Results 1 to 7 of 7
Thread: Hello from London, England
  1. #1
    Registered User
    Join Date
    Nov 2016
    London
    Posts
    13
    Likes (Given)
    0
    Likes (Received)
    0
    Hello everybody.
    I've been lurking a good while and learning a lot from you guys and I guess it's time to finally break cover.
    I currently fly gliders (1985 vintage LS6), used to fly toy aeroplanes, did an Aerospace Engineering degree getting on for 20 years ago and have my eye on designing / building some kind of SSDR (sub 300kg, single seat, 35 Knot stall speed) thing.
    What really got my interest going was the recent proliferation of small electric aeroplanes so the idea is to build something efficient, cheapish and low powered with off the shelf (read toy aeroplane) parts. Doesn't seem to me that I need any new technology - the power train was worked out five+ years ago, the aerodynamics and structures 30+ years ago all I've got to do is tie it all together nicely(!)
    I'll be popping up around the place asking dumb questions for the next little while as I work out what might work.
    Here's a brief outline of what I'm after:
    250kg AUW
    500fpm climb
    90 Knot cruise(!)
    1 hr+ endurance
    composite construction (infused carbon probably because that looks fun)
    Must be possible to build most of it in pretty confined space.
    That's about it really.
  2. #2
    Registered User Toobuilder's Avatar
    Join Date
    Jan 2010
    Mojave, Ca
    Posts
    2,991
    Likes (Given)
    246
    Likes (Received)
    1757
    Re: Hello from London, England
    Welcome to the club. Dont worry about dumb questions - those seem to get the most air time around here!
    As an aside, I spent 2 years of my life near London, stationed with the USAF at the now closed RAF Upper Heyford. That experience cured me from ever needing to see another drop of rain again (which explains my current address).
  3. Likes Battler Britton, bmcj, rv6ejguy liked this post
  4. #3
    Registered User
    Join Date
    Nov 2016
    London
    Posts
    13
    Likes (Given)
    0
    Likes (Received)
    0
    I can't imagine what you do with your time without the constant wondering about / complaining about the weather.
    Upper Heyford is just rows of cars these days - true for most big runways round here.
  5. #4
    Join Date
    Jan 2010
    Mojave, Ca
    Posts
    2,991
    Likes (Given)
    246
    Likes (Received)
    1757
    One thing I learned about England's weather: If you don't like it at the moment, wait a few minutes because its going to change.
    I've "Google mapped" the present Heyford site, and yep, lots of cars on the runways and taxiways. I always wondered about that. All this incredible airfield infrastructure - and they use it as a parking lot.
  6. #5
    Registered User Aerowerx's Avatar
    Join Date
    Dec 2011
    Marion, Ohio
    Posts
    3,252
    Likes (Given)
    468
    Likes (Received)
    850
    Quote Originally Posted by Toobuilder View Post
    I thought that was only in Ohio. You know you are in Ohio if you use your furnace and air conditioner in the same day.
    Visited Upper Heyford once. My brother was stationed at RAF Fairford for a while, when he was in the USAF, and several of the family went over for a visit. I'm surprised they would close the place.
    And welcome to the forum, Foundationer!
    ___________________________
    Optimist: The bottle is half full.
    Pessimist: The bottle is half empty.
    Engineer: The bottle has a Factor of Safety of 2.0
  7. #6
    Registered User Beragoobruce's Avatar
    Join Date
    Oct 2014
    Blue Mountains, AUSTRALIA
    Posts
    44
    Likes (Given)
    6
    Likes (Received)
    28
    Greetings Foundy
    Interesting idea for a new class of light plane. I'm sure this general concept will be in a lot of peoples' minds, particularly as battery technology inevitably evolves.
    I note you're thinking of infused carbon fibre as the basis of construction. How would this sit with homebuilding? I'm a wooden aeroplane man myself, but have dabbled in low tech epoxy/glass detail work.
    To optimise the weight & structural potential of your proposed materials, wouldn't you need to autoclave? Or at the very least, vacuum bag at controlled temperature & humidity? How easily & cheaply could you manage this as a one off home build?
    As regards structural integrity, would you need to destruct test primary structure, or could you be sure enough of achieving theoretical c.f. properties in your shed? Or do you simply allow sufficient factor of safety to be sure of meeting structural minima? (I think this is how it works on homebuilts like my recently completed MiniMax, using wood & epoxy in uncontrolled conditions.)
    I solved the temperature/humidity/weather issues by moving from Devon to Australia, but some may consider that an extreme solution.
    I look forward to following your design (& hopefully build) process.
  8. #7
    Registered User
    Join Date
    Nov 2016
    London
    Posts
    13
    Likes (Given)
    0
    Likes (Received)
    0
    Hi Bruce,
    Re. Infused CF... No idea yet but I'm going to find out - currently I just like the idea of it / have seen some other people using it successfully. I don't think autoclave is necessary - curing at elevated temperature maybe but then that's fairly easily done (I think). I'm hoping that infusion will make more reliable pieces than wet layup and I can get away with testing smaller coupons to destruction and the main components to some extent.
    I really would love to build a wooden aeroplane one day though - there's something sort of 'proper' about it!
Similar Threads
  1. Hello from England.
    By DodgyDJ in forum New Member Introductions
    Last Post: February 6th, 2012, 09:51 PM
  2. London to Capetown-n-back..Solo record!
    By LArzfromarz in forum Hangar Flying
    Last Post: September 22nd, 2010, 10:35 AM
  3. Hello from England
    By bvlgary in forum New Member Introductions
    Last Post: October 29th, 2007, 10:00 AM
  4. Hi from England
    By Johnny luvs Biplanes in forum New Member Introductions
    Last Post: October 26th, 2003, 06:28 PM
  5. Over here in England
    By bigflyingrob in forum Hangar Flying
    Last Post: May 20th, 2003, 04:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
