Likes Likes:  0
Results 1 to 13 of 13
Thread: Another dumb noob question...
  1. #1
    Registered User
    Join Date
    Jul 2016
    Queensland, Australia
    Posts
    138
    Likes (Given)
    19
    Likes (Received)
    16
    Has anyone tried coating a particularly critical load-bearing structure (like, say, a wing spar) with this Line-X coating?
    https://youtu.be/30Q4HK7wcJE
    Weight penalty?
    Benefit/deficit ratio?
    Apologies if this has been asked/discussed before.
  2. #2
    Registered User Winginit's Avatar
    Join Date
    Jun 2016
    Indiana
    Posts
    373
    Likes (Given)
    84
    Likes (Received)
    115
    Re: Another dumb noob question...
    Quote Originally Posted by Thunderchook View Post
    Weight penalty?
    It's been suggested that fuel tanks might benefit from an external coating of LineX.
    https://www.youtube.com/watch?v=PdY9s9kxv14
    Everything I post is just my misguided personal opinion !
    Look for Torque and you will find HP !
  3. #3
    Registered User
    Join Date
    Jul 2016
    Posts
    138
    Likes (Given)
    19
    Likes (Received)
    16
    Quote Originally Posted by Winginit View Post
    Just the fuel tanks?
    Nothing else?
  4. #4
    Registered User
    Join Date
    Jan 2013
    Right here in front of my computer
    Posts
    2,046
    Likes (Given)
    300
    Likes (Received)
    335
    If I paint my car with this will it then be a tank? Might have to try this...lol
  5. #5
    Registered User
    Join Date
    Jan 2013
    Posts
    2,046
    Likes (Given)
    300
    Likes (Received)
    335
    Quote Originally Posted by N8053H View Post
    I see they tried this. They made one mistake by only coating one side of the car panels. I would coat all sides by taking the car apart and then putting it back together.
  6. #6
    Registered User Battler Britton's Avatar
    Join Date
    Nov 2015
    Montpellier,LFNG most of the time and Fontainebleau(shop) France
    Posts
    330
    Likes (Given)
    1725
    Likes (Received)
    191
    nice..but what about aerodynamic, and ....weight!!
  7. #7
    Registered User
    Join Date
    Jul 2016
    Posts
    138
    Likes (Given)
    19
    Likes (Received)
    16
    Quote Originally Posted by Battler Britton View Post
    .... which is what I basically postulated in the OP.
    The videos basically show plastic cups with a coating of 1-2mm.
    Has anyone done the numbers?
    My thinking is that you could use a very light material (e.g. Styrofoam) and coat it with this tuff.
    it would be good if someone could give it a try and then apply loads to test the potential.
  8. #8
    Registered User bmcj's Avatar
    Join Date
    Apr 2007
    Fresno, California
    Posts
    11,543
    Likes (Given)
    6207
    Likes (Received)
    3900
    There you go...I've never trusted the idea of foam-only wing ribs, but coat them or make them out of this stuff and...
  9. #9
    Registered User
    Join Date
    Sep 2014
    Canada
    Posts
    656
    Likes (Given)
    3
    Likes (Received)
    165
    LineEx would be most valuable to bush pilots, cargo pilots and crop dusters who routinely land on gravel strips. LineEx could protect high-wear areas like door frames and cargo floors. LineEx could also reduce rock chip damage to the undersides.
  10. #10
    Join Date
    Apr 2007
    Fresno, California
    Posts
    11,543
    Likes (Given)
    6207
    Likes (Received)
    3900
    Quote Originally Posted by Riggerrob View Post
    Never break another prop!
  11. #11
    Registered User D Hillberg's Avatar
    Join Date
    Nov 2010
    very low low low earth orbit
    Posts
    964
    Likes (Given)
    262
    Likes (Received)
    349
    We used it for edge trim on the 214 huey seat and thin plywood floor liners - it lasts and lasts , thinking on using it for fuel system (aluminum & nylon cloth tanks) great stuff
  12. #12
    Join Date
    Apr 2007
    Fresno, California
    Posts
    11,543
    Likes (Given)
    6207
    Likes (Received)
    3900
    Looks like amazing stuff, but...
    Is it fuel-proof and alcohol-proof? What is the longevity of the stuff? Does it harden or get brittle with age?
    In regard to using it on a spar, the spar should already be designed to handle all normal loads. If you need this stuff to supplement the spar, then you will need to know the materials properties before you can properly calculate its application and effect. Once on, how do you inspect the spar or do repairs on the spar?
  13. #13
    Registered User
    Join Date
    Jan 2015
    My Moms basement
    Posts
    734
    Likes (Given)
    52
    Likes (Received)
    441
    I know guys are spraying that stuff on wore out alaskan bush wheels. Anything to get more life out of tires that cost 4 grand.
Similar Threads
  1. Okay... another dumb, newbie question...
    By Gimballock in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: June 25th, 2014, 09:54 PM
  2. Noob experimental question
    By Holtzy3 in forum Hangar Flying
    Last Post: June 6th, 2014, 10:18 AM
  3. Dumb question
    By buzzypeterson in forum Composites
    Last Post: September 11th, 2013, 06:21 PM
  4. Dumb question, perhaps
    By H.Evan'sRV7A in forum General Experimental Aviation Questions
    Last Post: June 21st, 2012, 02:54 PM
  5. maybe a dumb question
    By WingNut in forum Soaring
    Last Post: October 1st, 2010, 02:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
