Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: Relative safety of various construction materials
  1. #1
    Registered User
    Join Date
    Dec 2016
    Putney, VT
    Posts
    51
    Likes (Given)
    8
    Likes (Received)
    3
    Hello,
    I am looking at building a new kit, and considering my options there is one piece of information I would love to have, but don't find readily available. Wood is my preferred material to work with, since I have a very complete shop. In the event of an accident, or forced landing, how does it compare to aluminum or cloth and tube? Are there any definitive studies, or at least compelling anecdotal and engineering evidence?
    Thanks in advance for the help,
    Ward
  2. #2
    Registered User Little Scrapper's Avatar
    Join Date
    Jan 2014
    Wisconsin
    Posts
    2,480
    Likes (Given)
    1501
    Likes (Received)
    1170
    Re: Relative safety of various construction materials
    Aluminum airplanes don't do well in some crashes, true. An engine out crash causing damage has more to do with math than it does material. A wood Pietenpol is a "low and slow" type airplane so it just barely kills you in a crash. Lol. A engine out over a plowed field with a stall speed of a 100 mph can be a nightmare regardless of material used. Physics.
    I feel tube and fabric is the strongest but wood is a amazing material as well.
    I'm not sure of any documentation of material characteristics because there's a ton of variables to consider. If you Google a design and accident and click images you can see the aftermath.
    Of course, the goal is not to crash, learn to fly and be prepared at all times. If you like wood I think you'll discover it's a great material in which to build a airplane.
  3. Likes bmcj liked this post
  4. #3
    Registered User Toobuilder's Avatar
    Join Date
    Jan 2010
    Mojave, Ca
    Posts
    2,944
    Likes (Given)
    243
    Likes (Received)
    1708
    Quote Originally Posted by wardo View Post
    ... Wood is my preferred material to work with, since I have a very complete shop. In the event of an accident, or forced landing, how does it compare to aluminum or cloth and tube...
    Regardless of construction materials employed, the entire objective is to maintain deceleration of the delecate pink bodies inside at a survivable rate. If the entire airframe is crumpled like a beer can and consumed in the crash event but allows the people to live, thats far better than a hell for strong structure that survives intact, but forces the occupants to withstand deceleration in isolation.
  5. #4
    Registered User
    Join Date
    Apr 2010
    Posts
    7,486
    Likes (Given)
    0
    Likes (Received)
    1755
    It is going to be dependent of design, but they are going to be close to the same. Lots goes into thinking about crashing but planes are really designed to keep flying not crashing. That is the first protection of crashing. Nothing wrong with wood.
  6. Likes Little Scrapper liked this post
  7. #5
    Registered User wsimpso1's Avatar
    Join Date
    Oct 2003
    Posts
    3,672
    Likes (Given)
    593
    Likes (Received)
    1361
    My view on which material set to build in is all wrapped around materials you can communicate in and like to work in. Building an airplane is a huge thing, and if you do not love it, you will never fly it.
    Safety is largely a matter of flying the airplane well, making good decisions, using good judgement. If awful things result in a forced landing, be proficient in landing under control and at minimum speed.
    That being said, I think that if you select an airplane with a good safety record and without major issues, build it to the plans, and then get fully proficient in flying before you start flying it, you will have seriously stacked the deck in your favor.
  8. #6
    Registered User
    Join Date
    Mar 2008
    Upper midwest in a house
    Posts
    3,166
    Likes (Given)
    319
    Likes (Received)
    1004
    Without regard to construction materials, installing basic safety equipment to properly restrain and support the pilot's torso when subjected to deceleration forces will give the best opportunity in an accident. I would not at all be concerned with wood as a building material.
    “The only difference between reality and fiction is that fiction needs to be credible.” - Mark Twain
    “If you can't dazzle them with brilliance, baffle them with bull$hi+.” ― W.C. Fields
  9. Likes cheapracer liked this post
  10. #7
    Registered User mcrae0104's Avatar
    Join Date
    Oct 2009
    Colorado / USA
    Posts
    1,659
    Likes (Given)
    1298
    Likes (Received)
    1078
    Some thoughts elated to your question can be found here: https://flycorvair.net/2012/11/17/st...mph-accidents/
    ​simplify.
  11. Likes Daleandee, wardo, Vision_2012 liked this post
  12. #8
    Registered User BBerson's Avatar
    Join Date
    Dec 2007
    Posts
    7,147
    Likes (Given)
    1227
    Likes (Received)
    1060
    Since the early days of aviation it was known that wood sticks can snap and impale the pilot. They tried wrapping the longerons with fabric, which helps a bit. The real solution was plywood sheathing in the cockpit, pioneered by Dehaviland.
    Metal yields (bends and absorbs energy) which is ideal in a crash. But wood and composites can be engineered for crush loads.
  13. Likes Victor Bravo liked this post
  14. #9
    Registered User D Hillberg's Avatar
    Join Date
    Nov 2010
    very low low low earth orbit
    Posts
    964
    Likes (Given)
    262
    Likes (Received)
    349
    Don't crash, Had a friend with a Lohl 5151 and he crashed it twice (three if you count a ground loop after a rudder cable snapped), last one all he got was a bruised butt and it was close to destroyed , damn if he didn't rebuilt it as a razorback looks better too. aluminum and wood disposal can heat a camp fire or buy beer and pizza after your done, plastics tend to require special handling to get rid of....No mater what material you pick I bet it will fly just fine.
  15. Likes cheapracer liked this post
  16. #10
    Registered User Victor Bravo's Avatar
    Join Date
    Jul 2014
    Posts
    2,576
    Likes (Given)
    546
    Likes (Received)
    2197
    Quote Originally Posted by BBerson View Post
    Excellent point !
    You could possibly use Kevlar thread to wrap the longerons and cross members in an "open frame" design, and the Kevlar would prevent the sticks from snapping. The Kevlar thread weighs almost nothing, and is fairly inexpensive too.
    However, if there are plywood sheet structural materials that are glued to the sticks as part of the design, the Kevlar thread could interfere with proper bonding between the sticks and the plywood. You'd have to have somebody look into that before you put that thread in as part of the glue joint. May be a deal-breaker.
    A layer of thin Kevlar cloth on the inside of the structure would surely add a lot of crash safety, but this has far more weight, cost, and complexity than wrapping sticks.
    "Everything in this book may be wrong."
    Richard Bach, Illusions
  17. #11
    Moderator Topaz's Avatar
    Join Date
    Jul 2005
    Posts
    12,321
    Likes (Given)
    6880
    Likes (Received)
    3896
    Any construction material can be made "relatively safe" in a crash. Design for crashworthiness is more about design and much less about materials.
    Since the early days of aviation it was known that wood sticks can snap and impale the pilot. ...
    If cockpit structure is being deformed to the point of failure, there are much larger crashworthiness issues with the design than what material was chosen. The cockpit should provide a "secure cage" capable of withstanding the design crash loads without significant deformation. Otherwise, all the other crashworthiness measures are for naught.
    Quote Originally Posted by Turd Ferguson View Post
    Yes. Also, keeping the pilot's extremities (including the head) from flailing into hard or sharp features in the cockpit. Either put the stuff out of "flail range" (there are actual numbers for this, with the usual percentile ranges for pilot size) and/or make sure everything within that range is either soft, padded, and/or given rounded corners or edges.
    Quote Originally Posted by wsimpso1 View Post
    This is the best route. Established designs with a big enough history can be seen to have good or poor crashworthiness characteristics. Choose the airplane, not the material, build in a material you enjoy, and stick to the plans. Best way to "come out good" in the end.
    The best reference on general-aviation crashworthiness design that I've found is here: http://www.niar.wichita.edu/agate/Do...034043-036.pdf
    "If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them." - Henry David Thoreau
    Design Project: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
    Discussion Thread for the Project: Discussion: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
  18. Likes Little Scrapper, wardo liked this post
  19. #12
    Moderator autoreply's Avatar
    Join Date
    Jul 2009
    Rotterdam, Netherlands
    Posts
    10,637
    Likes (Given)
    244
    Likes (Received)
    2253
    All planes in similar categories with the lowest injuries/fatalities are composite airframes...for good reason.
    High-end racing... same reason.
    A bad airframe design will make a far bigger difference though.
    Kennis vermenigvuldig je door het te delen.
    (You multiply knowledge by dividing it)
  20. #13
    Registered User
    Join Date
    Dec 2016
    Putney, VT
    Posts
    51
    Likes (Given)
    8
    Likes (Received)
    3
    Thanks everyone for all the input. It was most helpful. Of course not crashing should always be your first line of defense, but I like to consider the planned and unplanned outcomes. I owned and flew an RV-4 for a few years, and the unexpected never showed up. The years I spent racing a rally car are another story....
    Ward
  21. #14
    Registered User
    Join Date
    Dec 2016
    Putney, VT
    Posts
    51
    Likes (Given)
    8
    Likes (Received)
    3
    Quote Originally Posted by mcrae0104 View Post
    That link directly addresses a number of relevant issues. I am also an Embry-Riddle grad, so I guess I should give the author extra points for that as well.
    Thanks,
    Ward
  22. #15
    Registered User
    Join Date
    Dec 2016
    Putney, VT
    Posts
    51
    Likes (Given)
    8
    Likes (Received)
    3
    The link looks very promising, but it is going to take me a few minutes to wade through the 414 pages!
    Thanks,
    Ward
    Quote Originally Posted by Topaz View Post
Similar Threads
  1. Cassutt - Construction Techniques & Standards / Tube and Fabric Aircraft Construction
    By Little Scrapper in forum General Experimental Aviation Questions
    Last Post: January 27th, 2017, 04:09 PM
  2. Locating the C.G. relative to wing aeroydnamic center?
    By WK95 in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: April 10th, 2016, 08:32 AM
  3. Engine vs pliot placement relative to neutral pt
    By stankap in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: February 6th, 2012, 06:03 PM
  4. RELATIVE HUMIDITY
    By TWOLABS in forum Wood Construction
    Last Post: October 2nd, 2008, 08:51 PM
  5. PLUG CONSTRUCTION MATERIALS
    By AVI in forum Composites
    Last Post: October 6th, 2004, 08:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
