Page 1 of 81 1 2 3 4 5 6 7 11 51 ... LastLast
Results 1 to 15 of 1209
Thread: What did you do on your airplane project today?
  1. #1
    Registered User
    Join Date
    May 2015
    Iowa
    Posts
    348
    Likes (Given)
    325
    Likes (Received)
    391
    Or recently.
    A little threat to share the latest step no matter how big or small you took on your project.
    I will go first, was a few days ago as I was out of town this weekend but I took the second side of the fuselage out of the jig and pulled the jig up. I then rolled out some more paper on the build table (I got a roll of paper from a hobby store) and marked out the vertical fin and rudder. I ordered hinges and the wood needed. the hinges showed up but waiting on wood. I also cleaned the work area to prepare for the next step.
    again share your work no matter if all you did was clean up a little or if you built a whole wing in one sitting.
  2. #2
    Registered User wsimpso1's Avatar
    Join Date
    Oct 2003
    Posts
    5,266
    Likes (Given)
    1931
    Likes (Received)
    2597
    Re: What did you do on your airplane project today?
    I have been building the top support for the rudder system. This part is V shaped, 13" wide, 16" long. The wide end will attach to the seatback bulkhead, the narrow end will be have a bolt hole to support one side of a bellcrank. I had built a tool on my vacuum bagging table out of a plastic wedge and blue foam and packing tape on Friday. Saturday I went and watched the Wolverines win a ball game at The Big House (Let's Go Blue!), with attendant tailgating beforehand and fuss afterwards.
    Today I waxed the tool, cut the Triax and Biax glass cloth, the green PVC foam cores, UNI tape, peel ply, perforated film, bleeder plies, and bag film, laid out the shapes for each of the plies of glass cloth, then laid up the part and sealed the bag. It has been under vacuum since 12:30 pm. The sealant tape covers an area about 18" by 26". Pictures show the tool and two shots of the part curing under vacuum. I shall follow up with pictures of the completed part. in a day or so.
    Click image for larger version.
ID:	65749Click image for larger version.
ID:	65752Click image for larger version.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	65748   Click image for larger version.
ID:	65750   Click image for larger version.
    Billski's opinions expressed here are available free and may be worth the money you paid for them. Understand that they are based upon a successful combination of education and a lifetime of experience using that education, but I can not know everything about your circumstances. Your choices are yours alone, and you must be the final judge on what you do. No whining...
  3. Likes Little Scrapper, cdlwingnut liked this post
  4. #3
    Registered User stuart fields's Avatar
    Join Date
    May 2008
    Inyokern California
    Posts
    295
    Likes (Given)
    191
    Likes (Received)
    118
    I drilled and tapped a drain hole for the Sprag clutch on my Turbine engine. I also set up some welding practice pieces of aluminum. I have to fabricate an aluminum oil tank for same item. I've also set up a test piece using 3M VHB tape to see if it really will take the place of welding and screws to attach two pieces of aluminum sheet stock. I also ordered some Loctite paste adhesive LOCTITE EA 9309.3NA to test for the same idea.. I also patted the bubble on the helicopter.
  5. Likes cdlwingnut liked this post
  6. #4
    Registered User Aerowerx's Avatar
    Join Date
    Dec 2011
    Marion, Ohio
    Posts
    4,540
    Likes (Given)
    708
    Likes (Received)
    1204
    Does thinking about it count?
    ___________________________
    Optimist: The bottle is half full.
    Pessimist: The bottle is half empty.
    Engineer: The bottle has a Factor of Safety of 2.0
  7. #5
    Registered User
    Join Date
    Feb 2014
    Oneida
    Posts
    747
    Likes (Given)
    37
    Likes (Received)
    156
    Quote Originally Posted by Aerowerx View Post
    For me it is dreaming...
    Tim
  8. #6
    Registered User FritzW's Avatar
    Join Date
    Jan 2011
    Las Cruces, NM
    Posts
    2,983
    Likes (Given)
    1888
    Likes (Received)
    2623
    I worked on a friends airplane which gets me closer to getting back to work on my airplane so it counts
    I finished entering my friends paper instrument panel template in the computer and made the cutting files for it. I started to mount the panel blank to the machine but, even in mid September with the garage AC going full blast, it's too bloomin hot out there. I'll cut it on Tuesday morning
Name:	Sky Ranger Panel SW.jpg
ID:	65756 Click image for larger version.
Name:	Sky Ranger Panel CB.jpg
ID:	65757 Click image for larger version.
Name:	Sky Ranger Panel.jpg
    Iēsous Christos, Theou Yios, Sōtēr
  9. #7
    Registered User don january's Avatar
    Join Date
    Feb 2015
    Midwest
    Posts
    2,541
    Likes (Given)
    1389
    Likes (Received)
    976
    I spent a couple hours today sorting out hardware left over from my KR-2 and did some napkin design work on the Taylor-m. Plan on stopping in Fargo N.D. tomorrow and picking up some more ply for the mono. I have most the pieces cut but for the turtle deck.and have been working on a holding tank to soak and heat the pieces to ease shaping to mount to the plane.
    Taylor- Mono, PDQ.
  10. Likes cdlwingnut liked this post
  11. #8
    Registered User
    Join Date
    Apr 2010
    Posts
    10,738
    Likes (Given)
    26
    Likes (Received)
    2849
    Not for a specific project, but I bought a one of the spruce odds and ends from ACS to see what they send. Shipping is murder.
  12. #9
    Registered User proppastie's Avatar
    Join Date
    Feb 2012
    Posts
    3,316
    Likes (Given)
    1238
    Likes (Received)
    923
    Was at a very satisfying music festival in Nashville (Americanafest) for the last week. But had decided before I left that I needed to borrow (get back) the small drill press I had given to my son. He drove from Illinois and I flew from NJ for the festival. So I flew back today with the drill press for my spar fabrication.
    I finished the detail design of the seat back while there. Pretty soon I will be able to sit and make airplane noises.
  13. #10
    Registered User Little Scrapper's Avatar
    Join Date
    Jan 2014
    Wisconsin
    Posts
    5,037
    Likes (Given)
    2525
    Likes (Received)
    2983
    Wife and two boys completely cleaned the shop today for me. I was pretty thankful for that.
  14. Likes akwrencher, cdlwingnut liked this post
  15. #11
    Registered User Victor Bravo's Avatar
    Join Date
    Jul 2014
    Posts
    5,402
    Likes (Given)
    1095
    Likes (Received)
    4400
    Been installing instruments in the Kolb Firestar this past few days. Before that I did some quick and dirty composite/paint repair on the combination nose fairing and instrument panel. In between (literally while the glue was drying) I built and installed a switch panel on the side of the cockpit.
    "Everything in this book may be wrong."
    Richard Bach, Illusions
    "Common sense is so rare today, it should be reclassified as a superpower!"
    Derswede
  16. Likes cheapracer, cdlwingnut liked this post
  17. #12
    Registered User Chris In Marshfield's Avatar
    Join Date
    Jan 2008
    Germantown, WI USA
    Posts
    1,206
    Likes (Given)
    1470
    Likes (Received)
    985
    Slowly unpacking boxes since the move, tracking down and organizing my tools, fasteners, and aluminum parts. What a chore!
    Chris Owens
    Germantown, WI USA
    Project "Expedition"
    Bearhawk Plans #991
    Bearhawk Patrol Plans #P313
  18. Likes cheapracer, MadRocketScientist liked this post
  19. #13
    Registered User cheapracer's Avatar
    Join Date
    Sep 2013
    Australian
    Posts
    5,106
    Likes (Given)
    3903
    Likes (Received)
    3188
    I had a fight with a guy in a forum over Flying Flea style craft to help secure my future market when I start making them.
    Or I just like fighting in forums, I knows it's one of the 2 ...
    Quote Originally Posted by BoKu View Post
    The vast majority of engineering failures are the results of failure of imagination rather than failure of calculation.
  20. Likes Chris In Marshfield, Tiger Tim liked this post
  21. #14
    Join Date
    Feb 2012
    Posts
    3,316
    Likes (Given)
    1238
    Likes (Received)
    923
    See build log.
    Also fixed the Strike Finder on the Mooney...cleaned the contacts.
  22. #15
    Registered User mcrae0104's Avatar
    Join Date
    Oct 2009
    Colorado / USA
    Posts
    2,692
    Likes (Given)
    3152
    Likes (Received)
    1769
    In the last week, I've finished a configuration change that I've been contemplating since Oshkosh and revised the weight estimate of the new design to check that the CG will be where it belongs. Also I revised my conceptual fuselage shape for flat-wrapping. Been putting that off a long time. This week I'll be working on turning it into plans for an RC model that a friend wants to build, which should be interesting since I never have been an RC guy.
    ​simplify.
Similar Threads
  1. Homebuilt airplane project documentation
    By pilotarix in forum General Experimental Aviation Questions
    Last Post: April 4th, 2017, 08:55 PM
  2. Searching for the Right (first) airplane project
    By sscout in forum General Experimental Aviation Questions
    Last Post: August 23rd, 2015, 08:41 PM
  3. [Wanted] Experimantal airplane project
    By aircraftbuilder in forum For Sale / Wanted
    Last Post: July 20th, 2014, 10:04 AM
  4. Replies: 15
    Last Post: July 9th, 2014, 09:20 AM
  5. New airplane design - the two decade project
    By DLrocket89 in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: December 13th, 2011, 07:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
