Likes Likes:  0
Results 1 to 4 of 4
Thread: Tail airfoil references?
  1. #1
    Registered User
    Join Date
    May 2007
    Toms River, New Jersey
    Posts
    422
    Likes (Given)
    4
    Likes (Received)
    9
    David Lednicer's "The incomplete guide to airfoil usage." The Incomplete Guide to Airfoil Usage is a great reference for wing airfoils. Is there a similar list that shows the tail airfoils.
    I am particularly interested in tail airfoils for a fast, lightweight (sub 1400lb gross) plane capable of the +/-220mph range.
    10% chord airfoils appear to be popular, would there be any advantage to a slightly thinner section (6-8%?).
    George
  2. #2
    Registered User
    Join Date
    May 2007
    Posts
    422
    Likes (Given)
    4
    Likes (Received)
    9
    Re: Tail airfoil references?
    I'd be interested in any opinions on the tail airfoils below.
    Naca 0010-34
    Naca 0080-34
  3. #3
    Registered User Mac790's Avatar
    Join Date
    Jun 2008
    Poznan, Poland
    Posts
    1,569
    Likes (Given)
    5
    Likes (Received)
    18
    We had a discussion about tail airfoils, a few weeks ago. For my knowledge there is no "similar list" with tail airfoils. When you said thinner, I guess you thought about classical sections like NACA-0008, it might be better to try NACA 6x-xxx series like NACA 64 012 for example, it has lower Cd than NACA 0008, but in same time it's thicker, which is a very good idea from a structural point of view, not to mention, that it has max thickness at around 40% of chord, which is another advantage over NACA 4-series.
    Seb
    Amor Patriae Nostra Lex
    "Time, training, training, training and more training is the key to any success."
    Francis "Gabby" Gabreski
  4. #4
    Registered User
    Join Date
    May 2007
    Posts
    422
    Likes (Given)
    4
    Likes (Received)
    9
    The NACA 0010-64 appears to be rather similar to the NACA 0010-34 ragarding the position of max thickness around 40% anyway. The main difference appears to be the noticably sharper leading edge of the 34 series.
    Naca 0010-34
    Naca 0010-64
    George
Similar Threads
  1. Flat plate vs. airfoil shaped tail surfaces
    By BBerson in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: October 7th, 2010, 03:10 PM
  2. Suggested references for "low" Reynolds number airfoil performance?
    By Grimace in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: September 11th, 2010, 09:25 AM
  3. upside down airfoil horizontal tail and trim drag.
    By K-Rigg in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: November 23rd, 2009, 11:30 PM
  4. Optimal tail (with rudder) airfoil?
    By rtfm in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: December 10th, 2008, 11:13 PM
  5. Airfoil section comments on PS-1 airfoil on ProTech PT2C
    By prostar in forum Feedback and Suggestions
    Last Post: January 12th, 2007, 09:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
