Results 1 to 6 of 6
Thread: Simple Inspection Panel for Wood Construction.
  1. #1
    Registered User
    Join Date
    Jan 2013
    USA.
    Posts
    4,130
    Likes (Given)
    1982
    Likes (Received)
    3443
    I have used this type of inspection panel for wood construction for 3 airplanes and I like it because its simple and easy to remove with 2 machine screws. This cover is for the flap horn.
    The machine screws are 6/32 X 1/2" that screws into Blind Nuts from Tower Hobbies. 24 for about $2.50. I put a little epoxy on the lip of the blind nut before pressing into the 1/4" plywood. Drill the hole in the plywood the same dia as the od of the body of the blind nut. In the pictures you can see the steel blind nuts in the holes. Front alum lip flush riveted on the cover.
    Dan
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	48402   Click image for larger version.
ID:	48403   Click image for larger version.
    Pops
  2. Likes PTAirco, Joe Fisher liked this post
  3. #2
    Registered User PTAirco's Avatar
    Join Date
    Sep 2003
    Corona CA
    Posts
    3,315
    Likes (Given)
    163
    Likes (Received)
    899
    Re: Simple Inspection Panel for Wood Construction.
    Like it. I also put panels like that wherever struts or wires come through the wing. Can't stand to see just a ragged cut in the fabric.
    "Aeronautical engineering is highly educated guessing, worked out to five decimal places. Fred Lindsley, Airspeed."
  4. #3
    Registered User Victor Bravo's Avatar
    Join Date
    Jul 2014
    KWHP, Los Angeles CA, USA
    Posts
    2,590
    Likes (Given)
    550
    Likes (Received)
    2213
    On a wooden airplane structure, for goodness sakes then make the inspection plates out of plywood too, and cover them with fabric to match the airplane.
    "Everything in this book may be wrong."
    Richard Bach, Illusions
  5. Likes Joe Fisher liked this post
  6. #4
    Registered User
    Join Date
    Jan 2013
    USA.
    Posts
    4,130
    Likes (Given)
    1982
    Likes (Received)
    3443
    Quote Originally Posted by Victor Bravo View Post
    Purist, Purist.
    Have also made fiberglass sheets between two pieces of flat glass and cut the inspection panels out of the fiberglass sheets. The curved baggage door for the forward baggage area on the wood SSSC is fiberglass. Also have a inspection panel of the elevator control horn made from Plexiglas so I can check it on the pre-flight inspection and my elevator. Electric trim tab is honeycomb from the B-1 Bomber. Helicopter airspeed. Tail wire from J-3 Cub wing drag and anti-drag wires, Brake cylinders for a Cessna 150. The aluminum gap seals between the wings and fuselage and the tails and fuselage is house soffit aluminum trim ( comes painted white) Lowes aviation section, aisle 10. . Seat upholstery from Army Surplus store, ( sleeping bag storage bag, $1 ). Fuel strainer on the lower firewall from a 1956 Chevy. Powered with a VW engine with intakes and exhaust SS tubes made from Lowes box store bathroom handrails.
    That is all I can think of for now.
    Dan
    Pops
  7. Likes Rockiedog2, Joe Fisher, D Hillberg, b6313 liked this post
  8. #5
    Registered User
    Join Date
    Jan 2015
    My Moms basement
    Posts
    734
    Likes (Given)
    52
    Likes (Received)
    441
    Isn't some of the J3 drag wires #4? Kinda skinny. Obviously it works.
  9. #6
    Registered User
    Join Date
    Jan 2017
    Cluj-Napoca
    Posts
    2
    Likes (Given)
    0
    Likes (Received)
    0
    That's what I'd like to see as well. Keep it up, though. Almost there.
    __________________________________________________ ___________
Similar Threads
  1. Pushrods vs Cables in wood construction
    By Aerowerx in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: April 24th, 2015, 10:40 AM
  2. Wood Construction or Sheet Metal?
    By addicted2climbing in forum General Experimental Aviation Questions
    Last Post: March 7th, 2012, 02:28 PM
  3. Very simple project 3 axix, wood and fabric starts right now!
    By Catocala in forum The light stuff area
    Last Post: August 27th, 2011, 04:22 PM
  4. aluminum and wood construction
    By flat6 in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: February 22nd, 2011, 07:15 PM
  5. Wood Propeller Construction
    By Jman in forum Firewall Forward / Props / Fuel system
    Last Post: October 29th, 2004, 09:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
