what conditions require a switch to high temp resins and/or aluminum tape, stainless tape, and Fiberfrax? Empirical results are great...
    I expect that this can be particularly important near exhaust pipes or in conventional cabin heat systems where air can come off the red hot pipes...
    Billski
  12. #8
    Registered User
    Join Date
    Jan 2011
    US
    Posts
    3,083
    Likes (Given)
    1118
    Likes (Received)
    1328
    A related question: Is there a significant difference in flammability/flame spread/smoke properties of an epoxy part and a vinylester part in the case of inadvertent contact with an ignition source (headers/exhaust pipe, etc)? Maybe the MSDS info from the manufacturers of the specific resins would provide some useful information on this.
    As far as keeping the temps tolerable, I would think a radiative barrier (reflective metal tape, etc) would be a big help in reducing heat transfer to the part.
  13. #9
    Join Date
    Oct 2013
    97FL, Florida, USA
    Posts
    8,303
    Likes (Given)
    4625
    Likes (Received)
    5307
    There are VE formulations that will not sustain combustion. The more common will burn.
    BJC
  14. Likes Vigilant1 liked this post
  15. #10
    Moderator Topaz's Avatar
    Join Date
    Jul 2005
    Orange County, California
    Posts
    14,125
    Likes (Given)
    9094
    Likes (Received)
    5219
    Quote Originally Posted by wsimpso1 View Post
    Billski
    I don't have answers to your questions or the OP's, but it seems to me that the critical condition is on the ground, right after shut-down. Everything is still very hot, and there's no cooling airflow. Exhaust system components are usually fairly thin metal and will cool down quickly, but the engine itself is a pretty big block of metal and would do a nice job of heating everything around it, after a flight.
    "If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them." - Henry David Thoreau
    Design Project: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
    Discussion Thread for the Project: Discussion: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
  16. #11
    Join Date
    Jan 2010
    Mojave, Ca
    Posts
    4,156
    Likes (Given)
    416
    Likes (Received)
    2891
    I've measured components after a good heat soak and even at the top of the engine I didn't see much more than 200f. Not bad.
  17. Likes Topaz, wsimpso1 liked this post
  18. #12
    Join Date
    Oct 2003
    Saline Michigan
    Posts
    5,266
    Likes (Given)
    1931
    Likes (Received)
    2597
    Gougeon Brothers' stuff is always good, if pricey. Check out https://www.prosetepoxy.com/wp-conte...82_HTP-284.pdf. Tg of 300F when post cured at 140F and 275F. That may make it a bit tough to finish off in the average home shop, but maybe you have the equipment or can arrange use of an oven someplace.
    Their standard cure resins can be cured at 180F and make a Tg of 207F. We can get 180 F even here in Michigan by wrapping the assembly in black visqueen and setting it in the sun on a warm summer day. Watch a remote reading thermometer so you can open the bag if it tries to get too hot.
    Fiberglast 1110 has a Tg of only 209 F. Derakanes go from 210 to 250 F, and you can get their stuff through Aircraft Spruce & Specialty. Not having any luck finding a 300 F vinyl ester, but I know that I have seen them...
    Billski
  19. #13
    Registered User BoKu's Avatar
    Join Date
    Aug 2013
    Douglas Flat, CA
    Posts
    2,112
    Likes (Given)
    5076
    Likes (Received)
    2562
    Gougeon Brothers' stuff is always good, if pricey. Check out https://www.prosetepoxy.com/wp-conte...82_HTP-284.pdf. Tg of 300F when post cured at 140F and 275F...
    We're in the process of evaluating high-TG epoxies for a couple of projects in the works. We've considered this one, but the viscosity of 3k cP is a bit high for my taste. For a laminating resin I prefer something down around 1k cP.
    I'll post more when we've actually had a chance to work with one or more candidates.
    Bob Kuykendall
    HP-24 Kit Sailplane
    HP-24 Kit Sailplane Facebook Page
    http://www.hpaircraft.com/hp-24
    EAA Technical Counselor
    "Homebuilt aviation is not for folks
    who won't try stuff at home."
  20. #14
    Registered User
    Join Date
    Jun 2007
    Winston Salem, NC
    Posts
    12
    Likes (Given)
    76
    Likes (Received)
    3
    Hysol EA9396 is good to work with but I've always cured it at 150 F.
  21. #15
    Registered User
    Join Date
    Apr 2010
    Memphis, TN
    Posts
    10,738
    Likes (Given)
    26
    Likes (Received)
    2849
    I know you talked about the shape on another thread, but I don’t remember. Is it a complicated shape? Why not stainless for the whole thing or titanium? Soft Titanium sheet could be shaped and be pretty trick.
Similar Threads
  1. High Oil Temp Anomaly
    By Dee in forum Half VW
    Last Post: February 2nd, 2019, 06:33 AM
  2. Plasma coated Clyinder liners & a New High temp aluminum alloy
    By Bill-Higdon in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: September 4th, 2017, 08:48 PM
  3. High temp epoxy
    By Radialconversions in forum Composites
    Last Post: May 8th, 2017, 01:24 AM
  4. High Temperature Epoxy Resin
    By Radicaldude1234 in forum Composites
    Last Post: February 25th, 2016, 12:00 AM
  5. [Free] High-performance epoxy resin--VDO
    By bharding in forum For Sale / Wanted
    Last Post: June 7th, 2014, 04:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
