Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 55
Thread: Swept-forward, shoulder-wing configuration
  1. #16
    Moderator Topaz's Avatar
    Join Date
    Jul 2005
    Posts
    12,426
    Likes (Given)
    6980
    Likes (Received)
    3964
    Re: Swept-forward, shoulder-wing configuration
    As far as I know, the "objections" to this configuration are:
    1) Limits visibility directly to the side, and
    2) "It looks weird".
    In terms of marketing, the second factor is by far the largest, by orders of magnitude. I've never heard of any particular safety issues regarding the aircraft listed. You might try contacting SVSUSteve via PM, and see if he has any data about this aspect.
    "If you have built castles in the air, your work need not be lost; that is where they should be. Now put the foundations under them." - Henry David Thoreau
    Design Project: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
    Discussion Thread for the Project: Discussion: Conceptual Design of an "Inexpensive" Single-Seat Motorglider
  2. Likes tunnels liked this post
  3. #17
    Registered User
    Join Date
    Jun 2014
    Over the Rainbow in Kansas, USA
    Posts
    204
    Likes (Given)
    85
    Likes (Received)
    61
    If number 2 matters that much (it looks weird), how do you explain the majority of Zenith aircraft? They look like they were designed by a blind man.
  4. #18
    Join Date
    Jul 2005
    Posts
    12,426
    Likes (Given)
    6980
    Likes (Received)
    3964
    Quote Originally Posted by Highplains View Post
    "Eye of the beholder". They may look a little "odd", but the wing is "where it should be", in the mindset of most pilots. Show some pictures to pilots and ask around. I've been in conversations with some pilots about these very aircraft (the shoulder-wing swept-forward ones). Those two factors listed are the ones that kept coming up as to why those guys didn't like these aircraft. Also a couple of comments that the wing attachment "looked weak", despite the fact that it's potentially a beefier attachment than the typical high-wing Cessna.
  5. #19
    Registered User cheapracer's Avatar
    Join Date
    Sep 2013
    Australian
    Posts
    3,933
    Likes (Given)
    2495
    Likes (Received)
    2237
    Because over a long number of years they have been promoted as a plane that first and foremost performs a function, i.e. STOL, and not as a showpiece.
    Quote Originally Posted by BoKu View Post
    The vast majority of engineering failures are the results of failure of imagination rather than failure of calculation.
  6. #20
    Registered User FritzW's Avatar
    Join Date
    Jan 2011
    Las Cruces, NM
    Posts
    1,842
    Likes (Given)
    1400
    Likes (Received)
    1729
    Your head isn't any closer to anything in one of these than it is in a Cessna 172.
    And yes, I spent 20 years pulling bodies out of wrecked cars. I've seen just about every possible way to get hurt, or killed, in a crash. Thinking that your risk of head injury is increased because of this wing configuration is ...well ...not based on fact.
    Iēsous Christos, Theou Yios, Sōtēr
  7. #21
    Moderator autoreply's Avatar
    Join Date
    Jul 2009
    Rotterdam, Netherlands
    Posts
    10,727
    Likes (Given)
    246
    Likes (Received)
    2303
    Google Schempp Hirth Duo Discus for ideas.
    The "crushing skull" argument is BS. Stub spars break long before that.
    Visibility is great. Make sure eye is level with the wing. That way you can look over it and under it (duck).
    Structural divergence gets a big no-no above 8-10 degrees of fwd sweep.
    The only argument that has any substance against fwd sweep is it's looks...
    Kennis vermenigvuldig je door het te delen.
    (You multiply knowledge by dividing it)
  8. #22
    Banned
    Join Date
    Sep 2014
    china is my home , place of work but was born in New ZEaland
    Posts
    562
    Likes (Given)
    122
    Likes (Received)
    21
    Quote Originally Posted by cluttonfred View Post
    Thanks, all, for the comments and of course with my twin tail fixation I should have mentioned the Nord. Cheapracer, I am not sure if you are being facetious or not but I don't really see any significant crash danger there, maybe you could elaborate? If you're thinking that the wings would fold forward in a sudden stop, I supposed that the inner spars could be made deliberately over strong with a discontinuity to encourage the wing to breakaway further outboard, though I suspect that in a crash that severe you'd have other issues to worry about as well.
    for some one wanting better visibility the wing at that height must the worst possible position !!and yes accident and wings crushing your skull that interesting as well I saw that straight away as well !!
  9. #23
    Banned
    Join Date
    Sep 2014
    Posts
    562
    Likes (Given)
    122
    Likes (Received)
    21
    for some one wanting better visibility the wing at that height must the worst possible position !!and yes accident and wings crushing your skull that interesting !!, I saw that straight away as well !!
    going to question mar that on the list of possible build options thats for sure !!
    I see the zenith has there wing almost over head height not shoulder height !
  10. #24
    Registered User
    Join Date
    May 2006
    Posts
    870
    Likes (Given)
    11
    Likes (Received)
    126
    I am glad to hear autoreply mention that you can go up to 10 degrees of forward sweep without risk. Jim Marske and Orion have said that as well. The MFI is an interesting design with an original conception that was great for the homebuilder. I believe it had three bulkheads. The Cygnet was geodetic which was supposed to make it cheaper to build. I have never seen the P130 before.
  11. #25
    Registered User
    Join Date
    Jun 2014
    Posts
    204
    Likes (Given)
    85
    Likes (Received)
    61
    I'm more interested in the aerodynamics of the slightly forward sweep wings. In my experiments with Quickie 500 designs, having a forward sweep wing seemed to lower the drag slightly.
  12. #26
    Join Date
    Jul 2009
    Posts
    10,727
    Likes (Given)
    246
    Likes (Received)
    2303
    Quote Originally Posted by plncraze View Post
    Not without, but somewhere between 10 and 20 degrees of sweep it changes from a "must check a few things" to "wing goes hard over and breaks off".
    completely forgot to mention, but with a certain amount of fwd sweep, your flaps can effectively have zero effect on trim, so you can get away with a much smaller tail. Especially interesting with big (Fowler) flaps.
    the underlined part is obviously only true for REAR sweep...
  13. #27
    Registered User cluttonfred's Avatar
    Join Date
    Feb 2010
    Posts
    3,824
    Likes (Given)
    844
    Likes (Received)
    1176
    Quote Originally Posted by tunnels View Post
    The crash safety issue has already been discussed but from a visibility point of view I think you are way off the mark. A typical side-by-side, two-seat tractor-engine design puts the the center of gravity of the crew about at the belt buckle) above the main spar in a low wing or below the main spar, restricting downward upward visibility substantially. A mid-wing is even worse because the wing is closer and blocks more of the downward view.
    A shoulder wing, however puts the wing edge on to the pilot and allows views above and below the wing. I think it makes sense from a visibility standpoint to cheat it higher than lower as its much easier to duck down than to stretch your neck higher. That said, I am thinking of more of a mid-wing location for my own design, sacrificing some visibility for a smaller and lighter structure.
    Matthew Long, Editor
    cluttonfred.info
    A site for builders, owners and fans of Eric Clutton's FRED
    « Voici ce que j'ai fait...vous pouvez en faire autant! »
    "This is what I have done...you can do the same!"
    --Henri Mignet (1893-1965)
  14. #28
    Join Date
    Jan 2011
    Las Cruces, NM
    Posts
    1,842
    Likes (Given)
    1400
    Likes (Received)
    1729
    The engine is in the wrong place on the J-2 but the plans are free. They might give you some ideas. I think Aerowerx is building a J-1 but with a T tail like the this.
    Click image for larger version.
  15. #29
    Join Date
    Feb 2010
    Posts
    3,824
    Likes (Given)
    844
    Likes (Received)
    1176
    Thanks, Fritz, but I actually think you nailed it when you reminded me of the Nord NC.850 series. Takes this NC.854 and imagine cutting the fuselage down to the level of the top stringer and carry that straight to the firewall, no door. Drop the wing down to sit on top of the fuselage and lose the strut, perhaps with a bit more forward sweep to move the wing root back out of the way. Switch to trigear and you're almost there, but I still have to decide whether to go with an H-tail or something more conventional, maybe an all-moving horizontal stabilator and a swept all-moving rudder like the VP-3. Decisions, decisions.
    cluttonfred.info
  16. #30
    Join Date
    Jan 2011
    Las Cruces, NM
    Posts
    1,842
    Likes (Given)
    1400
    Likes (Received)
    1729
    I can visualize everything your talking about except how your going to do the canopy. ...a VP-3 with the wing mounted on top, moved back and swept forward?
    I still like the H tail though.
Similar Threads
  1. CG of swept tapered wing?
    By rtfm in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: January 9th, 2014, 07:57 AM
  2. Forward Swept Wings - a question
    Last Post: October 29th, 2013, 07:44 PM
  3. Swept Wing Lift
    By Docskyhawk in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: March 29th, 2013, 12:36 PM
  4. Forward swept wings
    By Leighton in forum Hangar Flying
    Last Post: December 28th, 2011, 01:47 PM
  5. Swept wing & Wing Taper
    Last Post: April 11th, 2011, 08:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
