Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: V Tail Bonanza ruddervator control mixer diagram
  1. #1
    Registered User Lucrum's Avatar
    Join Date
    Jun 2008
    Canton, GA
    Posts
    764
    Likes (Given)
    184
    Likes (Received)
    120
    Anyone have a copy or photo of a 35 Bonanza elevator/rudder flight control mixer diagram from a maintenance or parts catalog maybe they could post or email me?
    Thanks
  2. #2
    Registered User Tom Nalevanko's Avatar
    Join Date
    Oct 2007
    Camarillo, CA
    Posts
    1,287
    Likes (Given)
    3
    Likes (Received)
    101
    Re: V Tail Bonanza ruddervator control mixer diagram
    Here is one from a Robin; hope it helps.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  3. #3
    Join Date
    Jun 2008
    Canton, GA
    Posts
    764
    Likes (Given)
    184
    Likes (Received)
    120
    Thanks Tom, it's a bit small to make out the details but useful non the less.
    I should have specified diagrams of any V tail/ruddervator flight control mixers anyway. It doesn't have to be a Bonanza.
  4. #4
    Join Date
    Oct 2007
    Camarillo, CA
    Posts
    1,287
    Likes (Given)
    3
    Likes (Received)
    101
    If you click on the picture, it gets big. I have lots of others that I will look for...
  5. #5
    Join Date
    Oct 2007
    Camarillo, CA
    Posts
    1,287
    Likes (Given)
    3
    Likes (Received)
    101
ID:	12482Click image for larger version.
  6. #6
    Registered User
    Join Date
    Dec 2010
    Pacific
    Posts
    273
    Likes (Given)
    23
    Likes (Received)
    13
    Rather than starting another thread, I thought I should revive this old one. What are some design consideration and challenges one should keep in mind. Speed is definitely an attraction but what could I be missing?
    Thanks
  7. #7
    Registered User BoKu's Avatar
    Join Date
    Aug 2013
    Douglas Flat, CA
    Posts
    1,261
    Likes (Given)
    2360
    Likes (Received)
    1387
    Quote Originally Posted by Vector View Post
    ...What are some design consideration and challenges one should keep in mind. Speed is definitely an attraction but what could I be missing?...
    I think we're going to need a bit of context before anybody can provide any meaningful information. Are you interested in the tradeoffs between V-tailed and more conventional configurations? Between different mixer arrangements (cable vs push-pull based)?
    I can say that there is no particular speed advantage to the V-tail configuration. In terms of static and dynamic stability per unit wetted area, they are pretty much a wash with conventional tails. They might offer a slight advantage in intersection drag, but it can be a challenge to give them good pitch feel without compromising yaw effectiveness.
    --Bob K.
    Bob Kuykendall
    HP-24 kit sailplane project
    HP-24 Project Facebook Page
    http://www.hpaircraft.com/hp-24
    Akaflieg Arnold Spring 2017!
    EAA Technical Counselor
  8. Likes bmcj, Vector liked this post
  9. #8
    Registered User BJC's Avatar
    Join Date
    Oct 2013
    Posts
    5,085
    Likes (Given)
    2648
    Likes (Received)
    3181
    Quote Originally Posted by BoKu View Post
    --Bob K.
    Although I agree with you, I feel obligated to point out the outstanding, clean, classic aesthetics of the HP-18. (Since I'm not flying sailplanes, I am entitled to opt for looks over performance.)
  10. Likes bmcj liked this post
  11. #9
    Join Date
    Aug 2013
    Douglas Flat, CA
    Posts
    1,261
    Likes (Given)
    2360
    Likes (Received)
    1387
    Quote Originally Posted by BJC View Post
    I really liked the HP-18 until I had one of my own. It is indeed a very pretty glider.
    Bob Kuykendall
  12. Likes BJC liked this post
  13. #10
    Registered User bmcj's Avatar
    Join Date
    Apr 2007
    Posts
    11,534
    Likes (Given)
    6197
    Likes (Received)
    3894
    Oops... that's rather telling.
  14. Likes BoKu liked this post
  15. #11
    Registered User
    Join Date
    Dec 2010
    Pacific
    Posts
    273
    Likes (Given)
    23
    Likes (Received)
    13
    --Bob K.
    Why would an Experimental homebuilt such as the Sonex/Onex use one if the speed gains aren't appreciable.
  16. #12
    Join Date
    Oct 2013
    Posts
    5,085
    Likes (Given)
    2648
    Likes (Received)
    3181
    Aesthetics, marketing.
  17. Likes BoKu liked this post
  18. #13
    Join Date
    Aug 2013
    Douglas Flat, CA
    Posts
    1,261
    Likes (Given)
    2360
    Likes (Received)
    1387
    Let's be clear here, unless you're adding horsepower, speed comes from drag reduction. Drag comes from parasitic things like intersections and protuberances, is also an inescapable cost of producing lift (induced drag) and is an equally inescapable cost of maintaining stability (trim drag).
    V-tails are pretty much dead even with conventional tails in terms of drag per unit effectiveness. When you size a V-tail so that it has the same effectiveness as it's conventional equivalent, you almost always end up with a tail that has the same wetted area, the same induced drag, and near enough the same parasitic drag as makes no difference. In my experience, when you analyze V-tailed aircraft that have lower than expected overall drag, you usually find that it comes at the expense of static stability, with commensurate increases in pilot workload.
    From the perspective of one who's actually made and sold V-tail kits, the real benefit of V-tails pretty much comes down to two words: parts count. If you treat each half of the horizontal stabilizer as a separate surface (not universally valid, but close enough), the V-tail gives you one less surface to kit out, and gives the builder one less surface between starting and done. And in a market where tail kits are often the gateway lure, that can be big.
    Whenever you want to see what a low-drag aircraft looks like, have a look at modern racing sailplanes. What you see is that even contest-optimized sailplanes like the Diana and the Duckhawk, sailplanes that trade a bit of operationality for that last quarter-percent of performance, have conventional T- or cruciform tails, not V-tails.
    --Bob K.
    Bob Kuykendall
  19. #14
    Registered User
    Join Date
    Dec 2010
    Pacific
    Posts
    273
    Likes (Given)
    23
    Likes (Received)
    13
    --Bob K.
    What about in the case of Scaled Composite V-Jett II or the new Cirrus Jet. Could it be that engine placement constrict options? In both instances, a single engine was used. Not arguing with you but trying to understand the decision making of a potential aircraft manufacturer.
  20. #15
    Registered User
    Join Date
    Apr 2010
    Posts
    7,501
    Likes (Given)
    0
    Likes (Received)
    1759
    V tail on the Cirrus jet made the fuselage 100 times simpler to make. No long engine ducts and no structure that had to miss an engine. It looks cool.
  21. Likes BoKu liked this post
Similar Threads
  1. Flap-Pitch Trim Mixer
    By GESchwarz in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: January 14th, 2011, 01:11 AM
  2. Y Tail = less control?
    By rrruuunnn in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: September 18th, 2009, 11:47 AM
  3. Empennage as ruddervator?
    By yankeeclipper in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: July 16th, 2009, 04:51 AM
  4. First pass elevon mixer design
    By addaon in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: April 4th, 2009, 11:31 AM
  5. Vn diagram
    By BDD in forum Aircraft Design / Aerodynamics / New Technology
    Last Post: April 28th, 2005, 08:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
