Hi Fellers,
I'm planning to build an experimental PA-18. I have a number of the original Piper drawings so I could actually build an 18 clone if I wanted to.
However, I'd like to modify the fuselage to make it a full truss instead of a smaller truss with the sheet metal turtle deck arches. I would think this would make a stronger fuselage structure without adding too much weight.
I've come up with a design to do this but I really don't want to have to spend the money to have an engineer do a detailed stress analysis on the design to satisify safety and the FAA. I'm assuming that in a case like this that the DAR that performs the certification inspection would want to see that there had been at least some engineering done on the design.
I know a few years ago someone had gone through the process of certifying a cub fuselage that incorporated this change, but it never went into full scale production.
Has anyone ever seen plans for building an 18 fuselage like this?
