Likes Likes:  0
Results 1 to 4 of 4
Thread: Wood...Stress Risers???
  1. #1
    Registered User
    Join Date
    Jul 2016
    Saint John, NB Canada
    Posts
    14
    Likes (Given)
    1
    Likes (Received)
    13
    Good day all,
    Question for you. I'm aware of the importance and the care needed when working and smoothing any edges and "jagged" lines in metal as it creates a possible stress riser in the metal. My question is
    Is this the same for wood?
    I ask because I have small tooling marks on the inside of my relief holes in my wing ribs. I'm smoothing them out, but wondering how far I should take it? The relief holes will be covered with plywood face plys.
    Thanks
    Mark
    Also I'm about to start my builders thread for my Snoshoo SR-1 Reno F1 Racer so please stop by and take a look!
  2. #2
    Registered User wsimpso1's Avatar
    Join Date
    Oct 2003
    Saline Michigan
    Posts
    3,721
    Likes (Given)
    624
    Likes (Received)
    1400
    Re: Wood...Stress Risers???
    Get out a hand lens and look at wood's structure. It is one big mass of stress concentrations. Wood and composites are generally not considered to be sensitive to stress concentrations for this reason. Smooth surfaces? Sure. But do not go overboard...
    Billski
  3. #3
    Registered User
    Join Date
    Nov 2007
    Posts
    1,515
    Likes (Given)
    9
    Likes (Received)
    116
    It might make sense to taper the edges of the plywood a bit where they are glued on, but then you might have to make the plywood a bit wider in places.
  4. #4
    Registered User vtul's Avatar
    Join Date
    Mar 2017
    Southern Vermont, USA
    Posts
    56
    Likes (Given)
    8
    Likes (Received)
    6
    Not as notch sensitive as metal at really small scale, but certainly is in larger. I build longbows. You don't want to leave tooling marks on the back of a bow unless you need more fiber in your diet.
Similar Threads
  1. Stress analysis?
    By Bill Clapp in forum General Experimental Aviation Questions
    Last Post: January 3rd, 2016, 07:45 PM
  2. FEA Rivet Stress
    By proppastie in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: July 4th, 2014, 01:57 PM
  3. Stress calculation
    By Aviator168 in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: February 20th, 2014, 09:46 PM
  4. Stress calculation
    By Kristjan123 in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: March 12th, 2013, 11:23 AM
  5. Canopy Stress
    By mladen.k in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: August 3rd, 2010, 05:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
