Likes Likes:  0
Results 1 to 8 of 8
Thread: The "Beast One": What doesn't kill you makes you stronger
  1. #1
    Registered User Scheny's Avatar
    Join Date
    Feb 2019
    Vienna, Austria
    Posts
    14
    Likes (Given)
    0
    Likes (Received)
    This is the thread where I present the concept of the "Beast One". Unlike the title, it is the goal to create an economic BD-5 alike single seat jet which on the contrary to the BD-5 won't try to actually kill you.
    The plane is not about re-inventing the wheel, nor to follow this stupid higher, faster, stronger philosophy. The only goal we have in mind is to be better! When you are bound to something as unefficient as a turbojet, the rest has to be even better to compensate. With the FLS Microjet (unchanged successor of the BD-5) and the JSX-2 there are already two competitors, but it goes without saying that there is room for improvement against a widowmaker and a flying Hershey-bar derived from a low-tech motorglider.
    Passive Safety:
    With the knowledge of carbon formula car specialists, the fuselage will be built to endure up to 30G frontal, while incorporating a 80cm composite crumplezone capable of handling impacts at almost landing speed. In addition, the fuselage is built in a way to reduce frontal collision loads by around 30% and incorporate a BRS which can be activated up to cruise speed.
    Another relevant safety factor is a static stability unknown for such small aircraft, forgiving stall characteristics and an even lower landing speed than the JSX-2.
    Aerodynamics:
    Nobody can defy physics, but you can switch to state-of-the-art. We decided against unforgiving laminar profiles in favor for profiles which are an advancement over the proven NACA 64xxx, having 23% more lift at exactly the same drag (and even more forging stall characteristics). The profiles have been developed with help from Dr. Quabeck and the quasi-elliptical wing has outstanding slow-flight qualities while still being efficient for high cruising speeds. The tail is dimensioned bigger than comparable aircraft and meets the recomendations for jet-trainers. The fuselage is built to minimize wetted area and interference drag without risking flow detachment.
    Key data:
    The plane is built around a PBS TJ-100 engine putting out 1100N of force and pushing the 380kg MTOW to between <60kt (to fulfill CS-23) and an economy cruise speed of 200kt (top speed ~300kt). It will be built aerobatic capable with an ultimate rating of 14G but normal use is restricted to 6G for engine reasons.
    More info to follow...
  2. #2
    Join Date
    Feb 2019
    Vienna, Austria
    Posts
    14
    Likes (Given)
    0
    Likes (Received)
    Re: The "Beast One": What doesn't kill you makes you stronger
    This is a comparison for required thrust over flight speed calculated using detailled 3-views of the BD-5J, the JSX-2 and the Beast One:
    Click image for larger version.
    For landing speed, it even outperforms the JSX-2, while having good economy up to 230kt. The sweet spots have been set to 120kt for best endurance and 200-220kt for maximum range.
  3. #3
    Registered User
    Join Date
    Sep 2009
    Melbourne, Australia
    Posts
    109
    Likes (Given)
    8
    Likes (Received)
    39
    Why do people fall into the trap of making sweeping and outrageous definitive claims about a paper aeroplane? Some of the numbers here are on the border of credibility with no means of independent sniff testing. Is this project Raptor 2.0...?
    Aren't things supposed to get better as the version number climbs?
  4. #4
    Moderator Topaz's Avatar
    Join Date
    Jul 2005
    Posts
    14,125
    Likes (Given)
    9094
    Likes (Received)
    5219
    Quote Originally Posted by Andy_RR View Post
    I don't mind high goals and claims, but we really do need more information before anyone can judge the credibility of this project. Hopefully that will be forthcoming soon.
    Scheny, would you mind sharing more of the project, and how your performance numbers were derived? Are these aspirational, or have they been affirmed by analysis? If so, would you mind showing us some of the basics of that work? I'm sure the members would like to know more.
    "If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them." - Henry David Thoreau
    Design Project: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
    Discussion Thread for the Project: Discussion: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
  5. #5
    Join Date
    Feb 2019
    Vienna, Austria
    Posts
    14
    Likes (Given)
    0
    Likes (Received)
    Actually, if you check the comparison I stated the conservative numbers and not the optimistic values from the comparison. Basically I do not pretend to have much better values than the JSX while our wing was reviewed by two independent aerodynamic specialists and both have been impressed it didn't originate from a big factory (and roughly confirmed the predicted numbers).
    Compared to Raptor there is one big difference. I rely on the expertise of my team and I am not ashamed of taking their advice. This is why the tail has already been modified twice and why I asked in this forum for advice on the fuel tank system. While I am the key person driving this project, there is the continuous support of two aerodynamicists, two carbon chassis experts and one testpilot, so I can assure you it is not a castle in the sky.
  6. #6
    Registered User Victor Bravo's Avatar
    Join Date
    Jul 2014
    Posts
    5,404
    Likes (Given)
    1095
    Likes (Received)
    4402
    I think it's safe to say we're all waiting for the digital rendering of this machine that provides a visual image of what you are proposing.
    One of the OP's posts mentioned detailed 3-views, but I cannot find any of those 3-views in this thread.
    Is this aircraft concept being presented here in the "pre-3-view" stage? That is not automatically a negative, many of us have proposed discussions for concepts that have not progressed to the 3-view stage. I have recently psoposed such a concept myself.
    "Everything in this book may be wrong."
    Richard Bach, Illusions
    "Common sense is so rare today, it should be reclassified as a superpower!"
    Derswede
  7. #7
    Registered User
    Join Date
    Sep 2009
    Posts
    109
    Likes (Given)
    8
    Likes (Received)
    39
    Trust me, I'm all for pushing the limits of what's possible but if you post a bunch of huge claims backed only with a graph that has no visible ordinate axis, I'm calling bullsh´t until proven otherwise.
  8. #8
    Join Date
    Feb 2019
    Vienna, Austria
    Posts
    14
    Likes (Given)
    0
    Likes (Received)
    Quote Originally Posted by Victor Bravo View Post
    You see it in my avatar. I hope you don't mind I don't want to include a full resolution yet.
    Quote Originally Posted by Topaz View Post
    We started independently in two groups with students doing a concept study and constraint analysis and me, doing concept study for one potential customer. After the student project finished, we joined forces and now it is "my" child, but with support from many capable people.
    My approach has been:
    .) Configuration Selection
    .) detailed requirements study
    .) mission definition
    .) comparison to competitors
    .) Conceptual Design
    .) Powerplant --> only PBS was left
    .) Initial sizing (came from constraint analysis --> turned out complete bull**** for our mission)
    .) First sketches
    .) Preliminary Design
    .) Profile selection --> we decided against critical ones and for a mixture between low landing speed, efficient cruise and aerobatics possible
    .) Aerodynamics (wing) --> VLM2
    .) Aerodynamics (non-wing) --> turned out to be similar to Arnolds concept for the AR-6
    .) Weight --> detailed list for every single part to be used, fuselage based on input from chassis experts
    .) Regulations (CS-23 compatible)
    .) Cost estimation for first prototype
    .) Comparison to BD-5 and JSX-2 --> VLM2 simulation + CFD for cruise condition to roughly validate VLM2
    .) Configuration Development
    .) Ergonomics --> mockup tbd next, some tests with coarse foamplates mockup done successfully
    .) Avionics chosen
    .) Systems --> configuration almost done
    .) To continue here...
    As you see, there is a lot going on in the background. I would not call the rendering in my avatar a final solution yet
Similar Threads
  1. Replies: 8
    Last Post: January 24th, 2017, 06:54 PM
  2. Replies: 4
    Last Post: March 25th, 2015, 07:12 AM
  3. Variable effective spring rate torsional vibration "attenuator" - or "absorber"?
    By Autodidact in forum General Auto Conversion Discussion
    Last Post: June 20th, 2013, 01:19 PM
  4. Flying Wing with "Diffuser Tips" AKA "Weltensegler Crank" AKA "Stromburg Wing"
    By danmoser in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: November 11th, 2011, 12:51 PM
  5. Replies: 7
    Last Post: November 21st, 2008, 01:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
