Results 1 to 11 of 11
Thread: Fire Sleeve
  1. #1
    Registered User TXFlyGuy's Avatar
    Join Date
    Apr 2012
    Republic of Texas
    Posts
    655
    Likes (Given)
    43
    Likes (Received)
    196
    Fire Sleeve
    How many of you have chosen to fire sleeve the fuel / oil lines FWF?
    Why? Why not?
    edit: Here is the source for materials - www.tsflightlines.com
    Deplorable before it was cool to be deplorable.
  2. #2
    Registered User
    Join Date
    Jan 2013
    Posts
    3,964
    Likes (Given)
    1930
    Likes (Received)
    3321
    Re: Fire Sleeve
    Yes. Safety.
  3. #3
    Registered User Mark Z's Avatar
    Join Date
    Aug 2012
    Granbury, Texas USA 0TX0
    Posts
    369
    Likes (Given)
    104
    Likes (Received)
    139
    Re: Fire Sleeve
    I did it on my T-210; they're everywhere. If nothing else, the fire sleeving is easier to clean than braided hose. PHT out of OK did mine.
  4. #4
    Registered User
    Join Date
    Apr 2010
    Posts
    7,268
    Likes (Given)
    0
    Likes (Received)
    1691
    Re: Fire Sleeve
    Every line; every inch.
  5. #5
    Registered User BJC's Avatar
    Join Date
    Oct 2013
    Posts
    4,907
    Likes (Given)
    2545
    Likes (Received)
    3091
    Re: Fire Sleeve
    As Pops said, yes, because of safety.
  6. #6
    Registered User
    Join Date
    Aug 2008
    Concord, NC
    Posts
    625
    Likes (Given)
    13
    Likes (Received)
    170
    Re: Fire Sleeve
    No but I have pushers. I want to be able to inspect the lines. I change rubber Aeroquip hoses about every 5-7 years. If I was flying tractor engine airplanes where a broken exhaust pipe might put hot gases on fuel/oil lines, I might use firesleeve. Just reading that the major source of engine fires is broken exhaust pipes.
    Kent
    -Cozy Mk IV - flying 650 hrs, Long-EZ - 25 hrs, BD-5 o-t-g
  7. Likes cheapracer liked this post
  8. #7
    Registered User gtae07's Avatar
    Join Date
    Dec 2012
    Georgia
    Posts
    1,127
    Likes (Given)
    556
    Likes (Received)
    655
    Re: Fire Sleeve
    I plan to use the conductive teflon lines with integral firesleeves for everything FWF. That's how we do all the hoses on the big airplanes within the fire zones.
    I reserve the right to be smarter tomorrow than I was yesterday.
  9. #8
    Registered User bmcj's Avatar
    Join Date
    Apr 2007
    Posts
    11,367
    Likes (Given)
    5992
    Likes (Received)
    3798
    Re: Fire Sleeve
    That, or any form of thermal block, will also reduce the chances of heat-induced vapor lock.
  10. #9
    Registered User Rockiedog2's Avatar
    Join Date
    Dec 2012
    Grenada MS
    Posts
    1,262
    Likes (Given)
    451
    Likes (Received)
    820
    Re: Fire Sleeve
    yes always
  11. #10
    Join Date
    Apr 2012
    Republic of Texas
    Posts
    655
    Likes (Given)
    43
    Likes (Received)
    196
    Re: Fire Sleeve
    Looks like about $250 in materials to do all of our fluid lines.
    Consider it done.
  12. #11
    Registered User
    Join Date
    Jan 2010
    Cape May NJ USA and Varna Bulgaria
    Posts
    228
    Likes (Given)
    104
    Likes (Received)
    65
    Re: Fire Sleeve
    Quote Originally Posted by gtae07 View Post
    I plan to use the conductive teflon lines with integral fire sleeves for everything FWF. That's how we do all the hoses on the big airplanes within the fire zones.
    The integral stuff is very nice and makes for a clean installation.I havent worked with it on aircraft but we use it on a lot of marine installations and the separate sleeves are notorious for the clamps causing cuts etc while reaching around tight spots.
    I wonder if it's lighter with the built in protection?
    Another benefit of the integral stuff is you can add a lightweight reflective sleeve in areas where you want or need a belt and suspenders approach.
Similar Threads
  1. How can I fire one plug with two ignitions?
    By challenger_II in forum Firewall Forward / Props / Fuel system
    Last Post: August 19th, 2016, 05:33 PM
  2. Good Video on making Custom Sleeve
    By Armilite in forum 2-Stroke Aircaft Engines
    Last Post: April 4th, 2016, 05:28 AM
  3. Fire susppression systems
    By Alan Waters in forum Firewall Forward / Props / Fuel system
    Last Post: July 23rd, 2013, 09:17 AM
  4. rotax sleeve removal
    By texas-buzzard in forum 2-Stroke Aircaft Engines
    Last Post: October 15th, 2010, 05:30 AM
  5. Protect your investment from fire!
    By Brent Parsley in forum Supplier / Manufacturer Announcements
    Last Post: November 23rd, 2005, 12:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
