Results 1 to 8 of 8
Thread: Hello from SW MO
  1. #1
    Registered User
    Join Date
    Dec 2016
    Springfield,MO
    Posts
    6
    Likes (Given)
    4
    Likes (Received)
    0
    Hello from SW MO
    recently medically retired from working on BlackHawks & Chinooks (And G.A. previous to that). When other kids were getting working permits for McDonalds, I was bucking rivets in Cessnas with numb fingers for $2.50\hr.
    I've got an exploratory project bouncing around the noggin. "Exploratory" because I have a shovel ready aviation-unrelated (music studio building) project in front of it.
    In wondering why you never see canard gliders. Seems to me, the design would be perfect, with the appropriate wing & canard design (eventually, to be self-launching). Alas, there must be SOME reason you don't see them!
  2. #2
    Registered User BJC's Avatar
    Join Date
    Oct 2013
    Posts
    5,085
    Likes (Given)
    2648
    Likes (Received)
    3181
    Re: Hello from SW MO
    Welcome to HBA, the best sport aviation place on the www.
    Rutan tried it with this https://en.m.wikipedia.org/wiki/Rutan_Solitaire
    The limitations of the canard configuration have been widely discussed here. Use the advanced search to find those threads.
  3. #3
    Moderator Topaz's Avatar
    Join Date
    Jul 2005
    Posts
    12,333
    Likes (Given)
    6890
    Likes (Received)
    3902
    Welcome to the forums!
    Aspect ratio of the lifting system is one key parameter for soaring performance. For a canard aircraft, the canard itself is included with the wing in that "lifting system." Aspect ratio is defined as span squared divided by total area (b^2/A), so a canard design will always be at a disadvantage compared to "conventional" design.
    The same math applies to biplanes, which is why you don't see high-performance biplane gliders, either.
    "If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them." - Henry David Thoreau
    Design Project: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
    Discussion Thread for the Project: Discussion: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
  4. #4
    Registered User
    Join Date
    Mar 2008
    Upper midwest in a house
    Posts
    3,180
    Likes (Given)
    321
    Likes (Received)
    1010
    Quote Originally Posted by XtremeBudgetMusician View Post
    Same reason you don't see a screen door on a submarine! Just not the optimum solution!
    “The only difference between reality and fiction is that fiction needs to be credible.” - Mark Twain
    “If you can't dazzle them with brilliance, baffle them with bull$hi+.” ― W.C. Fields
  5. Likes rbrochey, Victor Bravo liked this post
  6. #5
    Registered User
    Join Date
    Jan 2007
    Posts
    837
    Likes (Given)
    154
    Likes (Received)
    243
    Welcome to the HBA forum from the Southeast part of Missouri, near Cape Girardeau. Your question is way beyond me so I'll let the others guide you. I do well to follow detailed plans, much less go into "exploration" mode on a project.
    Lynn
    Topaz....I hate to barge into the welcome, but I have a question about your formula. "Aspect ratio is defined as span squared divided by total area (b^2/A), so a canard design will always be at a disadvantage compared to "conventional" design. The same math applies to biplanes, which is why you don't see high-performance biplane gliders, either"
    When applying the formula for aspect ratio on a biplane, would it be the span of one wing squared divided by the area of one wing, or would the span squared of one wing be divided by the total area of both wings?
  7. Likes XtremeBudgetMusician liked this post
  8. #6
    Registered User pwood66889's Avatar
    Join Date
    Feb 2007
    Ozark, Alabama, USA
    Posts
    998
    Likes (Given)
    1
    Likes (Received)
    62
    Welcome to HBA, X. As stated, best forum on the web.
    I worked on the UH-60 myself; now on UH-72.
    Percy in SE Bama
  9. #7
    Registered User bmcj's Avatar
    Join Date
    Apr 2007
    Posts
    11,534
    Likes (Given)
    6197
    Likes (Received)
    3894
    The other issue of the canard is that the canard should stall first to prevent the main (rear) wing from stalling. This means that you will never be able to fly your main wing at the max coefficient of lift (Cl, the peak of the lift/drag curve just before the stall). A lot of soaring flight depends on getting the max lift coefficient to get the best flight results, and a properly designed canard can never reach that full Cl on the main wing.
  10. #8
    Registered User Victor Bravo's Avatar
    Join Date
    Jul 2014
    Posts
    2,582
    Likes (Given)
    549
    Likes (Received)
    2206
    Somewhere else on this forum I posted an anecdote about once sharing a thermal with the Solitaire canard glider. To summarize what others have mentioned already, that configuration has built-in inefficiencies that are unacceptable for the typical glider use.
    There was another really interesting canard glider from Switzerland or somewhere nearby, which had the fuselage suspended from the wing with huge airfoiled V struts, and the canard way the heck out in front. Really exotic and futuristic looking. Didn't work well enough to achieve its mission.
    "Everything in this book may be wrong."
    Richard Bach, Illusions
  11. Likes XtremeBudgetMusician liked this post
Posting Permissions
  • You may not post replies
  • You may not edit your posts
