Results 1 to 8 of 8
Thread: Just a quick question and maybe a not so quick answer
  1. #1
    Registered User
    Join Date
    Apr 2013
    CO
    Posts
    6
    Likes (Given)
    1
    Likes (Received)
    Hi guys.
    Alright, here is the situation. I'm looking at building a Pietenpol Air Camper, probably with a Corvair conversion. My question is would it be too under-powered to fly safely in Colorado. Specifically near the Front Range and around the Denver metro area. I love the looks of it and love the fact that it isn't some carbon fiber go fast or load to the gills with technology. But I don't want to start and find out that it's too low powered to fly safely up here. Any input would be greatly appreciated.
    Thanks in advance.
  2. #2
    Registered User bmcj's Avatar
    Join Date
    Apr 2007
    Posts
    11,526
    Likes (Given)
    6184
    Likes (Received)
    3887
    Re: Just a quick question and maybe a not so quick answer
    Which wing... undercamber or flat bottom?
  3. #3
    Registered User
    Join Date
    Apr 2013
    CO
    Posts
    6
    Likes (Given)
    1
    Likes (Received)
    I would think under camber, but I'm probably wrong on that. To be honest, I'm not sure which would be better in my situation.
  4. #4
    Registered User
    Join Date
    Dec 2010
    Middleton, Idaho
    Posts
    243
    Likes (Given)
    44
    Likes (Received)
    36
    Melloguy, There's no quick answer to your question. Here's three things to consider. 1. How much horse power will a Corvair conversion produce at your altitude.
    2. The empty weight of your Air Camper when you finish building it.
    3. The weight at which it will be normally flown at, your weight plus fuel and what ever else.
    jic
  5. #5
    Registered User
    Join Date
    Apr 2013
    CO
    Posts
    6
    Likes (Given)
    1
    Likes (Received)
    I know there isn't. I'm looking at either the 100 or 110 horsepower engines. I think the 120 horsepower version might be too much for the Air Camper, but correct me if I'm wrong. As for the empty weight, since it will be my first build I'm going to assume that I'm going to come out on the heavy side of things, but hopefully not by too much, but I would guess the empty weight would be between 650 and 725 pounds. As for normal flying weight, I'm guessing that it will be around 1,000 pounds or so, figuring my weight and 12 gallons of fuel.
  6. #6
    Join Date
    Apr 2007
    Posts
    11,526
    Likes (Given)
    6184
    Likes (Received)
    3887
    This post on another forum speaks well to your question. I suspect the turbo Subaru is of similar power to the Corvair.
    Matronics Email Lists :: View topic - service ceiling
  7. #7
    Registered User
    Join Date
    Apr 2010
    Posts
    7,488
    Likes (Given)
    0
    Likes (Received)
    1755
    The FAA registry has 2-3 listed in Colorado. Search out those guys from the FAA web.
  8. Likes Topaz liked this post
  9. #8
    Registered User
    Join Date
    Apr 2013
    CO
    Posts
    6
    Likes (Given)
    1
    Likes (Received)
    Thank you guys for the responses and help. I'm sure this won't be the last thing I ask about.
  10. Likes Topaz liked this post
Similar Threads
  1. Quick question on EAA/Sport Aviation Software
    By 32fordboy in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: March 25th, 2011, 10:57 AM
  2. quick question
    By fiddlesticks in forum General Experimental Aviation Questions
    Last Post: September 29th, 2010, 10:27 AM
  3. 2 Quick questions
    By GCD89 in forum Rules and Regulations / Flight Safety / Better Pilots
    Last Post: February 9th, 2010, 05:48 PM
  4. quick certification question
    By wtl0715 in forum Rules and Regulations / Flight Safety / Better Pilots
    Last Post: May 25th, 2006, 01:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
