Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Thread: Question (from a noob non-pilot): What's up with all the ...
  1. #1
    Registered User
    Join Date
    Aug 2015
    Santa Clara, UT
    Posts
    29
    Likes (Given)
    38
    Likes (Received)
    5
    What's up with all the appearance and disappearance of V-tails when looking at the history of sailplanes?
    Do V-tails pose more drag in actual use than T-tail, Cruciform-tail, or Conventional-tail sailplanes? I would think in many circumstances you would be causing more drag to create force vectors with opposing components to cancel - through a necessarily stronger and heavier tail assembly.
    Although, there should be less total area to get the same set of forces, and with modern construction the tail isn't going to be substantially heavier.
  2. #2
    Moderator Dana's Avatar
    Join Date
    Apr 2007
    Posts
    8,561
    Likes (Given)
    452
    Likes (Received)
    2847
    Re: Question (from a noob non-pilot): What's up with all the ...
    The theoretical advantages of V-tails don't really pan out in the real world, not enough to be worth the added complexity of the control mixer and the structural disadvantage of not being able to have a straight stabilizer spar right across the fuselage.
    Hatz CB-1 Biplane
    Starduster SA-100 rebuild project for sale
    Fisher FP-404 (sold)
    ParaFan PPG (dormant project)
    Kolb Ultrastar (sold)
  3. Likes Victor Bravo, copec, BoKu liked this post
  4. #3
    Registered User BBerson's Avatar
    Join Date
    Dec 2007
    Posts
    10,706
    Likes (Given)
    1621
    Likes (Received)
    1900
    Gliders tip over to the side after stopping. The V tail avoids ground strikes on the tail tips. Same with T-tail.
  5. Likes copec, BoKu liked this post
  6. #4
    Registered User Victor Bravo's Avatar
    Join Date
    Jul 2014
    Posts
    5,404
    Likes (Given)
    1095
    Likes (Received)
    4401
    With respect to BBerson, Dana's answer above is the more correct. There are plenty of "regular" low cruciform tailed gliders that tip over on a wing and don't damage the tail. Everything from training gliders (SGS 2-33, LET L-13 Blanik ) to club and sport gliders (SGS 1-26, 1-34, Schleicher Ka-6) to Open Class competition sailplanes (Schleicher AS-W17, SZD-42 Jantar)
    "Everything in this book may be wrong."
    Richard Bach, Illusions
    "Common sense is so rare today, it should be reclassified as a superpower!"
    Derswede
  7. Likes copec, BoKu liked this post
  8. #5
    Join Date
    Dec 2007
    Posts
    10,706
    Likes (Given)
    1621
    Likes (Received)
    1900
    The Blanik actually has "dihedral" in the tail to avoid hitting the brush. A V tail allows an even smaller tail boom end. Nothing to do with Dana's aero comment. https://commons.m.wikimedia.org/wiki...8C)_RP5676.jpg
  9. Likes copec liked this post
  10. #6
    Registered User
    Join Date
    Sep 2014
    Canada
    Posts
    1,049
    Likes (Given)
    7
    Likes (Received)
    287
    V tails have 2/3 the interference drag where they join the fuselage. They also only need 2/3 as many parts. Please note that V tails still need the same surface area (tail volume) as conventional tails.The disadvantage is they stability and control are not quite as good as conventional tails.
  11. Likes copec liked this post
  12. #7
    Registered User Dan Thomas's Avatar
    Join Date
    Sep 2008
    Posts
    4,656
    Likes (Given)
    207
    Likes (Received)
    1935
    On powered airplanes, V-tails came and went away. T-tails came and went away. On sailplanes, I've seen V's and T's and dihedraled stabilizers and straight stabilizers, and to me the ground-clearance thing is a minor reason. If a straight stab is atop the fuselage, with that long wing preventing any significant bank angle when the wingtip hits the ground, the stab tips are well clear.
    I used to tow gliders in the 1970s.
    The tail configuration is, IMHO, nothing more than style. Fashion. Plenty of reasons are put forth at the time of introduction to support it, but the marketers are careful to keep quiet about the drawbacks of their designs. V-tails, with their larger surfaces and heavy structure within the fuselage to take the cantilevered loads, can weigh more, they're more complex to build, and they do tend to wag around in turbulence. Their control systems are somewhat more complicated. Take a look at the inside of a Bonanza V-35 sometime when the tailcone fairing is off. More parts and weight. The T-tail (or cruciform, as on the Rockwell Commanders) requires a considerably heavier vertical fin and mounting structure because it has to take the horizontal stabilizer's loads, and those loads are through attach points that are very close together so they have to be heavier. The rotating propeller slipstream also tries to rotate that stab,as it does in most airplanes, and the rotation has to be resisted thorugh that narrow mounting. The Commanders have cracking issues at the vertical stab rib at the HS forward attachment. The Lake Amphibian has had horizontal stab failures at the aft spar attach at the fin and there's an expensive AD against it.
    Fashion is more important than function when it comes to selling airplanes, exactly as it does with cars. The best vehicles often tend to be the plainest, strongest, simplest and lightest. And homely. Buyers are motivated more by style and fancy paint than by any practicalities. I see this when I get to work on some old airplane that's had a nice new paint job and maybe new seat upholstery. The buyer sees the paint but misses the corrosion and cracks and worn-out expensive stuff. When I was young, secondhand car dealers were famous for taking rusting and tired cars, painting them, and selling for massive profit. It works, because fashion sells.
  13. #8
    Registered User
    Join Date
    Aug 2015
    Santa Clara, UT
    Posts
    29
    Likes (Given)
    38
    Likes (Received)
    5
    ^I kind of figured as much. Thanks for the perspective!
  14. #9
    Join Date
    Jul 2014
    Posts
    5,404
    Likes (Given)
    1095
    Likes (Received)
    4401
    If there was not a measurable advantage of a T tail, I can guarantee you that the European sailplane designers and manufacturers would not use them. They weigh more, cost more, and take longer to build. The people whose financial and personal success depends entirely on performance and drag are all using the T tail.
    Derswede
  15. Likes BoKu, copec liked this post
  16. #10
    Registered User BoKu's Avatar
    Join Date
    Aug 2013
    Douglas Flat, CA
    Posts
    2,112
    Likes (Given)
    5076
    Likes (Received)
    2562
    Quote Originally Posted by Victor Bravo View Post
    Apologies if this sermon is a repeat.
    As others have observed, V-tails and conventional orthogonal tails are pretty much neck and neck in terms of stabilizing effectiveness per unit wetted area and per unit mass. However, there is definitely a real and measurable advantage to the T-tail in sailplanes: Packaging.
    The European sailplane designers behind the composite revolution of the 1960s (Waibel, Wilks, Lemke, Holighaus, et al) understood that to improve soaring flight performance, the thing to optimize is not the absolute performance of the machine, but rather the overall performance of the pilot, and the machine, and its support infrastructure, as a system. And the easiest metric by which to do that is the enjoyment of the soaring experience. And the easiest way to assess that metric is whether or not they write you a check. Because unlike many other velocity sports, the person in the pilot's seat of a sailplane is almost always the one writing the checks, not the one cashing them.
    Anyhow, back to tails. The designers listed above all understood that a T-tail with a removable one-piece horizontal tailplane offered, at only a modest increase in mass and complexity, a substantially superior packaging solution over any other tail configuration. Because the stabilizer is one piece, the moment reaction between the right and left halves is built in, so the mounting system only has to accommodate relatively light loads. And when you remove the tailplane, it is essentially planar and easy to handle and find stowage space for. And its location at the top of the stabilizer makes it easy to position and easy to inspect; it is right there at eye level, no kneeling or stooping required.
    With the V-tail, however, one-piece tails are much more problematic. They occupy substantial volume, and are hard to handle and hard to make space for. So far as I know, Spud Kohler is the only glider guy to try it. Instead, most designers adopt a two-piece tail with a moment reaction joint at or near the middle. You have to design those joints and their related mechanisms carefully.
    Dick Schreder designed his V-tails to fold by pivoting the stabilizer around the forward attach and the upper aft attach, with a spring-loaded taper pin at the lower aft attach. Schreder's approach was a marvel of industrial engineering and effective compromises therein. Primarily it had low unique parts count and was easy to fabricate and assemble, which was critical to his model in which the parts were made by apprentices and high school kids and assembled in garages by kit builders. Trivia point: The skins for the Schreder ruddervators take exactly one third of a 4'x12' sheet of aluminum, and when properly cut exactly to the template scribe lines the wastage from that sheet is a strip of aluminum 3/8" x 48"-- 0.8% waste. However, Schreder tails joints tend to get loose with age, and you have to be careful when folding and deploying them.
    The Austria takes a different approach to the V-tail; the fuselage has two tubular steel stubs that stick up out of the aft fuselage, and you slide the stabilizers down over the stubs. With this arrangement, you have two stabilizers to handle and stow, and you also have bruises on your shins and calves from walking into the steel stubs.
    Going off-topic, one of the the best testaments to the effectiveness of the composite revolution is the movie The Sun Ship Game, filmed at the 1969 US Nationals in Marfa Texas. The film features many V-tailed gliders, but all as backmarkers or in supporting roles. Three years prior, Dick Schreder had stood on the podium at the Reno nationals and was recognized as the US national champion soaring pilot, having won that contest in an aluminum V-tailed sailplane that he designed himself and built in his own workshop. But a mere three years later, film coverage of the Marfa nationals concentrated on Moffatt, Scott, and Derujinsky, and their molded composite sailplanes. Schreder received only about a dozen frames worth of coverage, and most of that coverage was because he happened to be sitting behind Suzanne Moffatt at the awards ceremony. In those intervening three years, it became fully recognized that the complementary technologies of composite construction and highly laminar shapes pretty much made all other sailplanes obsolete.
    --Bob K.
    Bob Kuykendall
    HP-24 Kit Sailplane
    HP-24 Kit Sailplane Facebook Page
    http://www.hpaircraft.com/hp-24
    EAA Technical Counselor
    "Homebuilt aviation is not for folks
    who won't try stuff at home."
  17. #11
    Join Date
    Jul 2014
    Posts
    5,404
    Likes (Given)
    1095
    Likes (Received)
    4401
    Well, I have it on eyewitness account from one of the major contestants in that era that Suzanne was considered "quite a honey" in the soaring world, and the cameras liked to look at her as much as everyone else did.
    Derswede
  18. Likes BoKu, copec liked this post
  19. #12
    Registered User
    Join Date
    Nov 2007
    Posts
    3,160
    Likes (Given)
    34
    Likes (Received)
    435
    Anything wrong with the way they do it on the Ka-8?
  20. Likes copec liked this post
  21. #13
    Join Date
    Jul 2014
    Posts
    5,404
    Likes (Given)
    1095
    Likes (Received)
    4401
    Quote Originally Posted by lr27 View Post
    Slightly higher drag due to more intersection drag.
    Stabilizer partly "blanked" or made less effective by being in the fuselage boundary layer... needs to be slightly larger than it would be if mounted in "clean" airflow.
    Stabilizer flow, drag, and efficiency affected by wing root and fuselage flow separation or turbulence at higher angle of attack.
    These small negative factors were considered acceptable for a medium performance glider, when balanced against the advantages of lower cost, weight and structural requirements for the low tail, especially in the era of the Ka-6 and Ka-8.
    Derswede
  22. Likes copec liked this post
  23. #14
    Registered User
    Join Date
    Aug 2015
    Santa Clara, UT
    Posts
    29
    Likes (Given)
    38
    Likes (Received)
    5
    I really like V-tails and it is probably because it is pleasing how they look to me.
    However, I enjoy hearing the actual reasoned engineering. If a T-tail is well understood and seems to offer the least drag with the best control - as well as breakdown, storage and transportability - it makes sense why it became the predominant tail.
  24. Likes BoKu liked this post
  25. #15
    Join Date
    Jul 2014
    Posts
    5,404
    Likes (Given)
    1095
    Likes (Received)
    4401
    Thread drift off into the margins, but BTW powered aircraft are a different story in many cases. Powered aircraft manufacturers (primarily Piper) experimented with T-tails in the 1980's, and after a few years the tails moved back down to the fuselage where they were before. The balance between advantage and disadvantage was simply not favoring the T-tail for the type of flying that these airplanes do.
    A friend of mine owns a Piper Lance (the biggest member of the single engine Cherokee family) and he explained that having the tail down inside the propeller blast allows him to do much more with the aircraft in terms of low speed control during takeoff and landing. Much more "control power" available. This is particularly important on aircraft with a wide range of CG, because many powerplanes are hopelessly nose-heavy when flown solo. Having the ability to hold the nose up using prop blast makes a significant difference in operating these aircraft.
    All of this is irrelevant of course to sailplanes.
    Derswede
  26. Likes BoKu, copec, Pops liked this post
Similar Threads
  1. Another dumb noob question...
    By Thunderchook in forum Workshop Tips and Secrets / Tools
    Last Post: December 22nd, 2016, 07:32 PM
  2. Silly question: sizing Pilot CAD objects
    By rtfm in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: October 28th, 2015, 11:56 PM
  3. Noob experimental question
    By Holtzy3 in forum Hangar Flying
    Last Post: June 6th, 2014, 10:18 AM
  4. Hypothetical Question: Pilot at CG??
    By Aerowerx in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: December 6th, 2013, 10:40 PM
  5. Another noob ;^)
    By jlknolla in forum New Member Introductions
    Last Post: November 29th, 2010, 05:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
