Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 36
Thread: L/D Ratio of an RV 3 ?
  1. #16
    Registered User
    Join Date
    Feb 2013
    Brisbane
    Posts
    197
    Likes (Given)
    Likes (Received)
    23
    Re: L/D Ratio of an RV 3 ?
    Autoreply, Thanks again, I'm looking at that now. I will ask Jan what he uses for CDo to get his predicted L/D.
    Fly2kads, So vey true about the program, however it is well worth the asking price, I've had all sorts of fun playing with this. At the very least it gives a guide even with a WAG on L/D. It's good to get feed-back as to the accuracy of the program, I'm very impressed with it overall.
    Thanks for all the comments - it all helps.
    George
  2. #17
    Registered User BBerson's Avatar
    Join Date
    Dec 2007
    Posts
    6,781
    Likes (Given)
    1186
    Likes (Received)
    996
    X-Plane will give L/D in any speed or attitude. If you input correct numbers.
  3. #18
    Registered User
    Join Date
    Feb 2013
    Brisbane
    Posts
    197
    Likes (Given)
    Likes (Received)
    23
    Autoreply, I looked up Sadraey for CDo and there are some guides there -'e' should be easy enough with his formula and there is a scale 'from/to' for CDo. I will do some comparisons within that scale and see what eventuates. The JC prop Program does it's own L/D estimates so that may be helpful as a comparison.
    George
  4. #19
    Registered User
    Join Date
    Feb 2013
    Brisbane
    Posts
    197
    Likes (Given)
    Likes (Received)
    23
    Autoreply, Well I did the maths and will have to check everything again, but at this stage all I got was 9.42 L/D Ratio -(Bugger!!). 'e' was a little low at 0.64, Sadraey Gave from 0.65 to 0.7, as a guide.
    George
  5. #20
    Registered User
    Join Date
    May 2012
    Clugnat, France
    Posts
    21
    Likes (Given)
    0
    Likes (Received)
    5
    Quote Originally Posted by Himat View Post
    The L/D ratio is related to the wing aspect ratio, but not a direct function of the wing aspect ratio. NACA/NASA published a long list of L/D and A/R for different planes.
    Have you a link ?
  6. #21
    Registered User Himat's Avatar
    Join Date
    May 2011
    Norway
    Posts
    2,271
    Likes (Given)
    1346
    Likes (Received)
    514
  7. #22
    Registered User
    Join Date
    May 2012
    Clugnat, France
    Posts
    21
    Likes (Given)
    0
    Likes (Received)
    5
    Thank you !
  8. #23
    Join Date
    May 2011
    Norway
    Posts
    2,271
    Likes (Given)
    1346
    Likes (Received)
    514
    Quote Originally Posted by autoreply View Post
    Good planes have AR>>30
    I am not quite sure a 50+ feet span wing would look right on the RV-3.
    At least one of the great aeroplanes in history did have an A/R below 2.
    That plane did have a best L/D above 12.
  9. #24
    Moderator autoreply's Avatar
    Join Date
    Jul 2009
    Rotterdam, Netherlands
    Posts
    10,563
    Likes (Given)
    243
    Likes (Received)
    2205
    Quote Originally Posted by Lendo View Post
    George
    Sounds about right. Which CD0 did you use? CAFE tested a few RV's. EFPA was consistently between 1.8 and 2.2. I wouldn't expect the RV3 to be much lower, maybe a clean one at 1.65 or so. Should be straightforward to compare the used CD0 to that value.
    Kennis vermenigvuldig je door het te delen.
    (You multiply knowledge by dividing it)
  10. #25
    Registered User Jan Carlsson's Avatar
    Join Date
    Jan 2009
    Sweden
    Posts
    1,726
    Likes (Given)
    458
    Likes (Received)
    300
    If Van's Nr is correct they usually are, I make a wild guess and say L/D on a slippery RV-3 is 10.6-10.7 without propeller but with spinner, but never seen one like that.
    Jan.
    A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away. Antoine de Saint-Exupery
    "Flight by machines heavier than air is unpractical and insignificant, if not utterly impossible." Simon Newcomb, 1902
  11. #26
    Registered User
    Join Date
    Jul 2014
    Rochester, NY, USA
    Posts
    1,050
    Likes (Given)
    20
    Likes (Received)
    441
    I'm going purely on WAG. 6.5-7.8 L/D.
    I know that's lower than most guesses here, but I'm going "Price Is Right" low ball. If you take the prop off and tape some curved cardboard over the nose & air intakes.... 8.5/1.
    It's a fairly clean design, the RV guys say that landing gear intersection fairings make a big difference, ( a sign the big things are proper ) but it's a fairly low A/R and The Wing Is The Thing.
  12. #27
    Registered User BJC's Avatar
    Join Date
    Oct 2013
    Posts
    4,907
    Likes (Given)
    2545
    Likes (Received)
    3093
    Quote Originally Posted by Jan Carlsson View Post
    If you take away the propeller, you have to add in the tow hook.
    CAFE developed a zero propeller-thrust sensor that used a proximity sensor to determine when the crank was floating between the front and back faces of the thrust bearing. Scroll down here to read about it http://cafe.foundation/v2/aboutcafe_orderfromchaos.php
    I don't know if they used it when testing the RV's, but the greater-span -9A had an idle power glide ratio of 12 : 1. The -6A had a calculated Oswald span efficiency of 0.851 and a glide of 11.39 : 1.
  13. Likes autoreply liked this post
  14. #28
    Join Date
    Jan 2009
    Sweden
    Posts
    1,726
    Likes (Given)
    458
    Likes (Received)
    300
    The 10.6 - or so L/D I got from my propeller design software, is a result from the performance page, the L/D with propeller stopped isn't useful for propeller calculation, only important when it stop spinning.
    Jan.
  15. #29
    Join Date
    Oct 2013
    Posts
    4,907
    Likes (Given)
    2545
    Likes (Received)
    3093
    Yup, lots of things suddenly get important when the propeller stops.
  16. #30
    Join Date
    Dec 2007
    Posts
    6,781
    Likes (Given)
    1186
    Likes (Received)
    996
    Is that 10.6 at best L/D speed or cruise speed?
    I would think the prop is designed for cruise speed.
Similar Threads
  1. t-88 mix ratio tolerance
    By skybound in forum Wood Construction
    Last Post: December 22nd, 2015, 11:35 AM
  2. Span loading and Aspect Ratio vs glide ratio
    By leviterande in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: February 25th, 2015, 09:01 AM
  3. HP to weight ratio
    By TXFlyGuy in forum Firewall Forward / Props / Fuel system
    Last Post: September 14th, 2012, 08:02 PM
  4. low aspect ratio
    By D Graber in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: February 1st, 2010, 09:26 PM
  5. Aspect Ratio
    By Jim Pekola in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: April 7th, 2008, 09:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
