Likes Likes:  0
Results 1 to 11 of 11
Thread: junkers flaps info after 1930's?
  1. #1
    Registered User
    Join Date
    Nov 2007
    Posts
    1,547
    Likes (Given)
    9
    Likes (Received)
    120
    I've been looking around for info on Junkers flaps, but everything I've found so far is from the 1930's and isn't necessarily all that precise. Plus I'm thinking with CFD and all, there might be foils especially designed for it. For Part 103, they are flaps that the will be recognised as such, maybe making things look a bit less high tech. And if I read, was it Hoerner's?, correctly, less drag for the additional lift than some other types. Seems like they might be simpler to build than some of the other flaps that can get the same sort of high Cl, plus allow a bit of negative when trying to escape sink.
    Anyway, anyone seen more recent info about them.
    BTW, has anyone seen info about two part symmetrical airfoils, which are sometimes used for sailboats. One of my persistent fantasies is to build the highest pointing, fastest Footie. http://www.sailfootyuk.com/
    Thanks,
    Lincoln
  2. #2
    Registered User BJC's Avatar
    Join Date
    Oct 2013
    Posts
    5,196
    Likes (Given)
    2719
    Likes (Received)
    3247
    Re: junkers flaps info after 1930's?
    Quote Originally Posted by lr27 View Post
    Thanks,
    Lincoln
    This wing sail did well:
    http://ultraviolet.org/scottmetze/Ru...088/index.html
  3. #3
    Registered User dcstrng's Avatar
    Join Date
    Oct 2010
    South of the Potomac
    Posts
    714
    Likes (Given)
    818
    Likes (Received)
    211
    Lincoln
    I gather you've already looked at the NACA archive... you're right, from the 1930s -- see reports #541, #614, #573, #604 and #603 if you haven't already... mostly build around the 23012 wing as I recall. Old, but plenty precise enough for anything I'd be able to build... I'd have to dig out my Hoerners, don't recall what he might have said about non-attached flaps...
    See: http://naca.central.cranfield.ac.uk/
  4. #4
    Registered User
    Join Date
    Dec 2015
    Earth USA East Coast
    Posts
    914
    Likes (Given)
    327
    Likes (Received)
    220
    Thanks,
    Lincoln
    Possibly because external airfoil flaps -- like Junkers and Youngman flaps -- are not seen to be sufficiently superior to Fowler flaps. Of course, there is a lot of information on multi-element airfoils, with cascades being the most extreme type.
  5. #5
    Registered User Hot Wings's Avatar
    Join Date
    Nov 2009
    Posts
    4,402
    Likes (Given)
    144
    Likes (Received)
    1334
    Quote Originally Posted by Swampyankee View Post
    But Fowler flaps make really lousy ailerons! For ultralights and flying wings the Junkers are a pretty good trade.
    Conventional wisdom and practices yield conventional results. If that is good enough for you:
    Problem solved.
    "--and pompous fools drive me up the wall. Ordinary fools are all right; you can talk to them, and try to help them out."
    Richard P. Feynman
    “Without deviation from the norm, progress is not possible.”
    Frank Zappa
  6. #6
    Registered User
    Join Date
    Apr 2014
    Flint, Mi, USA
    Posts
    720
    Likes (Given)
    191
    Likes (Received)
    224
    Thanks,
    Lincoln
    This may help with the Footie. http://www.sailwings.net/article.html
  7. #7
    Registered User
    Join Date
    Nov 2007
    Posts
    1,547
    Likes (Given)
    9
    Likes (Received)
    120
    Thanks. I've seen various sailing things with self-trimming wing sails like that, but what I had in mind was keeping the two parts very close and using the rear part like a slotted flap which could be put on one side or the other depending on whether it was port or starboard. This would provide a much higher lift coefficient.
    Here's a rig using both ideas:
    http://www.lusas.com/case/composite/...sail_yacht.jpg
    Of course, on a footie the Reynolds numbers would be just a bit lower.
    Anyway, someone somewhere knows a lot about this stuff.
  8. #8
    Registered User
    Join Date
    Nov 2007
    Posts
    1,547
    Likes (Given)
    9
    Likes (Received)
    120
    Found a list of references in a paper. The paper itself wasn't so hot.
    NASA:
    CR-198580
    CP-2487
    TM-85788
    CP-2413
    TP-1865
    Multiple Element Airfoil Optimized for Maximum Lift Coefficient, AIAA Journal Vol 10, December 1972
    High Lift Aerodynamics, Journal of Aircraft Vol 2 No 6 1975
    However, I suspect most of these will be only tangentially related.
  9. #9
    Registered User
    Join Date
    Jul 2014
    Posts
    811
    Likes (Given)
    318
    Likes (Received)
    157
    For sailing, have you discovered the Amateur Yacht Research Society? http://ayrs.org They've had numerous unusual sails over the years.
  10. #10
    Registered User
    Join Date
    Dec 2015
    Posts
    914
    Likes (Given)
    327
    Likes (Received)
    220
    Quote Originally Posted by Hot Wings View Post
    Well, there is that.
    If I remember, one of the problems with external airfoil flaps (Junkers are one variety) is that there is a lot of adverse yaw. The other problems, such as high drag and ice accumulation aren't problems for low-speed, fair-weather only aircraft.
    Look up information on multi-element airfoils. Junkers (and Fairey-Youngman) flaps are a special case of those.
  11. #11
    Registered User
    Join Date
    Nov 2007
    Posts
    1,547
    Likes (Given)
    9
    Likes (Received)
    120
    High drag is a problem in the case I'm looking at. However, the numbers I've seen from the thirties don't look so bad. I think the drag coefficient with a slightly negative flap was something like 0.01, but the chart was hard to read.
    However, I ran into a paper* on a two element laminar flow setup with fixed positions. I'm not sure I believe the polar, but it maxed out at a Cl of something like 2.7, as I recall, and had Cd in the neighborhood of 0.01 between Cl of less than zero up to about 1!
    Oops, that was the CFD result, experiment was somewhat lower. Haven't pored over it enough to figure out if it's really better, and not sure I can trust it anyway.
    *A thesis by a Mr. Steen at Texas A&M called A TWO ELEMENT LAMINAR FLOW AIRFOIL
    OPTIMIZED FOR CRUISE
Similar Threads
  1. ALCO Sportplane 1930 (Flying and glider manual)
    By rbrochey in forum Wood Construction
    Last Post: December 22nd, 2016, 01:30 PM
  2. Question re: Junkers flaps
    By rtfm in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: January 19th, 2016, 04:18 AM
  3. Junkers flaps
    Last Post: December 2nd, 2015, 10:50 PM
  4. A flight aboard the DoX. 1930
    By Brian Clayton in forum Hangar Flying
    Last Post: September 29th, 2013, 10:09 PM
  5. Fast Forward to the 1930's
    By ccg in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: July 27th, 2011, 02:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
