Inverted Rotax
pylon500
Dec 26, 2003
750
Taree Airport Australia
G'Day All, just want to hear from others that have invert mounted Rotax's with regards to oiled up plugs and starting. :mad:
I previously had an inverted single ignition 503 in my plane, that never seemed to give much trouble.
If parked for any more than a month or so, I'd have to pull the plugs and flush out the oil, then away I'd go. :rolleyes:
I now have a 582 in the same place (no oil injection) and will have to pull the plugs even the day after flying! :wail:
This engine is cowled, and it is a real pain in the A@# to get at the plugs.
I thought maybe the primer system was leaking, so disconnected it, no change.
I haven't done that drill hole in the rotary disc housing, would that much oil seep through from the carbi's when stopped?
I always turn my fuel off.
Any ideas? :confused:
Arthur.
