Results 1 to 12 of 12
Thread: Flitter
  1. #1
    Registered User bradyaero's Avatar
    Join Date
    Mar 2010
    Canada
    Posts
    77
    Likes (Given)
    3
    Likes (Received)
    18
    Flitter
    So I got tired of staring at the two sides of the flitter, putting off building a four foot hotwire, so I got out my carving knife (Chainsaw) and went at it. It's nice to see both sides together, I still have to do some fitting but in general, they fit, and it was a nice christmas present to myself, it was litterally snowing foam in my garage. Next I'll fit the halves together better and put the whole thing on a rotisserie so that I can get cleaning up the mess! Progress feels good no matter how small! If you have any suggestions, let em fly! Happy New Year, Greg
    Click image for larger version.
ID:	57440Click image for larger version.
    'The Piper Cub is the safest airplane in the world;it can just barely kill you.'
    - Attributed to Max Stanley ( Northrop test pilot) -
  2. #2
    Registered User Rockiedog2's Avatar
    Join Date
    Dec 2012
    Grenada MS
    Posts
    1,262
    Likes (Given)
    451
    Likes (Received)
    820
    Re: Flitter
    wow. tell us about it.
  3. Likes wsimpso1 liked this post
  4. #3
    Registered User wsimpso1's Avatar
    Join Date
    Oct 2003
    Posts
    3,616
    Likes (Given)
    557
    Likes (Received)
    1320
    Re: Flitter
    Quote Originally Posted by bradyaero View Post
    So, like, what is it? Airplane fuselage? Race car? Are you building it moldless or is this a plug or something else? You are not allowed to just throw this out there without more in the way of description of type and mission and construction... Grin.
  5. Likes bradyaero liked this post
  6. #4
    Registered User Tiger Tim's Avatar
    Join Date
    Apr 2013
    Posts
    1,336
    Likes (Given)
    429
    Likes (Received)
    753
    Re: Flitter
    Got nosy and google-y and came across this:
    Looks pretty sharp, and the CNC cut plug is a nice touch http://www.homebuiltairplanes.com/fo...ad.php?t=13953
  7. Likes bmcj, bradyaero liked this post
  8. #5
    Join Date
    Mar 2010
    Canada
    Posts
    77
    Likes (Given)
    3
    Likes (Received)
    18
    Re: Flitter
    I came up with the concept back in about 2000. I played around with flight sim models, and then found an aerodynamic engineer and then a cad guy to do the heavy lifting. After several iterations the plane took shape as you see it.
    I resurrected the wing from the ME163, its really quite a special wing you know. Had to go really fast and then become a glider, the only reason it was condemned to the dustbin of history was because of mach compression tuck... But for a GA aircraft flying under 600 mph it'll do just fine!
    The cad pic that Tim found doesn't show the leading edge slots but they are there to help airflow keep the elevons working near stall. It's a two person tandem, cog sits on the passengers' belly button, the wing is a re-developed eppler with aerodynamic twist and taper, I took measurements off a real ME163. The verticals are there for stability, I didn't want winglets, they are not necessary, a single fin had no place to go, so it grew two verticals, which actually drop a bit below the wing. Not being made of money (anyomore), I do what I can on it when I find some cents and some time. I'd love to get someone else involved, but haven't gone down that road yet. So there you have it, a potential GA flying wing.
    Happy New year, Greg
    --Conclusions--
    "The flitter has been shown to be a viable aircraft concept. Performance in terms of range, cruise, speed and rate of climb should be good for the relatively low installed horsepower. Aerodynamically, the aircraft is stable and has a cg range of seven inches. In terms of flying qualities, the aircraft is generally level 1 (mil-f-8785c) with some modes level 2. Loads fall within the range expected of an aerobatic aircraft, are well within the capability of either composite or metal structure. "
  9. Likes flyvulcan, Battler Britton, rv6ejguy liked this post
  10. #6
    Join Date
    Mar 2010
    Canada
    Posts
    77
    Likes (Given)
    3
    Likes (Received)
    18
    Re: Flitter
    Hi Bill,
    At this point I am building it moldless, probably s-glass / epoxy. An interesting thing about the design is that the wing center spars really carry most of the loads, the fuselage doesn't really do a whole lot. First set of wings will probably be wood. , (the real ME 163 was wood). The wing is pretty thick (almost a foot at the root) so I am going to have to work hard to come up with a light strong structure. Powerplant can be many things, from a rotax to a lycoming. I am happy to report it is not a canard!
    Greg
  11. #7
    Registered User Autodidact's Avatar
    Join Date
    Oct 2009
    Oklahoma
    Posts
    4,045
    Likes (Given)
    779
    Likes (Received)
    556
    Re: Flitter
    That's very nice! And interesting, too. Really cool looking airplane and I'd like to know how it flies.
    Say, did I ever tell you guys my hummus joke?
  12. #8
    Moderator autoreply's Avatar
    Join Date
    Jul 2009
    Rotterdam, Netherlands
    Posts
    10,579
    Likes (Given)
    243
    Likes (Received)
    2216
    Re: Flitter
    Hi Bill,
    Greg
    How do you plan to do that, glass the foam, then carve out all the foam on the inside?
    Kennis vermenigvuldig je door het te delen.
    (You multiply knowledge by dividing it)
  13. #9
    Join Date
    Mar 2010
    Canada
    Posts
    77
    Likes (Given)
    3
    Likes (Received)
    18
    Re: Flitter
    Hi auto,
    The first layer of glass is already on. My plan is to carve out the foam and then add my bulkheads and stringers. I think this is the quickest way to a prototype.
    Greg
  14. #10
    Registered User
    Join Date
    Sep 2014
    Canada
    Posts
    629
    Likes (Given)
    3
    Likes (Received)
    156
    Re: Flitter
    On construction methods and mood less composites .....
    Is there a way to infuse resin in two or three steps?
    I was thinking about hot-wire or CNC cutting foam blocks into the basic loft lines, then further cutting it into smaller components (e.g. wing leading edge). Ribs or spars or bulkheads could be glassed before the blocks are glued back together.
    For example: The wing leading edge (D spar) would be wrapped in composite (e.g. Carbon fibre) and infusing resin.
    The second (infusion) step involves gluing the wing centre box to the leading edge, wrapping a second layer of composite fabric and infusing resin.
    Repeat the process until it looks like a wing.
    Is multi-step infusion possible with current technology?
  15. #11
    Join Date
    Jul 2009
    Posts
    10,579
    Likes (Given)
    243
    Likes (Received)
    2216
    Re: Flitter
    Quote Originally Posted by Riggerrob View Post
    Yes.
    I doubt it's desirable though. Infusing foam is going to be heavy and most foams (XPS) will absorb enough resin to make your plane really heavy. Worse, foam has very low stiffness so it will compress under vacuum. With a skin and the mold on the outside, that's a non-issue. With a massive foam core wing, it'll deform a lot.
    It gets worse. One of the dirty little secrets of engineering is tolerance stacking. The moment you start adding up parts, dimensions of multiple parts or shapes of multiple parts, it is hell to get them all perfectly aligned, especially for a wing section. Worse, if you have varying stiffness in the structure (like a shear web and ahead of that just foam core), it is very easy to deform the "soft" part during joining. That's why virtually every molded composite wing has a top and bottom half; the stiff spar is far away from the joint and the LE is very stiff in bending up/down and fwd/aft, but pretty flexible in conforming to exactly the right airfoil shape if you use a mold.
    Thanks BradyAero!
    How do you plan to keep the skin stiff enough with the foam removed, temporary external supports?
    Your plan should work if the outside surface is good enough. If not, you have the start of a plug where you can make perfect skins in one go.
    Do you plan to make the wings removable? If not, a single big mold (if space allows) for both the top and bottom half would be the ultimate way to make it extremely light and simple to build.
  16. #12
    Registered User Victor Bravo's Avatar
    Join Date
    Jul 2014
    Posts
    2,449
    Likes (Given)
    511
    Likes (Received)
    2113
    Re: Flitter
    Pretty sure I have a Graupner or Multiplex molded foam flying wing electric that looks just like this Flitter. Flew really fast and reasonably stable.
    "Everything in this book may be wrong."
    Richard Bach, Illusions
Posting Permissions
  • You may not post replies
  • You may not edit your posts
