Need help from Kitfox owners
Zoomzoooie
Feb 14, 2011
170
BC Canada
I am trying to find out the differences and measurements between Kitfox Models I - IV, aside from the published information.
- Is there a difference across the left and right wing joiner pin distance?
- Is there a difference of the frame width across the front door posts?
- Is there a difference between the doors, which ones will interchange? Would model I doors fit later models aside from the lower double angles?
- Is there a difference in frame height from the wing joiners to the bottom of the frame?
- Are the cowls from model I - III interchangable?
- Is the width and height of the cowl mounting surfaces of a model IV the same as earlier ones? In otherwords would it fit the earlier models? I know the model IV has a longer windshield angle.
- what models are the windshields interchangeable?
- Will the model IV windshield fit earlier models provide using the model IV cowl?
- Is there a difference in distance from the door forward to the prop flange?
Any any additional measurements and differences for each model would be appreciated it.
Latest posts
