Results 1 to 12 of 12
Thread: New Part 23 final rule released
  1. #1
    Registered User gtae07's Avatar
    Join Date
    Dec 2012
    Georgia
    Posts
    1,162
    Likes (Given)
    580
    Likes (Received)
    677
    Located here: https://www.faa.gov/regulations_poli...65_WebCopy.pdf
    Still doesn't address PNC category or any significant relief for Part 21... but the FAA claims to be "working on it"
    I reserve the right to be smarter tomorrow than I was yesterday.
  2. #2
    Registered User Hot Wings's Avatar
    Join Date
    Nov 2009
    Posts
    4,377
    Likes (Given)
    140
    Likes (Received)
    1321
    Re: New Part 23 final rule released
    Only read the first 100 pages or so...
    If Vans were a publicly traded company this would be a good time to invest. Given this NPRM and the speed with which the FAA is likely to revise part 21 Experimentals are going to be the only practical way to design and build the kind of planes that private pilots are likely to fly.
    The ARC report was pretty well ignored by this whole NPRM/ASTM process. The established industry got what they wanted. Job done.
    Typed on tablet. Too many typos to try to correct.
    Conventional wisdom and practices yield conventional results. If that is good enough for you:
    Problem solved.
    "--and pompous fools drive me up the wall. Ordinary fools are all right; you can talk to them, and try to help them out."
    Richard P. Feynman
    “Without deviation from the norm, progress is not possible.”
    Frank Zappa
  3. Likes gtae07 liked this post
  4. #3
    Moderator Topaz's Avatar
    Join Date
    Jul 2005
    Posts
    12,338
    Likes (Given)
    6900
    Likes (Received)
    3910
    I haven't had the time to read it yet today. HotWings, it's that bad for new entrants?
    "If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them." - Henry David Thoreau
    Design Project: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
    Discussion Thread for the Project: Discussion: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
  5. #4
    Join Date
    Nov 2009
    Posts
    4,377
    Likes (Given)
    140
    Likes (Received)
    1321
    Quote Originally Posted by Topaz View Post
    It could be debated either way.
    While there is some improvement over the current situation it also heavily favors existing manufacturers that have a track record with the FAA. For example a new manufacturer will have to have everything they do blessed by the FAA/DER with onsite real time witnessing. Existing entities may be able to simply provide video or logs of the testing.
    The requirements for stall avoidance are also much more onerous than the existing part 23. Think 21st century level of technology to replicate the intent of the Ercoupe with a stick shaker. Yet there is zero that will make something simple like the typical Vans any easier to certify since there is only one lump of aircraft below 6 passenger and 6000 pounds (9 and 9000 in one place in the PDF). This means that a new 2 place trainer has basically the same standards to meet as does a new Beech Baron.
    It's probably not as bad as I see it but I still feel kind of used. This whole process started out with the ARC and was intended to be a way to revitalize the American aircraft industry for simple lower performance aircraft via a set of industry consensus standards. But once the existing manufacturers and EASA got involved it evolved into a way to harmonize the FAA and EASA regulations and cement the existing manufacturers hold on the market.
    Problem solved.
    Richard P. Feynman
    Frank Zappa
  6. #5
    Join Date
    Jul 2005
    Posts
    12,338
    Likes (Given)
    6900
    Likes (Received)
    3910
    Quote Originally Posted by Hot Wings View Post
    A new 2-seat trainer would require a stick-shaker? It's not the difficulty - just wire a motor with off-center weight to the same sensor as a current stall-warning horn - but it's the principle of the thing. Sheesh.
    Ugh. Just to confirm, this affects Part 23 and not S-LSA certification, correct?
  7. #6
    Join Date
    Nov 2009
    Posts
    4,377
    Likes (Given)
    140
    Likes (Received)
    1321
    Fortunately This does not effect LSA - directly. There has been some attempted meddling with the ASTM F37 group from the F39 (new part 23) but so far ASTM bylaws have prevented it. At one point some of the guys that were new to the ASTM process actually thought that they could unilaterally change the ASTM LSA standards to 'harmonize' them.
    It seems to me that the end result of all of this is that if you want to bring a new simple plane to market it's going to be bound by the LSA limitations simply because it's the only viable route to certification for something that is real world simple.
    The only other option would be to gather up a bunch of aviation enthusiasts to form a new ASTM group to put in place a set of standards to provide 'another path to show compliance' (FAA speak) for Primary category aircraft. IIRC the original Primary NPRM (which I can't find right now) specifically stated that the standards were intended/desired to be set by an industry standards group. Noting ever became of that idea. For what many of us would like to see there is a lot good to be found in the Primary category. It's basically describes a 172 that can be flown at night, IFR, and as fast as you want.
    If such an ASTM group were to be formed I'd put in some time provided it's an outgrowth of the F37 (Sport) and not F39 (part 23) - after the spring semester is over. Don't expect to have much free time until then.
    Problem solved.
    Richard P. Feynman
    Frank Zappa
  8. #7
    Registered User BBerson's Avatar
    Join Date
    Dec 2007
    Posts
    7,180
    Likes (Given)
    1231
    Likes (Received)
    1070
    The "simple airplane" category was dropped.
    Glad I dropped out of the process.
  9. #8
    Join Date
    Jul 2005
    Posts
    12,338
    Likes (Given)
    6900
    Likes (Received)
    3910
    The thing I absolutely love about the ASTM standard for S-LSA is that it allows a complete spectrum of kit "completion", from plans-only all the way up to fully-completed airframes, ready-to-fly. That's a real opportunity for a new entrant to slowly "bootstrap" themselves up from start-up to a "real" airplane company. I don't see the LSA restrictions as particularly onerous, since from my own research it seems that there's a broad interest in airplanes in that performance category, from both Sport Pilots and Private Pilots.
    I need to pick up a copy of the LSA certification standard. Maybe that'll be my Christmas present to myself.
    Thanks for all the information, HotWings. Interesting stuff.
  10. #9
    Join Date
    Nov 2009
    Posts
    4,377
    Likes (Given)
    140
    Likes (Received)
    1321
    From an aircraft certification point of view I don't either. Check you private e-mail...
    Problem solved.
    Richard P. Feynman
    Frank Zappa
  11. #10
    Join Date
    Dec 2012
    Georgia
    Posts
    1,162
    Likes (Given)
    580
    Likes (Received)
    677
    I just want to see the ability to make aircraft/kits the same way we make S-LSA and E-LSA, but for aircraft up to at least the RV-10 category, if not the full "under 6000lb and 250kt" category mentioned in the 3rd class medical exemption. Every day at work I learn more about what goes in to actually certifying an aircraft, in terms of the paperwork and bureaucratic mess I just don't see how in the heck a smaller company fresh to the market could ever hope to certify a new airplane. In one of our training classes the instructor even said "the FAA doesn't add value".
    Part 23 isn't really the problem. It's Part 21 and the FAA's insistence that it have its dirty little paws into every single step of every single process of every single part of manufacturing every single aircraft that causes the problem. It's the FAA's use of the meetings to schedule meetings, forms to authorize the forms that authorize the forms, the processes that generate paperwork whose value in simply the raw cost of paper exceeds the cost of the actual part being authorized, and the sheer magnitude of non-value-added paper-pushing that makes certification so hard. I'd estimate that certifying an aircraft "the FAA way" at least doubles your design and testing costs and adds 50% to your build labor cost, compared to designing, testing, and building the exact same airframe without the regulations.
  12. #11
    Registered User
    Join Date
    Mar 2008
    Upper midwest in a house
    Posts
    3,182
    Likes (Given)
    324
    Likes (Received)
    1010
    Quote Originally Posted by gtae07 View Post
    That would be all well and good but who is going to buy them? An RTF RV-10 certificated with consensus standards would cost >$250k at the retail level. Are there 1000's of people that have that kind if money burning a hole in their pocket just waiting to buy a personal plane? I find it hard to believe.
    “The only difference between reality and fiction is that fiction needs to be credible.” - Mark Twain
    “If you can't dazzle them with brilliance, baffle them with bull$hi+.” ― W.C. Fields
  13. #12
    Join Date
    Nov 2009
    Posts
    4,377
    Likes (Given)
    140
    Likes (Received)
    1321
    If such an ASTM group were to be formed I'd put in some time provided it's an outgrowth of the F37 (Sport) and not F39 (part 23).
    Correction: F39 should be F44 in all of my posts on this thread.
    Problem solved.
    Richard P. Feynman
    Frank Zappa
Similar Threads
  1. Milholland Cabin Eagle plans released!
    By cluttonfred in forum The light stuff area
    Last Post: June 10th, 2016, 06:53 AM
  2. Replies: 6
    Last Post: October 29th, 2015, 05:38 PM
  3. OpenVSP 3.1.0 with VSPAERO Released
    By aviast in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: July 28th, 2015, 03:02 AM
  4. OpenVSP 3.0.0 Released
    Last Post: January 4th, 2015, 09:56 PM
  5. Rotax has released a Mandatory Alert
    By Tony in forum 2-Stroke Aircaft Engines
    Last Post: July 24th, 2012, 08:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
