'K - here's the issue/problem
Am in the process of removing old ceconite from wings with ribs made from foam ( styrofoam actually !! ) with aluminum caps and in some cases aluminum sides.
The original cover was riveted to the caps and then the rivet heads were covered with ceconite tape.
I can remove the covering but if I drill out the rivets, the head comes off but there is no way to get the 'pin' of the rivet out without enlarging the holes!!!
Best solution ??
Leave the 'pin' in and just push it in a bit deeper into the foam with the the new rivet ??
Enlarge the hole ?? ( I don't like that one at all !! )
Leave the old rivets in place, do not rivet new covering
to the ribs ? ( going to look 'bumpy' ) :ermm:
Remove the heads of the old rivets and do not rivet new covering to the ribs ( smoother than the above idea !! )
or
I'd love some ideas or suggestions before I get seriously started on this.
Thanks.
Best solution ??
or
Thanks.
