Results 1 to 10 of 10
Thread: Normalize welded clusters and temperature crayon
  1. #1
    Registered User proppastie's Avatar
    Join Date
    Feb 2012
    Posts
    1,647
    Likes (Given)
    413
    Likes (Received)
    320
    I read conflicting statements....the heat after welding a cluster is "just stress relief" ....heat it to "blood Red" to re-normalize the cluster....There are temperature crayons that should melt at the proper temperature for a proper normalization, however the thought occurs to me that the torch might melt the mark before the metal is soaked to the proper temperature. ...
    Has anyone used these crayons on welded clusters, any tricks... does it work? is the cluster normalized or just stress relieved (annealed)
  2. #2
    Registered User
    Join Date
    Apr 2010
    Posts
    7,622
    Likes (Given)
    1
    Likes (Received)
    1789
    Re: Normalize welded clusters and temperature crayon
    Unless you heat the whole structure, you cant normalize. Term can be slang for the stress relieving local joints. Crayons are nice to make sure you hit the temp marks. Just depends on how precise the engineering needs to be.
  3. #3
    Registered User
    Join Date
    Apr 2010
    Posts
    7,622
    Likes (Given)
    1
    Likes (Received)
    1789
  4. #4
    Join Date
    Feb 2012
    Posts
    1,647
    Likes (Given)
    413
    Likes (Received)
    320
    Quote Originally Posted by TFF View Post
    Well we start out with normalized tube.... not sure what you are saying here. can/cannot re-normalize weld clusters after welding normalized 4130 steel tube fuselage using temperature crayons? Can/cannot re-normalize weld clusters under any circumstances?
    Anyone use them on aircraft fuselages?
  5. #5
    Registered User
    Join Date
    Apr 2010
    Posts
    7,622
    Likes (Given)
    1
    Likes (Received)
    1789
    To normalize 4130 you have to stick the whole thing in an oven at 500F for like a half an hour. No one I know has a 20 ft oven. 4130 was designed so it is still strong enough as welded , depending on the quality of the welding job. If your joint is normal airplane clusters that is how they are designed. The plus side of the joints stressed relieved is that they are less brittle. If you need a bracket or fitting that needs the extra strength, that is more doable. The tubes have to be vented if normalizing. I know of a helicopter company who experimented with one of their producion 4130 tube structures that was not vented and it came back with tubes sucked in where they were not vented.
  6. Likes don january liked this post
  7. #6
    Registered User wsimpso1's Avatar
    Join Date
    Oct 2003
    Posts
    3,725
    Likes (Given)
    628
    Likes (Received)
    1404
    500F is way low, but it might stress relieve the area.
    Normalization of steels require on the order of 1300-1400F. Yep, red hot throughout. Then it has to be cooled in still air.
    We do not need it in 4130 airplane parts. Lots of airplanes out there with weld clusters just warmed up with a torch and allowed to cool, and we do not hear about them falling out of the sky because of failed welds.
  8. Likes BBerson, Midniteoyl liked this post
  9. #7
    Registered User BJC's Avatar
    Join Date
    Oct 2013
    Posts
    5,175
    Likes (Given)
    2708
    Likes (Received)
    3238
    Lots, also, with TIG welded clusters that had no post-weld treatment and have been flying trouble-free for years.
  10. Likes wsimpso1, Midniteoyl liked this post
  11. #8
    Join Date
    Feb 2012
    Posts
    1,647
    Likes (Given)
    413
    Likes (Received)
    320
    Quote Originally Posted by wsimpso1 View Post
    To go further, in Tony Bingelis "The Sport Plane Builder" Page 58 talks about normalizing/stress relieving, with tempering to 1050 (Blood Red Color) 125,000 PSI RC25, vs 1650 (Salmon Color) 95,000 PSI Normalized... 1/3 more than annealed (62,000 psi ?).
    For fittings designed in shear/tension (not a good practice I know) this is perhaps significant. (Although doubling the size of tubing at one or two joints may not be that much weight.)
    Anyway the the thought was to use temperature crayons and I wondered if anyone here has. The amount of experience and expertise here is pretty amazing.
  12. #9
    Registered User Hot Wings's Avatar
    Join Date
    Nov 2009
    Posts
    4,400
    Likes (Given)
    142
    Likes (Received)
    1334
    Quote Originally Posted by proppastie View Post
    You really don't need the crayons if you just learn to read the color of the hot metal. The metal's black body color is directly tied to it's temperature.
    Click image for larger version.
Name:	metal color temp chart.png
    Conventional wisdom and practices yield conventional results. If that is good enough for you:
    Problem solved.
    "--and pompous fools drive me up the wall. Ordinary fools are all right; you can talk to them, and try to help them out."
    Richard P. Feynman
    “Without deviation from the norm, progress is not possible.”
    Frank Zappa
  13. Likes PTAirco liked this post
  14. #10
    Registered User PTAirco's Avatar
    Join Date
    Sep 2003
    Corona CA
    Posts
    3,333
    Likes (Given)
    164
    Likes (Received)
    907
    I've had some of my gas welded clusters and joints analyzed by a lab many, many years ago. They cut them, looked at them with microscopes, x-rayed them, tensile tested them, bent them back and forth, hammered them and generally abused the hell out of them. The minimum strength they found in theses pieces was 87% of the original normalized 4130 tubing. I was happy with that and used a very conservative figure based on that number for design purposes.
    These joints were not stress relieved or post-weld heated; I just played the torch over them and let them cool somewhat gradually once the weld was completed and made sure they didn't get draughts on them. That is all there is too it, no need to overthink it.
    "Aeronautical engineering is highly educated guessing, worked out to five decimal places. Fred Lindsley, Airspeed."
  15. Likes Midniteoyl liked this post
Similar Threads
  1. Welding Clusters
    By JohnS in forum Tube and Fabric
    Last Post: May 28th, 2015, 02:03 PM
  2. Welded aluminum wings?
    By addaon in forum Sheet Metal
    Last Post: June 9th, 2013, 11:34 PM
  3. Simplest welded steel fuselage?
    By cluttonfred in forum Tube and Fabric
    Last Post: March 18th, 2013, 03:17 PM
  4. Welded Steel Tube Strength
    By GESchwarz in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: February 9th, 2011, 08:49 PM
  5. Welded components?
    By Ryan2200 in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: December 23rd, 2005, 07:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
