Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Thread: Folding wings without disconnecting controls?
  1. #1
    Registered User cluttonfred's Avatar
    Join Date
    Feb 2010
    Posts
    6,211
    Likes (Given)
    1925
    Likes (Received)
    2155
    Does anyone have any nice photos or clear drawings of wing folding systems that avoid having to disconnect/reconnect flight controls? No, I don't mean eliminating ailerons or flaps, I mean folding wings without having to disconnect/reconnect the controls to the ailerons and flaps.
    Click image for larger version.
    Source: https://aviation.stackexchange.com/q...w-does-it-work
    I have seen drawings of systems like the one above on sailplanes, but they seemed pretty elaborate. I would be particularly interested in simple solutions, perhaps something a basic as cables that go slack when the wing is folded but are taught once the wing is back in place.
    Cheers,
    Matthew
    Matthew Long, Editor
    cluttonfred.info
    A site for builders, owners and fans of Eric Clutton's FRED and other safe, simple, affordable homebuilt aircraft
    « Voici ce que j'ai fait...vous pouvez en faire autant! »
    "This is what I have done...you can do the same!"
    --Henri Mignet (1893-1965)
  2. #2
    Registered User Tiger Tim's Avatar
    Join Date
    Apr 2013
    Posts
    2,589
    Likes (Given)
    1381
    Likes (Received)
    1451
    Re: Folding wings without disconnecting controls?
    Possible sources to check out for wings folding back: Avid Flyer or pretty well anything strut braced, fabric covered and English.
    Wings folding up: WWII carrier planes expose the guts of how it all works when the wings are folded, lots of pictures online.
    The gold standard of head scratchers: figure out how the controls automatically do their thing on a Grumman Sto-Wing.
  3. #3
    Registered User Hot Wings's Avatar
    Join Date
    Nov 2009
    Posts
    5,700
    Likes (Given)
    308
    Likes (Received)
    1858
    Quote Originally Posted by cluttonfred View Post
    Matthew
    They do look elaborate but in reality they aren't too hard do design/build with modern CAD/CAM. Making all of the little bits by hand is a chore. The only problem I see with this method is that one of the parts ends up with the connecting arms exposed and subject to damage from ground handling when seperated.
    We have had some rather comprehensive threads here on HBA on this subject but with our search function broken, history is not available.
    2 simple options, both with their own problems:
    Teleflex cables.
    Fold like the Onex.
    As Autoreply noted, when he still posted, slop in the control system can lead to flutter.
    Conventional wisdom and practices yield conventional results. If that is good enough for you:
    Problem solved.
    "--and pompous fools drive me up the wall. Ordinary fools are all right; you can talk to them, and try to help them out."
    Richard P. Feynman
    Industrial engine electronic management project
  4. Likes BoKu liked this post
  5. #4
    Registered User Toobuilder's Avatar
    Join Date
    Jan 2010
    Mojave, Ca
    Posts
    4,160
    Likes (Given)
    416
    Likes (Received)
    2894
    There was a version of the Nesmith Cougar with folding wings. IIRC, it did not disconnect the flaps/ailerons when folded.
  6. #5
    Registered User
    Join Date
    Nov 2012
    Marshall, MN
    Posts
    58
    Likes (Given)
    6
    Likes (Received)
    54
    Quote Originally Posted by Tiger Tim View Post
    Sonex Onex system is similar to the Grumman system. They both have paddles on each section of wing that pivot on concentric shafts when the wings are unfolded.
  7. #6
    Registered User
    Join Date
    Jun 2014
    Arusha
    Posts
    55
    Likes (Given)
    12
    Likes (Received)
    14
    Take a look at the DH60 Moth, the aileron cable routing from the underside of the fuselage to the inboard rib goes slightly forward, entering the wing just ahead of the rear spar root fitting. When the wing is folded the entry to the wing moves back and out so the tension is almost unchanged.
  8. #7
    Registered User Victor Bravo's Avatar
    Join Date
    Jul 2014
    Posts
    5,419
    Likes (Given)
    1100
    Likes (Received)
    4405
    Avid Flyer, as mentioned previously.
    I have owned two sailplanes with the automatic system shown in the OP drawings, and it worked perfectly through hundreds of assembly-disassembly cycles. It even has an adjustment to tighten up the tolerance to address wear in the little roller bearings.
    Why does Autoreply not post here anymore? Did he get PO'd at something or someone? Did he get transferred to living on a remote island without internet access?
    "Everything in this book may be wrong."
    Richard Bach, Illusions
    "Common sense is so rare today, it should be reclassified as a superpower!"
    Derswede
  9. #8
    Registered User BJC's Avatar
    Join Date
    Oct 2013
    Posts
    8,317
    Likes (Given)
    4630
    Likes (Received)
    5311
    I don’t have any photos of mine, but the Sportsman 2+2 folds without having to disconnect any of the the fuel, pitot, wiring, flaps or aileron cables.
    See https://m.youtube.com/watch?v=fLjuZ_5XoBk
  10. #9
    Registered User Daleandee's Avatar
    Join Date
    Sep 2015
    SC
    Posts
    779
    Likes (Given)
    122
    Likes (Received)
    483
    https://flywithspa.com/more-on-panther-wing-fold/
    Dale
    N319WF
  11. Likes mcrae0104 liked this post
  12. #10
    Registered User
    Join Date
    Mar 2016
    Austria
    Posts
    259
    Likes (Given)
    21
    Likes (Received)
    72
    The standard automatic connectors on Sailplanes were originally developed by Eugen Hänle (Glasflügel) and are thus called Hänle Tüten in German.
    Also have a look at the Stemme S10 folding mechanism. Looks quite reasonable to me.
  13. Likes BoKu liked this post
  14. #11
    Join Date
    Oct 2013
    Posts
    8,317
    Likes (Given)
    4630
    Likes (Received)
    5311
    Quote Originally Posted by ypsilon View Post
    What is a typical Vne for a high performance sailplane with automatic control connections? (BoKu’s, on the HP-24, look very robust.)
  15. Likes BoKu liked this post
  16. #12
    Registered User Himat's Avatar
    Join Date
    May 2011
    Norway
    Posts
    2,737
    Likes (Given)
    1710
    Likes (Received)
    636
    Quote Originally Posted by Victor Bravo View Post
    Could be he got a full time day job, wife and kids. At least that would be my guess.
  17. #13
    Join Date
    Nov 2009
    Posts
    5,700
    Likes (Given)
    308
    Likes (Received)
    1858
    Quote Originally Posted by Himat View Post
    "Life" happens to all of us at one time or another. For most of us, no matter how much we like the hobby, if it isn't part of our day job it's really pretty far down the list of things that need to be done.
    Problem solved.
    Richard P. Feynman
  18. Likes Topaz liked this post
  19. #14
    Registered User
    Join Date
    Mar 2016
    Austria
    Posts
    259
    Likes (Given)
    21
    Likes (Received)
    72
    Quote Originally Posted by BJC View Post
    250-290 km/h
  20. Likes BJC, BoKu liked this post
  21. #15
    Registered User
    Join Date
    Apr 2011
    Utah
    Posts
    191
    Likes (Given)
    9
    Likes (Received)
    73
    I like this page for Sto-Wing pictures: http://thanlont.blogspot.com/2011/03...ing-redux.html
    Been leaning toward the cables running on the axis or rotation method as fairly simple. Would be tricky to get both aileron and flaps in the limited space.
Similar Threads
  1. Boeing 777-9x will have folding wings
    By saini flyer in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: September 8th, 2015, 01:56 PM
  2. Folding Wings
    By ekimneirbo in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: March 19th, 2015, 12:31 AM
  3. Folding Wings
    By ekimneirbo in forum Tube and Fabric
    Last Post: September 25th, 2008, 02:40 PM
  4. Plane with folding wings
    By GrantR in forum For Sale / Wanted
    Last Post: August 30th, 2007, 08:52 AM
  5. Folding Wings on VP
    By Chris m in forum General Experimental Aviation Questions
    Last Post: May 16th, 2005, 10:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
