Rotax 582 Replacing Rotary Valve Hoses Advice/Tips
Turbo_Boss
Mar 20, 2008
27
Panama Rep. of panama
Hello Guys,
I need to replace the Rotary Valve hoses that goes to the small tank reservoir. One of them has a crack and eaven that is no leaking, I want to replace both.
One RV hose run on the back of the magnetos plate and I have to remove that plate/bracket in order to have access to the clamp were is atached.
That plate/bracket is attached to the engine by four screws............ Two of does upper screws also hold the water outlet socket in his place so I will be carefull when removing does 2 screws.
So here are the questions:
Do the 2 remaining lower plate/bracket screws hold something else that the Magnetos plate? Or I just go ahead and remove them.
Any advise on doing this work? Do I need to remove something else to have access to that clamp/hose?
BTW, this Rotax 582 is a grey head, is top mounted on a Quicksilver UL and the spark plugs are facing up.
Thx for your time and help,
Isaac
