Likes Likes:  0
Results 1 to 7 of 7
Thread: Oil pan for O-320/360 equivalent without any air induction?
  1. #1
    Registered User
    Join Date
    May 2014
    california, USA
    Posts
    125
    Likes (Given)
    129
    Likes (Received)
    63
    Does anyone know a source for such a thing?
    I'm considering cutting off the intake portions of an IO 360 sump.
    Thanks.
    Click image for larger version.
Name:	io360 sump 1.jpg
  2. #2
    Registered User
    Join Date
    Apr 2010
    Posts
    10,747
    Likes (Given)
    26
    Likes (Received)
    2854
    Re: Oil pan for O-320/360 equivalent without any air induction?
    There are a couple of companies that make them. Google cold air intake Lycoming
  3. #3
    Registered User
    Join Date
    May 2014
    california, USA
    Posts
    125
    Likes (Given)
    129
    Likes (Received)
    63
    TFF,
    Thanks, but I already did that. I want just a pan. I can't tell from photos, but the Titan cold air sump might have the air parts bolted on.
  4. #4
    Registered User
    Join Date
    Apr 2010
    Posts
    10,747
    Likes (Given)
    26
    Likes (Received)
    2854
    Sky Dynamics has a separate pan.
  5. #5
    Registered User Toobuilder's Avatar
    Join Date
    Jan 2010
    Mojave, Ca
    Posts
    4,158
    Likes (Given)
    416
    Likes (Received)
    2894
    You could also make one pretty easily. I drew up the pan rail in CAD and had one cut out of 6061 plate with a water jet. Simple matter to add the sides, bottom and oil pickup.
  6. #6
    Join Date
    Jan 2010
    Mojave, Ca
    Posts
    4,158
    Likes (Given)
    416
    Likes (Received)
    2894
    Here is the one I made. Still have to finish welding, but you get the idea:
  7. #7
    Registered User
    Join Date
    Apr 2010
    Posts
    10,747
    Likes (Given)
    26
    Likes (Received)
    2854
    Trace a gasket on some 1/4 al plate, cut out, box it out, add oil pick up. Fly. Looks good Toobuilder.
Similar Threads
  1. IO-540 Induction Air
    By Flyhighdave in forum Firewall Forward / Props / Fuel system
    Last Post: September 6th, 2016, 03:22 AM
  2. 4 Stroke Induction Tuning
    By Toobuilder in forum Firewall Forward / Props / Fuel system
    Last Post: July 6th, 2016, 08:21 PM
  3. NACA 23015 or equivalent
    By BDD in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: November 13th, 2015, 02:27 PM
  4. NACA 65-215-415 vs Ribblett equivalent?
    By Will Aldridge in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: May 29th, 2011, 07:33 PM
  5. Intro Induction ;)
    By cbird in forum New Member Introductions
    Last Post: September 9th, 2007, 09:42 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
