Page 1 of 6 123456 LastLast
Results 1 to 15 of 87
Thread: Any Ragwing Projects here?
  1. #1
    Registered User
    Join Date
    Aug 2010
    Harrisville, MI USA
    Posts
    89
    Likes (Given)
    13
    Likes (Received)
    4
    I am starting a RW 20 project, just wondering if anyone else here is or has ?
    Jake Levi
    We are all in this together.
  2. #2
    Registered User FritzW's Avatar
    Join Date
    Jan 2011
    Las Cruces, NM
    Posts
    1,836
    Likes (Given)
    1399
    Likes (Received)
    1727
    Re: Any Ragwing Projects here?
    I'm a big fan of the RW-19 and 20, I hope you start a build log with lots of pictures
    Iēsous Christos, Theou Yios, Sōtēr
  3. #3
    Registered User
    Join Date
    Mar 2015
    Columbus, OH
    Posts
    29
    Likes (Given)
    Likes (Received)
    1
    I was looking at building the RW-22 and bought the plans. When I was studying up on them, I noticed some issues with the design CG falling within the limits that were called out in the plans. If I remember correctly, normal loads (combinations of 180 lb pilot, 160 lb pax, and full/no fuel) would have had it forward and after of the limits called out in the plans. A bigger issue though was that in order to have the CG fall in range, the landing gear would have had to be moved to right behind the firewall. Otherwise the tailwheel would have ~70 lbs of uplift. I emailed Roger about it but I never heard back from him.
  4. #4
    Registered User
    Join Date
    Aug 2010
    Harrisville, MI USA
    Posts
    89
    Likes (Given)
    13
    Likes (Received)
    4
    I hope so too
    Jake Levi
  5. #5
    Registered User
    Join Date
    Aug 2010
    Harrisville, MI USA
    Posts
    89
    Likes (Given)
    13
    Likes (Received)
    4
    I think it calls for a 170lb pilot on the RW 20.
    I am looking at modifying to a trike. So a lot of things to refigure.
    Roger is about out of it the past several years.
    Jake Levi
  6. #6
    Registered User dcstrng's Avatar
    Join Date
    Oct 2010
    South of the Potomac
    Posts
    712
    Likes (Given)
    817
    Likes (Received)
    210
    Quote Originally Posted by Jake Levi View Post
    I am starting a RW 20 project...
    Let me echo FritzW’s comment – I have the plans and thumb through them from time to time – a fascinating bird, but too many other projects; however, I’d sure like to follow a current build of the R20 (or R19). There is an old YouTube vid of one of the variants that looks almost too good to be true…
  7. #7
    Registered User
    Join Date
    Aug 2010
    Harrisville, MI USA
    Posts
    89
    Likes (Given)
    13
    Likes (Received)
    4
    That's the same one that is shown with the plans , now sold with a DVD or downloadable. Under 50' on landing and takeoff. They claim 30 '.
    Right now I am reorganizing my shop, while scouting material.
    Jake Levi
  8. #8
    Registered User Tiger Tim's Avatar
    Join Date
    Apr 2013
    Posts
    1,402
    Likes (Given)
    476
    Likes (Received)
    785
    Quote Originally Posted by skybound View Post
    Something sounds off about this statement. I don't know who it lies with but it sounds like somebody along the line either mis-measured, misspoke or misunderstood what was going on.
    If you do a search on the forum for Ragwing you'll see there have been a number of projects started on here and even a few finished.
  9. #9
    Registered User
    Join Date
    Aug 2010
    Harrisville, MI USA
    Posts
    89
    Likes (Given)
    13
    Likes (Received)
    4
    Hi Tim
    I saw that, and was wanting to see if any builders were active here.
    Jake Levi
  10. #10
    Registered User
    Join Date
    Mar 2015
    Columbus, OH
    Posts
    29
    Likes (Given)
    Likes (Received)
    1
    Quote Originally Posted by Tiger Tim View Post
    My math (and memory of the results) very well could be off. There was a fair amount of geometry in the wings to get the CG range and I very well could have made a mistake in the math there. There were also a few other factors that led me to choose another plane. I wouldn't say anything bad about it, I just don't think it was the right plane for what I was looking for. I've heard lots of good things about the ragwing planes and would love to follow the build of on.
  11. #11
    Registered User
    Join Date
    Aug 2010
    Harrisville, MI USA
    Posts
    89
    Likes (Given)
    13
    Likes (Received)
    4
    There is another Ragwing that I like, the Special 26, but the 20 has the cabin, our season is too short for me to justify a short season flying plane. I have a couple more things to get done in the shop, while searching for wood, and order some plywood.
    Jake Levi
  12. #12
    Registered User Eagle's Avatar
    Join Date
    Aug 2015
    Good ole Usa
    Posts
    83
    Likes (Given)
    35
    Likes (Received)
    22
    Anyone here ever considered the Pazmany PL-9 Storch ? The plans are quite a bit more expensive, but they are also quite a bit more extensive.
    I don't believe there has ever been a more detailed set of plans for a homebuilt airplane.
    Everyone should have a dream. https://www.youtube.com/watch?v=RxPZh4AnWyk
    And be thankful to those people who gave you the opportunity to fulfill your dream. https://www.youtube.com/watch?v=9bWIRVcOYzw
  13. #13
    Registered User
    Join Date
    Apr 2010
    Posts
    7,620
    Likes (Given)
    1
    Likes (Received)
    1789
    The Pazmany Storch is a different animal. Its standard homebuilt, where as the RW 20 is more of a fat UL. The RW 20 is about starting with the lightest airframe and engine and then it is strong enough to carry someone. Once you add the passenger, you just added 25%, guess, to the gross; the plane will be a different animal. The Pazmany is regular construction, heavier, and bigger engines, tougher construction. It is full size Cub and Bearhawk Patrol type of aircraft. Across the taxiway, there is one of the Australian Storchs, I believe it was the US factory demo plane. It is a project now; blown over in a wind and wings damaged. It is an impressive aircraft stands very tall. Real ones had a machine gun out the back though.
  14. #14
    Join Date
    Apr 2013
    Posts
    1,402
    Likes (Given)
    476
    Likes (Received)
    785
    The RW26 looks like it would be a ton of fun to fly and the season can be pretty long if you dress warm...
  15. #15
    Registered User
    Join Date
    Aug 2010
    Harrisville, MI USA
    Posts
    89
    Likes (Given)
    13
    Likes (Received)
    4
    Quote Originally Posted by TFF View Post
    That's a very good assessment. My idea is to just very lightly add some structure thickening and a bit higher hp engine. To offset that 25% increase.
    The pazmany is a very impressive plane but much higher building cost, the engine alone is more then the cost of the RW 20. The Pazmany is a heavier plane , empty weight twice the Ragwing, and engine 3Xs the hp.
    Jake Levi
Similar Threads
  1. Projects that get in the way....
    By Monty in forum Hangar Flying
    Last Post: October 25th, 2013, 07:15 AM
  2. [Wanted] Three experimental projects need completing.
    By Hugh Lorimer in forum For Sale / Wanted
    Last Post: July 14th, 2013, 02:23 AM
  3. Vision Projects?
    By beakon20 in forum Composites
    Last Post: December 11th, 2011, 09:29 PM
  4. Inline engine projects?
    By cluttonfred in forum Firewall Forward / Props / Fuel system
    Last Post: April 27th, 2011, 02:06 PM
  5. Big projects
    By smenkhare in forum Hangar Flying
    Last Post: February 21st, 2007, 06:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
