Results 1 to 9 of 9
Thread: Volunteer Needed - FAQ thread on Amateur Built Aircraft
  1. #1
    Site Developer Jman's Avatar
    Join Date
    Oct 2002
    Pacific NW, USA!
    Posts
    2,411
    Likes (Given)
    21
    Likes (Received)
    59
    I'm looking for someone who would like to volunteer to create a thread that will be stickied to the General Experimental Aviation Questions forum. This thread will explain the basic overall process of building an experimental aircraft from the first stages of planning to the maintenance requirements of the finished aircraft. It will answer the most frequently asked questions concerning the types of construction materials, choosing the design, documenting the build, registration and inspection, test flying, and the continued maintenance of the aircraft. It is not intended to include specific how-to information but to answer basic questions that will help new builders make decisions before they start building.
    This volunteer must:
    1. Be motivated!
    2. Be very familiar with all aspects of the Amateur Built aircraft rules and regulations and be willing to put that knowledge into a clear and concise introduction to the world of experimental aviation. Writing experience would be helpful but not necessary.
    3. Preferably be a current builder or have successfully built an aircraft in the past.
    4. Be willing to maintain the thread by adding new information and considering suggestions and additions from others.
    5. Be willing to follow a set format that will be used for similar threads on different subject areas throughout the forum.
    If you would like to volunteer, please send me a private message containing your experience and any other important information I should know about you. If you have a specific skill that you feel could be used to create a thread in another part of this forum, please feel free volunteer for that too!
    If you have comments or suggestions regarding how the thread should be laid out, please post them here in this thread.
    Thanks guys!
  2. #2
    Join Date
    Oct 2002
    Pacific NW, USA!
    Posts
    2,411
    Likes (Given)
    21
    Likes (Received)
    59
    Re: Volunteer Needed - FAQ thread on Amateur Built Aircraft
    Oh, I forgot to mention if this opportunity is not the the right fit for you but you still feel like you want to help, there will be plenty of other chances in the future. Many of them will be appropriate folks of all experience levels.
  3. #3
    Join Date
    Oct 2002
    Pacific NW, USA!
    Posts
    2,411
    Likes (Given)
    21
    Likes (Received)
    59
    I moved Gary's suggestion to this thread.
  4. #4
    Join Date
    Oct 2002
    Pacific NW, USA!
    Posts
    2,411
    Likes (Given)
    21
    Likes (Received)
    59
    So far no takers but I'm holding out hope that the right individual will come along. I think this particular subject area could use a good FAQ thread.
  5. #5
    Super Moderator Midniteoyl's Avatar
    Join Date
    Sep 2003
    Indiana
    Posts
    2,497
    Likes (Given)
    1290
    Likes (Received)
    532
    Sorry Jake.. #'s 2 and 3 leave me out
    Jim
    Express 2000FT (hopeful - Again)
  6. #6
    Join Date
    Oct 2002
    Pacific NW, USA!
    Posts
    2,411
    Likes (Given)
    21
    Likes (Received)
    59
    No worries my friend, you do enough as it is!
  7. #7
    Registered User
    Join Date
    Nov 2012
    Near Chichester, UK
    Posts
    19
    Likes (Given)
    9
    Likes (Received)
    0
    Jake, that is a very responsible job.
    I have a lifelong interest in airplanes, ( am an engineer ) but I always ask the real expert if my experience is not sufficient, one can tell the real expert because he/she gives sensible numerate reasons for the answer.
    The Rules written vary from country to country - Europe is just getting it together for safety, UK joining in. Homebuilt rules vary, and change.
    Really, each area of airplanes has its own group of experts, and the more one learns, the more one realises how ignorant one is oneself, which is when one really begins to learn.
    Remarks about engineers worry me a bit - an engineer is someone whose calculations are in accordance with the results in the tests, stress, development, test flights, I think.
    But I do like ' bottom lines ', which apply to most subjects in engineering.
    In the case of airplanes, one needs to be clear on what a particular airplane is required to do, so its ceiling in adverse atmospheric pressure conditions needs to be born in mind, otherwise it won't get over that mountain.
    power - weight - reliability of engines is an on-going concern, some of the math is quite difficult, so hard for those not wired up that way to understand.
    Metallurgy is an area for pit-falls - SN curves are of serious importance.
    Welds need to be appropriately done with the correct rod, by a skilled person, if possible avoided. But checked meticulously for cracks, and NOT put in areas of the structure line where stress is a maximum.
    An understanding of what and why flutter occurs and how to avoid it is necessary, again not an easy subject.
    Partial counter-balancing of flying surfaces can be done with the anti-flutter arrangements by geometry, so they can help each other. meticulous care in planning and execution of the build which some people have a genius for is so noticeable on the airfield - or not.
    There are members who are expert at just one aspect, or whose approach is useful because it highlights pitfalls, or they have a flair for variety.
    Very few people are all-round experts, partly because engineering and piloting require a slightly different mind-set
    I know members don't like math, but it helps make the thing the right dimensions so that the test piece breaks as predicted, and the life tests as predicted - to home in on the right side by means of initial experiment is not a very sound use of time.
    Allan
  8. #8
    Registered User bmcj's Avatar
    Join Date
    Apr 2007
    Posts
    11,371
    Likes (Given)
    5997
    Likes (Received)
    3798
    Seems like Danielle is sort of on that path already with her Delta Hawk build thread.
  9. Likes Streffpilot liked this post
  10. #9
    Registered User BJC's Avatar
    Join Date
    Oct 2013
    Posts
    4,916
    Likes (Given)
    2551
    Likes (Received)
    3097
    Reported
Similar Threads
  1. Importing amateur-built aircraft into the USA
    By cluttonfred in forum General Experimental Aviation Questions
    Last Post: August 1st, 2010, 01:15 PM
  2. Home Built Aircraft
    By kaitlin415 in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: June 18th, 2009, 03:27 PM
  3. Call to Action - FAA proposed new amateur-built certification policy
    By jnorris in forum Rules and Regulations / Flight Safety / Better Pilots
    Last Post: September 8th, 2008, 03:33 PM
  4. Amateur Aircraft builders?
    By GrantR in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: August 1st, 2008, 12:19 PM
  5. FAA Amateur Built Referance Material
    By Jman in forum Rules and Regulations / Flight Safety / Better Pilots
    Last Post: March 18th, 2003, 02:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
