Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
Thread: L/D Ratio of an RV 3 ?
  1. #31
    Registered User Jan Carlsson's Avatar
    Join Date
    Jan 2009
    Sweden
    Posts
    1,726
    Likes (Given)
    458
    Likes (Received)
    300
    Re: L/D Ratio of an RV 3 ?
    Quote Originally Posted by BBerson View Post
    Is that 10.6 at best L/D speed or cruise speed?
    I would think the prop is designed for cruise speed.
    yes. at speed for max L/D
    Yes. or max speed.
    Jan.
    A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away. Antoine de Saint-Exupery
    "Flight by machines heavier than air is unpractical and insignificant, if not utterly impossible." Simon Newcomb, 1902
  2. #32
    Registered User BBerson's Avatar
    Join Date
    Dec 2007
    Posts
    6,779
    Likes (Given)
    1186
    Likes (Received)
    995
    Quote Originally Posted by Jan Carlsson View Post
    Yes. or max speed.
    So, to design a prop for cruise speed, do you input the airplane cruise L/D?
  3. #33
    Join Date
    Jan 2009
    Sweden
    Posts
    1,726
    Likes (Given)
    458
    Likes (Received)
    300
    No, I just use max speed or if knowing cruise speed can calculate max speed, the Best L/D is calculated, and should stay the same in both inputs, just as when calculate for a different alt. L/D is just a control Nr.
    Jan.
  4. #34
    Registered User
    Join Date
    Feb 2013
    Brisbane
    Posts
    197
    Likes (Given)
    Likes (Received)
    23
    Toa all,
    Well I got an 'e' Scale of from 0.7 to 0.9 from Harloff ( I think) for LSA where as the Scale from Sadraey was for GA Light aircraft which was from 0.0.65 to 0.7. Working through the 'e' Factor using (Sadraey and GAAD, which were both the same for 'Straight Wings') Formula 1.78(1-0.68AR^0.68)-0.64 I get an 'e' of 0.92.
    This wasn't intuitive for me, I found it confusing, as when the AR goes down the 'e' goes up and as the RV 3 AR is 4.4, this results in a high 'e'. Give the CDo guide for LSA is between 0.02 and 0.03 I got results of CDo of 0.03 = L/D of 10.3; CDo of 0.25=11.29 and a CDo of 0.02 = L/D of 12.6. The average was 11.4 which was my first WAG - but nothing beats the Designers information for a start point. In this case the HP is higher than in the original RV documentation of max 160 hp- the engine people are looking at 185hp for this test phase, which the RV3 is the mule.
    So getting the right sized prop is a good place to start and has been my contribution (to fellow HBA members) using Jan Carlsson's Prop program - I like the comments Jan. Although it's been a fair bit of work I did a number of Spread-sheets which range from Seal level performance to 15,000 ft. to get the 'Big Picture' on expected performance using different L/D ratios. The Prop Program can do this but collating the information from different screens is a manual effort - but well worth the exercise in IMHO.
    I hope that information on the calculations help someone.
    George
  5. #35
    Registered User
    Join Date
    Feb 2013
    Brisbane
    Posts
    197
    Likes (Given)
    Likes (Received)
    23
    Jan,
    Just so I'm not missing anything what is meant by your reference of 'Nr" i.e. what is Nr?
    George
  6. #36
    Join Date
    Jan 2009
    Sweden
    Posts
    1,726
    Likes (Given)
    458
    Likes (Received)
    300
    Quote Originally Posted by Lendo View Post
    Jan,
    George
    It is short for number. it was to long to type.
    Jan.
Similar Threads
  1. t-88 mix ratio tolerance
    By skybound in forum Wood Construction
    Last Post: December 22nd, 2015, 11:35 AM
  2. Span loading and Aspect Ratio vs glide ratio
    By leviterande in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: February 25th, 2015, 09:01 AM
  3. HP to weight ratio
    By TXFlyGuy in forum Firewall Forward / Props / Fuel system
    Last Post: September 14th, 2012, 08:02 PM
  4. low aspect ratio
    By D Graber in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: February 1st, 2010, 09:26 PM
  5. Aspect Ratio
    By Jim Pekola in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: April 7th, 2008, 09:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
