Likes Likes:  0
Results 1 to 13 of 13
Thread: Fibrelam panel building
  1. #1
    Registered User BBerson's Avatar
    Join Date
    Dec 2007
    Port Townsend WA
    Posts
    7,347
    Likes (Given)
    1253
    Likes (Received)
    1098
    Anybody using flat fiberglass panel construction?
    Like this: http://www.retroplane.net/forum/files/optimist_195.pdf
  2. #2
    Registered User
    Join Date
    Jul 2014
    North Carolina
    Posts
    779
    Likes (Given)
    312
    Likes (Received)
    155
    Re: Fibrelam panel building
    Barnaby Wainfan had plans for something like that on the fmx5.
  3. #3
    Join Date
    Dec 2007
    Port Townsend WA
    Posts
    7,347
    Likes (Given)
    1253
    Likes (Received)
    1098
    Yeah. Don't think he started construction.
    Just wondering if any other airplanes have flown in the years since 1999. Or if homebuilders have tried it.
  4. #4
    Registered User pwood66889's Avatar
    Join Date
    Feb 2007
    Ozark, Alabama, USA
    Posts
    1,003
    Likes (Given)
    1
    Likes (Received)
    62
    I think FibreLam died for some reason as an aircraft construction material. Only heard of one successful completion, and that was a glider in Great Britain.
    Percy in SE Bama, USA
  5. #5
    Registered User cluttonfred's Avatar
    Join Date
    Feb 2010
    World traveler
    Posts
    3,765
    Likes (Given)
    813
    Likes (Received)
    1161
    The Volksplanes call for a fuel tank/forward fuselage top made up primarily of sheets of Alsynite polyester resin fiberglass panels, which only seem to be made in New Zealand today and we know know that the resin itself is susceptible to modern fuels. I suspect most builders today make up their own epoxy panels on a sheet of glass or waxed aluminum and still have to protect the tank from the fuel.
    If there were a readily-available and reasonably-affordable source for high-quality composite panels today there would be lots of potential applications to homebuilts like the Optimist that go together from precut sheets like a big balsa or paper model. Unfortunately, that just doesn't seem to be the case.
    Matthew Long, Editor
    cluttonfred.info
    A site for builders, owners and fans of Eric Clutton's FRED
    Voici ce que j'ai fait...vous pouvez en faire autant!
    "This is what I have done...you can do the same!"
    --Henri Mignet (1893-1965)
  6. #6
    Registered User
    Join Date
    Oct 2005
    Evans Head Australia
    Posts
    133
    Likes (Given)
    0
    Likes (Received)
    52
    The fuselage of the Streak Shadow was constructed of Fibrelam.
  7. #7
    Join Date
    Dec 2007
    Port Townsend WA
    Posts
    7,347
    Likes (Given)
    1253
    Likes (Received)
    1098
    I think the Fibrelam is cored like corrugated cardboard. I don't think homemade is practical.
  8. #8
    Registered User
    Join Date
    Feb 2011
    Salem, Oregon, USA
    Posts
    123
    Likes (Given)
    0
    Likes (Received)
    34
    Quote Originally Posted by BBerson View Post
    Actually they're honeycomb cored, made by Hexcel corp and used in a lot of areas
  9. #9
    Join Date
    Dec 2007
    Port Townsend WA
    Posts
    7,347
    Likes (Given)
    1253
    Likes (Received)
    1098
    Quote Originally Posted by Bill-Higdon View Post
    Then if it is Hexcel honeycomb it is too expensive.
    Need an industrial corrugated core to be reasonably cheap like boxes. And corrugated folds nicely along the corrugations.
  10. #10
    Join Date
    Dec 2007
    Port Townsend WA
    Posts
    7,347
    Likes (Given)
    1253
    Likes (Received)
    1098
    This ThermHex honeycomb is apparently much cheaper than Hexcel
    http://econcore.com/en/technology/thermhex
  11. #11
    Registered User
    Join Date
    Jan 2011
    US
    Posts
    2,047
    Likes (Given)
    535
    Likes (Received)
    768
    Are you looking for a corrugated core (rather than foam core) in a pre-made laminated panel for a particular reason?
    If corrugation is a must, maybe an inexpensive thing to look at might be Coroplast (the corrugated plastic used for signs, etc). I don't know how well epoxy would bond to it.
  12. #12
    Registered User Twodeaddogs's Avatar
    Join Date
    Jan 2009
    Dunlavin, County Wicklow,Ireland
    Posts
    365
    Likes (Given)
    115
    Likes (Received)
    96
    Most, if not all airliners, use floor panels made of fibrelam or equivalent.....I owe my life to the Shadow being made of fibrelam. I reduced one to small pieces and the hull stayed intact enough for me to survive.
  13. #13
    Join Date
    Dec 2007
    Port Townsend WA
    Posts
    7,347
    Likes (Given)
    1253
    Likes (Received)
    1098
    The plastic Coroplast isn't very structurally useful. It would be if made with FRP or aluminum face sheets.
    The right idea, wrong material.
Similar Threads
  1. Panel Design
    By SR9 in forum Instruments / Avionics / Electrical System
    Last Post: February 16th, 2012, 04:47 PM
  2. An I-Pad on your Panel?
    By Cy V in forum Hangar Flying
    Last Post: July 7th, 2010, 02:31 AM
  3. Building or RE-Building a 20 year old murphy renegade
    By joebiplane in forum General Experimental Aviation Questions
    Last Post: March 25th, 2009, 11:13 AM
  4. my panel
    By Project AKOM in forum Instruments / Avionics / Electrical System
    Last Post: February 4th, 2006, 06:05 PM
  5. my panel
    Last Post: January 27th, 2006, 06:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
