Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: Scaled-Up Airfoils???
  1. #1
    Registered User Aerowerx's Avatar
    Join Date
    Dec 2011
    Marion, Ohio
    Posts
    3,251
    Likes (Given)
    468
    Likes (Received)
    849
    I have learned the hard way about Reynolds numbers and scaling airfoils. Fortunately it was a virtual crash and burn.
    What I had done was create my full-size XFLR5 model using the PRANDTL-D airfoils, which I think are Horten-like in design. This did not work at all when dynamically scaled to 1/8th or even 1/5th scale.
    But then I changed to a Hepperle MH46, because it had the same 12% thickness and was made for lower Reynolds numbers (besides low pitch moment). After a it of tweaking, all the models worked fine.
    Since the MH46 was designed for the lower Reynolds numbers, my question is: Are there any problems with scaling an airfoil up in size to use at higher Reynolds numbers?
    ___________________________
    Optimist: The bottle is half full.
    Pessimist: The bottle is half empty.
    Engineer: The bottle has a Factor of Safety of 2.0
  2. #2
    Registered User mcrae0104's Avatar
    Join Date
    Oct 2009
    Colorado / USA
    Posts
    1,662
    Likes (Given)
    1309
    Likes (Received)
    1082
    Re: Scaled-Up Airfoils???
    Do you have a drag polar at the lower and higher Re?
    ​simplify.
  3. #3
    Registered User
    Join Date
    Mar 2016
    Austria
    Posts
    129
    Likes (Given)
    4
    Likes (Received)
    29
    Quote Originally Posted by Aerowerx View Post
    Yes, there are. One way to look at Reynolds numbers is that they account for the fact that boundary layers don't (hardly) scale. This leads to all kinds of different effects. As an example, a very pointy section (i.e. small nose radius) can work perfectly in low Re enrvironment, while it will give you abysmal stall characteristics in high Re regimes.
    (In extremis have a look at "sections" deployed by insects. They fly fine, but only with very low re numbers ~10^2).
  4. #4
    Registered User
    Join Date
    Nov 2010
    USA
    Posts
    55
    Likes (Given)
    1
    Likes (Received)
    4
    The only problem might be at higher Reynolds numbers the boundary layer might transition to turbulent on the upper surface sooner than at the lower Re giving a smaller maximum lift coefficient. You should be able to simulate this using an empirical method like XFLR5. If you increase the Re number and the boundary layer starts transitioning to turbulent on the upper surface sooner, you will be seeing this effect.
    Doug
  5. #5
    Moderator Topaz's Avatar
    Join Date
    Jul 2005
    Posts
    12,426
    Likes (Given)
    6979
    Likes (Received)
    3963
    And this is one of the issues with using even a dynamically-scaled model to "flight test" the full-size aircraft. You need to design the model for the flight environment in which it will operate and, as you've seen with Reynold's Number, that can mean the two aircraft are substantially different in many ways. Which begs the question as to how applicable the scale-model results will be to the full-size aircraft.
    The best use of a scale model - dynamic or otherwise - is to test your design methods. If you design the model to be grossly the same as the full-scale aircraft, but design the model as a model, and if the model performs as your methods predict it should perform, then you have one data point that validates your design methods. Which gives you confidence towards applying them to a full-scale aircraft.
    "If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them." - Henry David Thoreau
    Design Project: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
    Discussion Thread for the Project: Discussion: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
  6. #6
    Registered User BBerson's Avatar
    Join Date
    Dec 2007
    Posts
    7,366
    Likes (Given)
    1257
    Likes (Received)
    1109
    Airfoils are designed for a particular Reynolds number range.
    An airfoil catalog, such as from Eppler, will have a chapter for each Reynolds range.
  7. Likes mcrae0104 liked this post
  8. #7
    Registered User Norman's Avatar
    Join Date
    Nov 2003
    Grand Junction, Colorado
    Posts
    2,635
    Likes (Given)
    497
    Likes (Received)
    713
    Yes. There's a region on the airfoil called a "transition ramp" where the pressure gradient changes from favorable to unfavorable. At high Re transition to turbulent flow happens over a very short distance so airfoils designed for high Re have very short transition ramps. At low Re the situation is a bit more complicated. The natural transition point moves forward with AoA, or at least it can if the transition ramp is long enough. Low Re flow can stay laminar pretty far aft into the unfavorable pressure gradient if the gradient isn't too steep. By making a long transition ramp the low Re flow can transition near the trailing edge at low AoA and move forward slowly as AoA is increased, resulting in a small bubble with low drag throughout the range of AoA. If you operate that low Re foil at high Re the long bubble ramp doesn't work so well because the high Re flow transitions at the point of minimum pressure (near the point of maximum thickness) resulting in high friction drag. On the other hand if you operate an airfoil designed for high Re (with a short transition ramp) at low Re the flow will separate at the minimum pressure point resulting in a big separation bubble and high pressure drag. By default graph 4 in XFLR5 shows the upper surface transition point (the one labeled "Xtr t" on the X axis). Notice that the curve for the Prandtl-D root airfoil on that graph has a long, nearly vertical, segment at about 55% of the chord but the curve for the MH-46 has a long sloping segment from about 75% at cl=0 to 5% at cl=0.88? That's the effect of a long bubble ramp in the MH-46's pressure distribution. However this is an efficiency issue and shouldn't have much affect on stability.
    Reflexed airfoils have a similar problem on the bottom surface that does affect stability. There will be a very short run of adverse pressure near the trailing edge because of the reflex and this could cause a laminar separation bubble that will change the pitching moment of the airfoil. Graph 3 shows the Cm plot. Notice that in the smooth condition the Cm curves of both airfoils have a couple of kinks in them but the excursion is much bigger for the Prandtl-D than the MH-46. This will definitely affect stability. Forcing transition on the lower surface will smooth out those lines. How closely this reflects physical reality is hard to say but I do know that some full size sailplanes have a trip strip on the lower surface of the wing near the control surface hinge.
    -------/V\
    -(^^)---(^^) -Norm
    We didn't throw the tail away, we just hid it
  9. Likes dcstrng liked this post
  10. #8
    Registered User
    Join Date
    Nov 2012
    Madrid, Spain
    Posts
    342
    Likes (Given)
    224
    Likes (Received)
    47
    Wait, I thought that the Scale Effect was a possitive outcome from 1-9 10^6 Re, as the skin friction with a turbulent boundary layer decreases as Re increases? Is this not the same a high Re numbers... only subsonic flights and in the rage explained (need to check if that is the limits, but that's my mental note) I recall reading something in Chapter 5 of Theory of Wings to support this...
    The biggest problem is, using an airfoil designed Re 1<10^6 and scaling it below that Re... going the other way should prove positive... hence numerical theory predicts that higher Re yields higher Cl as the turbulent boundary layer is moved backwards on the airfoil... flattening out the parabola (slightly) as you increase Re...
    Maybe I'm having one of those brain farts today... but this is what I thought...
  11. #9
    Registered User bmcj's Avatar
    Join Date
    Apr 2007
    Posts
    11,641
    Likes (Given)
    6317
    Likes (Received)
    3956
    Quote Originally Posted by SpainCub View Post
    Yes, farts can also transition from laminar to turbulent (depending on Reynolds Number, of course).
  12. Likes pictsidhe liked this post
  13. #10
    Join Date
    Dec 2007
    Posts
    7,366
    Likes (Given)
    1257
    Likes (Received)
    1109
    Quote Originally Posted by bmcj View Post
    Sometimes they break the sound barrier, I think.
  14. Likes bmcj liked this post
  15. #11
    Join Date
    Dec 2011
    Marion, Ohio
    Posts
    3,251
    Likes (Given)
    468
    Likes (Received)
    849
    The note on Hepperle's web site says the MH46 is good for Re above 100,000, but what does that mean?
    On my smartphone so am not sure but IIRC my scale model is at Re about 400,000 to 500,000. The full size one is about 8 to 10 times that.
    As I said, both look good in XFLR5, even with the self.trimming flaps at 60 degrees
  16. #12
    Registered User Jay Kempf's Avatar
    Join Date
    Apr 2009
    Warren, VT USA
    Posts
    3,187
    Likes (Given)
    1
    Likes (Received)
    662
    A 2.5ft profile at 200mph is about Re 4.5M at 5k feet density. At least that is the one I was just doing so I know that is about correct.
    Jay K.
    VT USA
  17. #13
    Join Date
    Dec 2007
    Posts
    7,366
    Likes (Given)
    1257
    Likes (Received)
    1109
    Easy way to guess at Reynolds number. Just remember:
    One foot wing and 100mph = 1 million RN (more or less)
    So a 6 inch wing and 100 mph = 1/2 million
    And a 4 foot wing at 100 mph = 4 million or a 4 foot at 50 mph = 2 million. And so on.
  18. #14
    Join Date
    Nov 2003
    Posts
    2,635
    Likes (Given)
    497
    Likes (Received)
    713
    Quote Originally Posted by BBerson View Post
    What? Your formula doesn't include distance from the center of the earth, the adiabatic laps rate, and temperature in degrees Rankin? I've been doing this all wrong!
    -------/V\
    -(^^)---(^^) -Norm
  19. Likes BBerson liked this post
  20. #15
    Registered User
    Join Date
    Sep 2010
    Mwanza, Tanzania.
    Posts
    761
    Likes (Given)
    335
    Likes (Received)
    295
    Much closer if you use knots rather than mph.
    One foot & 100mph -> 0.93*10^6
    One foot & 100kt -> 1.07*10^6
Similar Threads
  1. Scaled Jets (F-16)
    By Acrojet in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: January 14th, 2017, 10:14 AM
  2. Scaled VW Cub?
    By Little Scrapper in forum Hangar Flying
    Last Post: August 8th, 2016, 09:04 PM
  3. 1/3 scaled affordaplane
    By mr.dani in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: July 11th, 2015, 01:21 PM
  4. Scaled-down T-28
    By Matt G. in forum Warbirds / Warbird Replicas
    Last Post: December 24th, 2011, 04:13 PM
  5. Scaled up RC plane?
    By vwdevotee in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: January 1st, 2011, 08:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
