epoxys
Chester
Jul 20, 2005
40
Granby, MA
Hey everbody
Supplied with my Avid Plus is Loctite 9460 epoxy for the assembly of the wings. The construction manual says to mix it 3 to 2 and use Dow Corning Primer coat on all the aluminum for best adhesion. Well at $20 a pint I wanted to make sure it was needed. I called Loctite and come to find out the mixing ratio is 1 to 1. Loctite wasn't sure what would happen with the epoxy by changing the mix ratio. Plus they weren't sure a primer coat is needed. So I need to do some more research on this.
I'm attaching the tech sheet for the Loctite in case you're using it.
  • hysa9460-en.pdf
