Page 1 of 4 1234 LastLast
Results 1 to 15 of 48
Thread: L/D Ratio of an RV 3 ?
  1. #1
    Registered User
    Join Date
    Feb 2013
    Brisbane
    Posts
    217
    Likes (Given)
    4
    Likes (Received)
    24
    Does anyone have an RV 3 or know of the Airplanes L/D Ratio?
    TIA
    George
  2. #2
    Registered User
    Join Date
    Sep 2014
    Canada
    Posts
    662
    Likes (Given)
    3
    Likes (Received)
    166
    Re: L/D Ratio of an RV 3 ?
    Since L/D is related to aspect ratio .... and RV3 has an aspect ratio of 4 to 1 .... My first guess is an L/D of 4 to 1.
  3. #3
    Registered User BJC's Avatar
    Join Date
    Oct 2013
    Posts
    5,173
    Likes (Given)
    2704
    Likes (Received)
    3235
    For reference, the RV-8A has a glide ratio of 9.5 to 1. I would expect the -3 to be fairly close to that.
  4. Likes skier, BoKu liked this post
  5. #4
    Registered User rv6ejguy's Avatar
    Join Date
    Jun 2012
    Calgary, Alberta, Canada
    Posts
    2,444
    Likes (Given)
    1513
    Likes (Received)
    1490
    There was an L/D graph of an RV3 in one of the Contact books. I'll see if I can dig that up this weekend.
    Ross Farnham
    Racetech Inc.
    14 years and 408.2 hours on Subaru Turbo powered RV6A
    "The world is changed by your example, not by your opinion" Paul Coelho
    http://www.sdsefi.com/aircraft.html
  6. #5
    Registered User
    Join Date
    Dec 2015
    Earth USA East Coast
    Posts
    906
    Likes (Given)
    325
    Likes (Received)
    216
    You should be able to back-calculate the L/D, within about 10% or so, from data in the pilot's handbook. I suspect that it's optimum L/D is about 10 or so; this is fairly typical for general aviation aircraft.
  7. #6
    Join Date
    Jun 2012
    Posts
    2,444
    Likes (Given)
    1513
    Likes (Received)
    1490
    I found the chart but it was not L/D, was required hp vs. airspeed. 90 mph required about 30hp.
    Ross Farnham
    Racetech Inc.
  8. #7
    Registered User
    Join Date
    Feb 2013
    Brisbane
    Posts
    217
    Likes (Given)
    4
    Likes (Received)
    24
    To all,
    I purchased Jan Carlssons's Prop Program and to accurately predict performance the L/D ratio should be known, which acts as a parameter (Limit) to speed calculations (and therefore Prop Diameter/ Pitch). His program does in fact calculate the L/D but if one is trying to push the speed up, it lifts the L/D Ratio to unacceptable limits. As I'm doing a prop Estimate for someone else on HBA, I don't have a clue what the L/D is, so I estimated 11.4 given some other guide I found on the Internet of similar type aircraft. Then I thought I was too conservative and went to 12.7 because of the high HP available and streamlined Cowl. The Original RV 3 had a hp rating of up to 160 hp but this estimate is a little beyond that again - so I figure 12.7 might not be an overestimate in this case. Still if I had a baseline to work with it would be better than nothing.
    TIA
    George
  9. #8
    Join Date
    Oct 2013
    Posts
    5,173
    Likes (Given)
    2704
    Likes (Received)
    3235
    I would be surprised if the L/D of the RV-3 exceeds 10.
  10. Likes Pete Plumb liked this post
  11. #9
    Registered User Himat's Avatar
    Join Date
    May 2011
    Norway
    Posts
    2,346
    Likes (Given)
    1404
    Likes (Received)
    528
    Quote Originally Posted by Riggerrob View Post
    The L/D ratio is related to the wing aspect ratio, but not a direct function of the wing aspect ratio. NACA/NASA published a long list of L/D and A/R for different planes. Gudmundsson have this list in his book, together with some own calculations. I do not have the book in front of me, bur L/D close to 10 have been achieved on airplanes with A/R around five if I remember correct.
    A L/D of 8 to 10 on a RV-3 sounds possible, probably with a vide spread from aircraft to aircraft depending on details like wheel fairings, engine baffling, sealing of cockpit/fuselage and other.
  12. Likes Swampyankee liked this post
  13. #10
    Registered User BBerson's Avatar
    Join Date
    Dec 2007
    Posts
    7,362
    Likes (Given)
    1257
    Likes (Received)
    1109
    Could be measured in flight. Take the sink rate and distance and measure the L/D ratio.
  14. #11
    Registered User fly2kads's Avatar
    Join Date
    Jan 2010
    Justin, TX
    Posts
    1,040
    Likes (Given)
    555
    Likes (Received)
    305
    This points to one of the reasons why designing propellers can be very tricky. The underlying methods Jan is using can yield very precise results, but at the same time, they are subject to substantial uncertainties; the drag of the specimen aircraft in question, and the actual power output of that individual powerplant installation chief among them. This is a garbage-in, garbage-out scenario if there ever was one. The more accurate your input, the better your results.
    I have seen others on this forum describe propeller design as a black art. I disagree. The physics are well established and the math has been defined. The problem, as Lendo is discovering, is obtaining accurate input data. The "black art" is just lessening the uncertainty and arriving at reasonable estimates. From there, the design process is subject to the same types of tradeoffs as any other aspect of aircraft design.
    In this case, if you know the best glide speed for the RV-3, you can determine the L/D ratio from there.
  15. Likes Swampyankee liked this post
  16. #12
    Registered User
    Join Date
    Mar 2008
    Upper midwest in a house
    Posts
    3,255
    Likes (Given)
    329
    Likes (Received)
    1026
    Cafe Foundation has evaluated at least 3 customer built RV's and the factory RV-9. Could probably get I good idea of the RV-3's glide performance there.
    “The only difference between reality and fiction is that fiction needs to be credible.” - Mark Twain
    “If you can't dazzle them with brilliance, baffle them with bull$hi+.” ― W.C. Fields
  17. #13
    Registered User
    Join Date
    Nov 2007
    Posts
    1,522
    Likes (Given)
    9
    Likes (Received)
    116
    If you know what the prop efficiency they assumed is, then that horsepower figure, if accurate, should give you a good idea of L/D. For instance, I'd say, based on nothing but laziness and a wild guess, that the gross weight is 1,000 lbs. Oops, I just checked. It's pretty heavy for a single seat airplane. Real gross is 1100. If it takes 30 hp at 90 mph, with a prop efficiency of 70 percent, that's 11,550 ft-lbs/second at about 132 ft/sec. I.e. about 88 lbs thrust. That's almost 12.6:1. Seems a bit high. If the horsepower was AFTER accounting for prop efficiency, that would be more like 8.8. Throw in something for the drag of a stopped prop, or, worse, a windmilling one.. In any case, this might not be the best L/D speed in the first place. Best L/D should be somewhat above minimum sink. The latter should be somewhere close to speed for fastest climb, maybe a bit less because the best climb figure has to account for what the prop does. Another factor that might change things a little bit is that the propwash means faster air speeds over part of the fuselage.
    BTW, using the specs from the Van's Aircraft web site, the aspect ratio is 4.4. (19'11" and 90 square feet)
    Another way to go at it, and I suspect this will be considerably fuzzier:
    Assume equivalent flat plate area for the fuselage is 1.5 ft^2. (Another wild guess) Dynamic pressure at 90 mph is 20.7 lbs/ft^2. So that's 31 lbs drag . We'll look at the wing as a separate entity, hoping that the interference drag is similar to the drag savings by having part of the wing buried. Totally arbitrary and due to laziness on my part. The wing loading is 1100/90 = 12.2 lbs/ft^2. 12.2/20.7 = .58 for the Cl. I'm assuming that span efficiency is 0.85. cdi=.58^2/(pi*4.4*.85) or 0.0286 .0286 * 20.7 *90 is 53.3 lbs drag, which is higher than I expected. If we assume the wing Cd is .012 (another wild guess), then .012*20.7*90 is 22.4 lbs drag. So that makes a total of 107 lbs drag, or L/D = 10.3 So at least we're in the same ballpark. And maybe the higher reported figure means the RV-3 is somewhat cleaner than most. If I cheated on any of the guesses, I don't remember doing so.
    If someone else can prove there are holes in the above reasoning, I'd appreciate it if you did.
  18. Likes Lendo liked this post
  19. #14
    Registered User
    Join Date
    Feb 2013
    Brisbane
    Posts
    217
    Likes (Given)
    4
    Likes (Received)
    24
    Ir27 -You right 12.6 or 12.7 was my second guess but 10.3 seems a little low, it's fairly clean with a Powersport Cowl, so maybe my first WAG of 11.4 is more like it.
    Your right we have 90 sq.f.t wing area, 1,100 lbs., T/O weight, and 185 hp, the prop efficiency is about 85% - how dos that affect your maths.
    George
  20. #15
    Moderator autoreply's Avatar
    Join Date
    Jul 2009
    Rotterdam, Netherlands
    Posts
    10,717
    Likes (Given)
    245
    Likes (Received)
    2301
    Quote Originally Posted by BJC View Post
    Me too.
    Pretty easy to calculate with CD0 Oswald and AR.
    Likely in the 8-9 range without prop and considerably below 8 with a stopped prop.
    Good planes have AR>>30
    Kennis vermenigvuldig je door het te delen.
    (You multiply knowledge by dividing it)
  21. Likes mcrae0104, karoliina.t.salminen liked this post
Similar Threads
  1. t-88 mix ratio tolerance
    By skybound in forum Wood Construction
    Last Post: December 22nd, 2015, 11:35 AM
  2. Span loading and Aspect Ratio vs glide ratio
    By leviterande in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: February 25th, 2015, 09:01 AM
  3. HP to weight ratio
    By TXFlyGuy in forum Firewall Forward / Props / Fuel system
    Last Post: September 14th, 2012, 08:02 PM
  4. low aspect ratio
    By D Graber in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: February 1st, 2010, 09:26 PM
  5. Aspect Ratio
    By Jim Pekola in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: April 7th, 2008, 09:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
